Here's something I found on the googles: http://henrycountyrc.com/blog/2009/1..._dynamics.html Rafa |
Canada, ON, Muskoka
Joined Jul 2011
Lay your antenna to the side, your laying the dounut on its side, much less sky is covered. Your narrowing the radiated signal. |
Canada, ON, Muskoka
Joined Jul 2011
Rafa, no problem. It's a point of contention with a few people at our field and they wonder why they sometimes seem to loose signal when the plane gets a bit far. Nothing wrong with their equipment, it's the way they position their antenna, and then get to the fringe of the signal. If they had it positioned properly they wouldn't have a issue.
And yes, if you flew over your head all the time then I suppose laying the antenna on it's side would work fine, kinda tough on the neck though.
Joined Aug 2012
Trim for Devo 10
First, newbee here, sorry. I'm a bit confused on using the trim system on the devo 10 with my Quadcopter (Turbo Ace X830-D Devo 10 TX, RX1002) There are 4 switches on the Devo 10 for trim. The top two show a vertical graph on the screen and can move up and down past the center point, the bottom two show horizontal graphs and can move right or left past the center point. Can someone explain how moving these will effect each engine and how I can use these to trim to cut down on drift when I'm trying to just hover? Thanks all!
Peter |
Joined Aug 2012
Devo 10 Soften Controls
Newbee here again. Turbo Ace X830-D Devo 10 TX, RX1002) There are 4 switches on the Devo 10 for trim. I'm finding that the throttle as well as pitch, rudder, and aileron controls are extremely sensitive, I'm getting into trouble because my fingers are still getting trained on the controls and for each movement I make, my quad bolts in the direction that I send it. Is there any way to soften these controls so that I can make greater movements on the sticks and get less reaction from the quad?
Thanks all, Peter |
Fly it again, and then modify above values to suit your taste. Don't play with the trims (controllers like Naza don't like trims). I don't have one but I recall there is special software for configuring the controller. The quad drifting might be the effect of your inputs if you're a newbie. Edit: I found some reports saying that Naza natively drifts a bit to the right. Is yours the same? |
Joined Aug 2012
Thanks for your response and the heads up about the NAZA. I have decided to practice with my Ladybird and Devo 10 to get used to the flight controls. The Ladybird drifts but I'm not sure how to trim it, or if I can.
I'll take a look at the method for softening the controls that you mentioned. Do you have any specifics on how I get into the D/Rs for ELE and AIL on my Devo 10, I'll search for it myself as well. Again, thanks for writing. |
I think LB can be trimmed using the trim switches around the right stick for ELE/AIL (if you fly mode 2) and under left stick for RUDDER. So if your LB drift right, use the switch under the right stick and nudge a 2-3 notches to the left until she no longer drifts. (mode 2 is when you have throttle and rudder on left stick, ele/ail on right stick). But, don't use trims on the NAZA controller. It's probably safe to use subtrim, but you are not there yet. I recommend reading around these forums as much as you can, you need to have good command of your transmitter and you should become familiar with the lingo used around here too. BTW you'll find here a quadcopters section too, a lot of good information there. |
I recently started using a Devo 10 with a custom built quadcopter using a KK2 Flight Controller. Everything seemed fine for a couple months until (long story short) a couple of nights ago my quad seemed to freak out and took off, flew a few blocks and eventually after battling and trying to recover it disappeared into the snow somewhere. I'm not sure if it was pilot error, a technical issue or something went wrong with the hardware itself.
So now I'm looking at replacing the quad (and investing in some sort of locator) but also trying to plan what to do about the TX/RX. I think I need to flash the firmware to 100mw + mount the antennae wires differently this time. Maybe one vertical and one horizontal since the quad is used for acrobatics as well as some short-distance LOS flying? I was wondering if it's best to get another RX1002 (I actually only need 5ch for this setup) or if I should look at another RX? I'm searching and trying to find out what RX's are compatible with the Devo10 as I'd love to add telemetry or GPS locating etc. - I just don't know how that all works as I haven't tried it before. So any suggestions on the RX or links to a compatability list etc.? Thanks! |
I got my Devo 10 this afternoon. If you want to look at a receiver other than Devo then check out Deviation. It's a firmware update to allow Devo TX's to work with non-devos and non-Walkeras. I just installed it and tonight's project is to get it working with my V120D02S old Walkera receiver. |
The quad was an Armattan M370 (370mm shaft to shaft) custom build. I'm not sure what class that is but I would guess it's in the 300 range?I forgot about the firmware! I think I downloaded it and figured I didn't need it yet. Thanks for the reminder. So now I just need to figure out if the Devention RX1002 (or similar) RX like I had is good or if there is something else better suited. Now the choices have grown! |
| Thread Tools | |
| Discussion Walkera New Devention Devo 12 transmitter first impression: | ehirobo | Radios | 460 | Jun 13, 2013 01:25 AM |
| Discussion Walkera devo reciever question? | autowarrior | Beginner Training Area (Heli-Electric) | 0 | Feb 28, 2012 11:58 PM |
| For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale | Tom Z | Aircraft - General - Radio Equipment (FS/W) | 0 | Oct 06, 2011 12:33 PM |
| For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale | Tom Z | Aircraft - Electric - Helis (FS/W) | 0 | Oct 05, 2011 11:38 AM |
| Discussion Walkera Devo 12 (11X clone) Nuremberg 2011 | Mikarro | Radios | 7 | May 13, 2011 10:28 AM |
