Old Mar 02, 2012, 03:40 PM
FDR_ is offline
Find More Posts by FDR_
Joined May 2011
New Product
Walkera DEVO 10
Another new Walkera Devention Tx:
http://www.devention.com:82/en1/part...jsp?pn=DEVO_10
http://www.walkera.com/en/showgoods.php?id=449
Now that's really like the old WK-2801 Pro, only plus 2 channels...
FDR_ is offline Find More Posts by FDR_
Old Mar 02, 2012, 04:34 PM
Hellraser is offline
Find More Posts by Hellraser
Hellraser's Avatar
UK
Joined Jul 2007
http://www.walkera.com/en1/particular.jsp?pn=DEVO_10
From the single picture the screen certainly seems more like the 2801 than the devo 7 - could really do with more screen shots to confirm that its the same all the way through - for instance is the definition of the screen high enough to allow graphs for the pitch and throttle curve screens ?
Also looks to have a USB port which is another improvement on the devo 7
Regards David
Hellraser is offline Find More Posts by Hellraser
Old Mar 02, 2012, 06:54 PM
KKDDMM is offline
Find More Posts by KKDDMM
I love MOD! & WALKERA & V911!
KKDDMM's Avatar
China, Guangdong, Shenzhen
Joined Jan 2012
I will buy this TX!
http://www.walkera.com/cn1/devo10/devo_10_index.html
KKDDMM is offline Find More Posts by KKDDMM
Old Mar 02, 2012, 08:00 PM
mescalinedream is offline
Find More Posts by mescalinedream
Joined Jul 2008
maybe somehow someone could take the software from the devo 10 and put it into the devo 7
mescalinedream is offline Find More Posts by mescalinedream
Old Mar 02, 2012, 09:52 PM
itsmillertime is online now
Find More Posts by itsmillertime
United States, TN, Memphis
Joined Dec 2011
Originally Posted by KKDDMM View Post
Ah man, my google seems to be broken and wouldn't translate that for me...
itsmillertime is online now Find More Posts by itsmillertime
Old Mar 03, 2012, 01:48 AM
FDR_ is offline
Joined May 2011
For what purpuse?
The hardware is quite different...
Old Mar 03, 2012, 05:19 AM
Atomic Skull is offline
Find More Posts by Atomic Skull
Atomic Skull's Avatar
Joined Dec 2011
You'd need to replace the screen too.
The RX801 is now less than $30. Now Walkera just needs to put out a line of (not with 3 axis gyros) micro receivers for Devo transmitters.
For what purpuse?
The Devo radios are all built around STMicroelectronics ARM Cortex9 based microcomputers so the hardware is actually very similar. That's why they can be sold so cheaply, Walkera didn't design anything custom for these radios they just put them together with off the shelf components. All of the R&D work was already done for them, even the OS used by the radio (it's the same OS used in other STMicro based mobile devices such as pocket oscilloscopes). The days where you had to design custom ASICs to build something like this ended several years ago. There's really no advantage to it anymore when off the shelf technology can do the same thing just as well and at a fraction of the price.
Atomic Skull is offline Find More Posts by Atomic Skull
Old Mar 03, 2012, 06:45 AM
pmcbs is offline
Find More Posts by pmcbs
Joined Sep 2003
I have noticed that the devo 7 is being sold dirt cheap. Is this the low end replacement?
pmcbs is offline Find More Posts by pmcbs
Old Mar 03, 2012, 03:31 PM
FDR_ is offline
Joined May 2011
For what purpuse?
I have ment the display, the USB port, the plus potis and perhaps some switches too.
How do you mean "off the shelf"? I know the use ST ARM controllers, but it would only mean that every computer is "off the shelf".
Can you ellaborate more on the hardware and software of DEVO's please!
I have started to look into the firmwares and the libraries. (I wrote a little program to create or edit the dfu files.) The goal: I want to change (dismiss) the on/off tunes (beacause they are quite annoying! ), and replace the background of the edited values to increase the visibility.
It would only need editing of the library without disassambling the firmware...
Old Mar 03, 2012, 07:21 PM
pmerritt is online now
Find More Posts by pmerritt
Joined Oct 2010
I was going to get the Devo12S but if this has basically the same screen as the 2801pro I will be getting this.....for a fraction of the cost and most of the features of the Devo12 this is a no brainer for me. If it ends up being like the Devo7 then I may just bite the bullet on the 12S
pmerritt is online now Find More Posts by pmerritt
Old Mar 03, 2012, 09:37 PM
benmlee is offline
Find More Posts by benmlee
Los Angeles
Joined Oct 2006
A DEVO series with 2801 interface would be nice. I actually like the 2801 interface. Is faster than the DEVO 6. Less clicks to get to the correct page. For example, setting pitch or throttle, you have to go thru a drop down menu to pick a stick position before setting a pitch point. That is a waste of time. 2801 you just set one, then go to the next point with one press of the button. Buttons give you good feedback, so you can go faster.
Now if they make one size of DEVO 6 and 2801 interface, that would be the best.
benmlee is offline Find More Posts by benmlee
Old Mar 05, 2012, 02:59 AM
Joined Dec 2011
http://9xforums.com/forum/viewtopic.php?f=5&t=362
Apparently they use the same CYRF6936 chip in their transmitter moduel as the WK2801. So Walkera was lying when they said it was impossible to add WK2801 compatibility. Apparently the chip is under direct control of the motherboard and could do WK2801 or even DSM2 with nothing more than a firmware update.
Old Mar 05, 2012, 04:37 AM
bytemuncher is offline
Find More Posts by bytemuncher
Tokyo
Joined Jan 2010
Depending on price and reviews I may get this as a backup radio. I like the screen on the devo 6 as well as some of the features (telemetry, etc.), but I agree with benmlee there are some extra steps involved in order to set some things.
bytemuncher is offline Find More Posts by bytemuncher
Old Mar 05, 2012, 05:57 AM
Joined Dec 2011
It's selling for $140 with receiver.
Discussion Walkera New Devention Devo 12 transmitter first impression: ehirobo Radios 549 Dec 18, 2014 01:53 AM
Discussion Walkera Devo 12 (11X clone) Nuremberg 2011 Mikarro Radios 8 Aug 25, 2013 08:22 PM
Discussion Walkera devo reciever question? autowarrior Beginner Training Area (Heli-Electric) 0 Feb 28, 2012 11:58 PM
For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale Tom Z Aircraft - General - Radio Equipment (FS/W) 0 Oct 06, 2011 12:33 PM
For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale Tom Z Aircraft - Electric - Helis (FS/W) 0 Oct 05, 2011 11:38 AM
