Old Mar 02, 2012, 01:50 PM
helimor is offline
Find More Posts by helimor
Joined Mar 2012
Zhengrun Z 008 just spins, lower blades haven't got any real power
Hi Guys, First post and new too, be kind. My Z doesn't fly. It just spins ccw while the top blades spin cw. I can stall the lower blades while top blades continue to spin. Looking at the lower balde gear and its main gear I can see that even the motor shaft isn't turning. Holding the lower blades doesn't seem to stall the heli in any way. The lower blades have very little torque. Also, one of the little dog nuts was broken that locks the fly bar to the drive shaft. I've replaced the whole unit that sits atop the driveshaft. Please help with your ideas. Its a good little heli that needs new life. Your friend in flight, Helimor
helimor is offline Find More Posts by helimor
Old Sep 24, 2012, 01:22 PM
Zakinjo is offline
Find More Posts by Zakinjo
RC SHOP owner
Joined Sep 2012
For Z008 and P301 sometimes little black gear attached to rear motor is not in place. It should be turning bigger (main) gear. Maybe it is 1mm lower than it should be, or maybe it came off and now lies somewhere on the carpet. Pick it up, and put it back in the place.
In worst case scenario: you need to replace rear main motor (green)
Zakinjo is offline Find More Posts by Zakinjo
Help! i just got my fpv stuff and i can't figure out how to: flohio117 FPV Talk 10 Mar 02, 2012 02:15 PM
Discussion Just got my first proper iron! any tips? ipjodan The Builders Workshop 16 Oct 26, 2011 09:26 AM
Discussion Picoo Z just spins in circles Ripro Micro Helis 5 Jun 12, 2007 05:08 PM
Help! Top blade just spins and spins... won't stop NateO BladeRunner Heli 8 Feb 10, 2007 09:38 PM
