Old Mar 02, 2012, 02:51 PM
insutama is offline
Find More Posts by insutama
Joined Aug 2006
Charging my first lipo battery with my new charger
I just bought a hz super cub now i am about to charge the battery on my venom charger I'm just wondering do i charge the battery through the balance charger hook up on battery or the actually power lead ? also does anyone know if i should charge my battery before i fly it or does it come charged already ?
insutama is offline Find More Posts by insutama
Old Mar 02, 2012, 03:14 PM
startazz is offline
Find More Posts by startazz
RC plane addict ;-)
startazz's Avatar
United Kingdom, England, Norwich
Joined Aug 2008
I haven't got a venom charger so i can't comment on your charger but i do have a charger that has a plug for the power lead and the balance lead,and that one i use both to make sure i get a good balanced charge.
I also have another charger that just uses the balance lead to charge the battery,but the charger you have should explain what you should do in the manual,try to do a google search if you don't have one it will help out loads.
You will need to charge your new battery as they come to use in storage (partly charged) mode so it will need charging mate,all of my hobbyking batteries i use are never charged to the max when i buy them so i have to charge them and i'd be a bit upset if i didn't have too.
Just think if we brought Lipo batteries fully charged,there life span wouldn't be up to much as we wouldn't know how long they have been sitting on the factory/shop shelf for would we.
I hope this has helped a little but like i said read your lipo charger manual if not look for a manual online because i bet you will be able to find it and it will be a lot safer if you read it through and your batteries will benefit from it too because you will be able to charge them at the right voltage and so on.
startazz is offline Find More Posts by startazz
Old Mar 02, 2012, 05:42 PM
insutama is offline
Joined Aug 2006
great thanks for your help its seems i have to use both the balance and the power lead
Old Mar 02, 2012, 11:17 PM
midnite is offline
Find More Posts by midnite
Joined Feb 2012
I might have the same charger. You do have to plug in both power and balance leads.
Be sure to set the charge rate correctly for the battery you're using as well as the battery type.
Batteries are sold with the proper storage charge of approx 3.8 v per cell. They do need to be fully charged before use. Full charge is 4.2 per cell.
If you don't intend to use the battery the same day or the next perhaps, then use the charger to set it at a storage level. Don't leave a battery in a fully charged state and be careful to not over discharge it. It should be no less than about 3.4 volts per cell after use and preferably higher.
midnite is offline Find More Posts by midnite
Old Mar 03, 2012, 04:03 PM
insutama is offline
Joined Aug 2006
Thanks alot that really helped alot
Old Oct 16, 2013, 03:36 PM
moxieman3864 is offline
Find More Posts by moxieman3864
moxieman3864's Avatar
Joined Aug 2013
do you need to discharge brand new batt before charging it and do you need to discharge lipo batt be fore every charge?
moxieman3864 is offline Find More Posts by moxieman3864
Old Oct 16, 2013, 03:51 PM
Rhea is offline
Find More Posts by Rhea
Registered with FAA since 2016
Rhea's Avatar
United States, MN, Eden Prairie
Joined Oct 2008
No and no
The battery should be charged before you use it and using it will be the only discharge you will have to do. That said, you will want to store it in the “Storage” voltage, which is between 3.7 to 3.85 volts per cell. Since that is what it is likely to be after use it’s done.
Rhea is offline Find More Posts by Rhea
Old Oct 16, 2013, 08:24 PM
ggcrandall1 is offline
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
moxieman3864 and insutama
May I suggest you read this. It is a good place for basic information on the care and feeding of LiPo's.
https://sites.google.com/site/tjingu...arging-how-tos
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Discussion Lipo charging help needed, plugged in battery and charger blew and stopped working jasper7821 Batteries and Chargers 31 May 18, 2012 01:35 AM
Sold New Electrifly 11.1 V Lipo balancing smart charger with battery propflipper Aircraft - Electric - Batteries & Chargers (FS/W) 0 Feb 21, 2012 01:01 PM
Discussion Battery charging with car supplied wall wart charger kevmeist Car Talk 0 Jan 27, 2012 03:07 PM
Discussion Charging LiPo on charger with only lilo setting orectolobus Batteries and Chargers 1 Jan 10, 2012 03:57 PM
Question Charging and balancing Lipo in series with Hyperion charger 9joker6 Batteries and Chargers 9 Sep 24, 2011 09:14 AM
