Old Mar 02, 2012, 04:45 PM
mtflyr is offline
Find More Posts by mtflyr
Centreville,VA,USA
Joined Apr 2001
Start of Micro Voss Dr-I
My good friend and King of Tissue covering depron Speedy01(Gene) has out done himself by tissue covering a 14" WS enlarged paper model plan of Werner Voss's Dr-I 103/17 for me.
The paper plan was the 1:48 scale E-Card model you can buy on line.
Gene also baked each of the wings airfoil in his home built wing gig. So now all I have to do is put it together and add the e-gear.
The 2mm Depron tissue covered parts are only 15 gr's very light weight and the tissue adds some strength.
My friend Jin is working on some laser cut Spandaus that I hope to use on this build.
I hope I can do it justice.
Thanks Gene
Pete
mtflyr is offline Find More Posts by mtflyr
Old Mar 02, 2012, 04:53 PM
NEWBEFLYER is online now
Find More Posts by NEWBEFLYER
Crazy Canuck
NEWBEFLYER's Avatar
United States, VA, Woodbridge
Joined Apr 2007
WOW! Pete, what can I say about your obsession whit WW I planes is this one the foam parts with the tissue on it? You're really going all out here and it's pretty cool.
NEWBEFLYER is online now Find More Posts by NEWBEFLYER
Old Mar 02, 2012, 08:22 PM
R31 Mark is offline
Find More Posts by R31 Mark
amidoinitrite¿ ¿
R31 Mark's Avatar
Joined Feb 2012
This is gonna be an awesome build!!
R31 Mark is offline Find More Posts by R31 Mark
Old Mar 03, 2012, 09:04 AM
mtflyr is offline
Centreville,VA,USA
Joined Apr 2001
Added wheel tubes so they will spin on the wire axle. I'm using the FZ cowling, fake motor (that I'll beef up), the LG struts, etc. Got the elevator cut and tape hinges on.
Gave my German mustashed pilot a shave so maybe it will look more like Voss
Pete
Old Mar 03, 2012, 10:40 AM
speedy01 is online now
Find More Posts by speedy01
Gulf Breeze, FL
Joined Jul 2006
That looks terrific, Pete...especially the prop!
Gene K
speedy01 is online now Find More Posts by speedy01
Old Mar 03, 2012, 10:31 PM
pattypilot is offline
Find More Posts by pattypilot
No dear, That isn't New!
pattypilot's Avatar
United States, IL, Urbana
Joined Nov 2006
Pete, that's going to look amazing! Printed tissue, I haven't worked up the nerve to try that yet! The beat down my wife would put on me for gumming up her printer could be ugly!! Working on my four channel now.
pattypilot is offline Find More Posts by pattypilot
Old Mar 04, 2012, 11:42 AM
CarreraGTSCS is offline
Find More Posts by CarreraGTSCS
Lori, hey, you're home early
CarreraGTSCS's Avatar
United States, NJ, Freehold Township
Joined Jan 2004
Signing on!
CarreraGTSCS is offline Find More Posts by CarreraGTSCS
Old Mar 09, 2012, 07:00 AM
mtflyr is offline
Centreville,VA,USA
Joined Apr 2001
Had some time to work on this bird.
Added some paint and details to the fake motor, added a ply fire wall behind the foam one and epoxied the P-51 motor/gearbox in place, made the wing struts and added some paint to them, installed the PZ brick and added lightly sanded floppy hinge material to the rudder.
Test fit all parts by eye and all looks good next, I'll add the rudder and elevator push rods and horns and get this thing together.
Pete
Old Mar 09, 2012, 09:50 AM
pattypilot's Avatar
Joined Nov 2006
Wow! very, very Nice!
Old Mar 09, 2012, 02:46 PM
Gulf Breeze, FL
Joined Jul 2006
Had some time to work on this bird. .....
Lookin' good, Pete.
You may want to try rubbing some pastel chalk (gray/brown/green) over the crinkled front deck.
Gene K
Old Mar 09, 2012, 04:22 PM
mtflyr is offline
Centreville,VA,USA
Joined Apr 2001
I'll give that a try Gene but it's really not as bad as the closeup pic's make it look.
The hardest part of this so far is lining everything up by eye and mounting the P-51 motor to match the FZ fake motor and cowling.
Pete
Old Mar 10, 2012, 11:05 AM
mtflyr is offline
Centreville,VA,USA
Joined Apr 2001
Got it all together and ready to test fly today. Next add rigging, guns and pilot and lots of other details.
Glide tests are very good. weight WOB = 36 grs the pilot and guns will add another 2-3 grs. Not bad as my FZ P-51 motored Dr-I flys great at 38 grs.
This build would not have happened or look so good if it were not for Speedy01, Gene's awesome resizing of the E-Cards Dr-I paper plan, tissue covering of the 2mm Depron and wing baking of all wing sets. Thank you Gene.
I'm very happy the way this bird turned out and would recommend this type of build to folks who want to try something new.
Though the tissue may have added a tad more weight to this plane I feel the extra strength gained off sets the very minor weight gain.
Pete
Old Mar 11, 2012, 08:32 AM
mtflyr is offline
Centreville,VA,USA
Joined Apr 2001
Test flights outdoors yesterday and indoors last night revealed that the CG was off. I cut the fire wall bottom to move the battery forward.
I should have known to put the brick up into the cowling rather than behind the fire wall. So I have to redo it and the motor mount as I need to add additonal down thrust.
Considering those problems she flew pretty darn good but you had to be on it. I also had to adjust the wings to be sure they are all the same symmetrically.
Pete
Old Mar 11, 2012, 10:34 PM
WonkoTehSane is offline
Find More Posts by WonkoTehSane
Joined Jun 2011
Will these ever get made into kits??
This one looks absolutely fantastic!
WonkoTehSane is offline Find More Posts by WonkoTehSane
Old Mar 12, 2012, 07:01 AM
mtflyr is offline
Centreville,VA,USA
Joined Apr 2001
Well Wonko,
Technically it is a kit! It's an E-Card 1:48 scale paper model kit enlarged to 1:20th scale +- 14"WS, but no I couldn't do the great tissue covering my friend Speedy01did on this bird to make it look so good.
It is an easy conversion from paper to 2mm Depron with 1mm for the tail areas. I have a bunch of details yet to do another friend Jin is working on laser cut Spandau MG jackets for me.
Pete
Discussion Flyzone Micro Dr.1: Long 7mm Motor/Gearbox Upgrade Gordon Johnson Micro Ready-to-Fly 29 Dec 24, 2012 02:14 AM
Discussion scratch built micro Dr.1 - Richtofen's No. 152/17 dcwwcp Scratchbuilt Indoor and Micro Models 28 Mar 16, 2012 10:53 PM
Discussion Start of Micro Nieuport 17 mtflyr Scratchbuilt Indoor and Micro Models 77 Dec 23, 2011 11:07 AM
Discussion Micro, where to start? 3DFun Micro Cars 1 Dec 14, 2011 01:27 PM
