Old Oct 07, 2012, 10:28 AM
Tom Z is offline
Find More Posts by Tom Z
RC Reviews & Tx Setup Guides
Tom Z's Avatar
United States
Joined Sep 2007
Originally Posted by jastt View Post
my new devo 10 is turning out to be a piece of junk..i new i should of bought spektrum. it works with phoenix rc but thats about it, my esc won't recognize the throttle stick but my servo tester has no problems, and now Dfuse tools won't recognize the tx because walkera usb driver sucks.
You must manually install the USB driver.
The DfuSe USB Upgrade software also contains the driver.
The driver files are located in the “Driver” folder in your installed path
(C:\Program files\devention Upgrade Tools).
In the DfuSe USB Upgrade user manual v1.4 see the section
"6.2 Hardware installation section" on page 11/20.
This will show you how to load the driver so you can do the update.
http://www.rcgroups.com/forums/showp...1&postcount=31
Tom
Tom Z is offline Find More Posts by Tom Z
Old Oct 07, 2012, 10:38 AM
jastt is offline
Find More Posts by jastt
Joined Oct 2012
thanks for quick reply, the usb cable was not all the way in the tx i had to force it in like something was going break.
jastt is offline Find More Posts by jastt
Old Oct 07, 2012, 10:40 AM
Tom Z is offline
Tom Z's Avatar
United States
Joined Sep 2007
Your welcome. I'm glad you got it working.
Tom
Old Oct 07, 2012, 10:45 AM
jastt is offline
Joined Oct 2012
any idea's why my tx throttle isn't recognizing a 40a turnigy plush esc, iv'e tried everything even rollback tx to older software, ive tried doing this,
deactivate throttle hold
end points to max
reverse servo
created new model name
connect battery at 100% and 0% throttle
i get the 3 beeps when connect battery and thats it.
Old Oct 07, 2012, 11:31 AM
jastt is offline
Joined Oct 2012
i also have fixed id enabled, so tx on then rx.
Old Oct 07, 2012, 11:58 AM
livonia bob is offline
Find More Posts by livonia bob
Heli collector
livonia bob's Avatar
United States, MI, Livonia
Joined Apr 2009
You have to pull the rubber flap out of the way other wise it stops the cable from going in all the way.. I had this problem also till I figured out that the flap can be pulled out a hair more and it then doesn't interfere.
Open flap than pull gently on it and you will feel it come out a little more and clear the hole for the plug..
livonia bob is offline Find More Posts by livonia bob
Old Oct 07, 2012, 12:23 PM
jastt is offline
Joined Oct 2012
i was aware off the rubber usb cover and there was no binding on it when plugging in, there was alot of plastic creaking when it did go in.
Old Oct 07, 2012, 01:31 PM
Tom Z is offline
Tom Z's Avatar
United States
Joined Sep 2007
end points to max
reverse servo
I am not sure. What receiver are you using?
Tom
Old Oct 07, 2012, 02:09 PM
pmerritt is online now
Find More Posts by pmerritt
Joined Oct 2010
yeah, knowing which receiver would help....also you could try setting your throttle travels a little higher on either end. Oh yeah, go to the channel monitor screen and make sure you are getting proper throttle range. **Make sure it's linear**
Also, the Devo10 is really good...once you get things sorted out you're going to be quite happy with your purchase.
pmerritt is online now Find More Posts by pmerritt
Old Oct 07, 2012, 08:59 PM
jastt is offline
Joined Oct 2012
using rx1002 and it has binded as the blue light is not flashing, i did check monitor screen and at 100% it travels to its correct position, then i set travel adjustment to 150% and it reaches full end travel, also all 4 servo's work when connected.
the first new devo 10 i received from hobbyhot had a broken gear switch as the tx was only covered in bubble wrap, they did pay for return postage. the second one i received from myrchobby the right stick got stuck after 20min use..it was fixed by taking back cover off to free up the binding, so that has added to the frustration.
with the servo tester its working good with esc+motor+rx, but when the rx is connected to tx i just get 3 beeps when battery connected.
Old Oct 08, 2012, 12:15 AM
jastt is offline
Joined Oct 2012
i have a good idea what the problem is, but won't know till later on.
Old Oct 08, 2012, 03:19 AM
jastt is offline
Joined Oct 2012
problem solved it was wrong plug placement, devo 10 is good.
Old Oct 11, 2012, 08:11 AM
jastt is offline
Joined Oct 2012
when i plug in a gy650 gyro into a rx1002/devo 10 the rx doesn't bind with the tx, but when i take out the gyro's channel/gain leads it binds...any ideas
Old Oct 11, 2012, 08:48 AM
jastt is offline
Joined Oct 2012
all good, it was a setting with tx.
Old Oct 12, 2012, 07:55 AM
RotaryC is offline
Find More Posts by RotaryC
United Kingdom
Joined Sep 2011
Hi,
I have a 3 cell lipo on my TX, and I can't seem to get the lipo alarm to go above 10v, should be 11.1 min really, is there anyway to alter this on the Devo 10?
RotaryC is offline Find More Posts by RotaryC
Discussion Walkera New Devention Devo 12 transmitter first impression: ehirobo Radios 549 Dec 18, 2014 02:53 AM
Discussion Walkera Devo 12 (11X clone) Nuremberg 2011 Mikarro Radios 8 Aug 25, 2013 09:22 PM
Discussion Walkera devo reciever question? autowarrior Beginner Training Area (Heli-Electric) 0 Feb 29, 2012 12:58 AM
For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale Tom Z Aircraft - General - Radio Equipment (FS/W) 0 Oct 06, 2011 01:33 PM
For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale Tom Z Aircraft - Electric - Helis (FS/W) 0 Oct 05, 2011 12:38 PM
