![]() From this image for fuselage sections I pulled off the web; ![]() Note that the fuselage cross sections are more or less rectangular with only a little curving at the corners. This would lend itself to a "stick build" similar to the old gas powered old timers very nicely. Then some small upper and lower formers with a few stringers to get the rounded corners and wind screen areas and you'd be away. Similarly using light techniques for the wing surfaces would produce a light structure. With this methodology I don't see any issues at all at producing what could well be a sub 4 lb model. At that weight the .25 would fly it in great form with a good but not "jet like" climb and generally nice "light plane" like flying charactaristics. It would be a model which would be at its best on moderate wind to calm days. At least until you get to know it's strong and weak points. But I don't see it being a "fun" strong wind day model by any stretch. And when you consider that from my quick calculations a 60 inch span version of the Mig 8 would have a cross section under the wing of roughly 8.5 x 6 inches you REALLY want to build up the fusleage with something light. And the old timer style of sticks would be the way to go IMHO. Note that this does not mean that the model would be fragile. With the proper wood grades and use of diagonal uprights that form a Warren truss like structure similar to seen on heavy lift cranes a stick built structure can achieve high levels of strength and rigidity with surprisingly little material. Yes it's a little more work and fuss to build but when done you'd be rewarded with a great flying model. Quote:
Due to the distance away from the CG the fore plane is the better spot to place the elevators. By fortunate happenstance the downward deflection for "up elevator" acts to increase the camber of the foreplane making it a little less prone to stalling from the added lift. So all in all I'd suggest you stick with "the plan" and use the foreplane flaps for the elevator function as per the original. And CURSE YOU! From looking at the Mig 8 3 view plan attached I'm getting the urge to open up my CAD program and start tracing over the image .....
USA, NH, Manchester
Joined May 2010
Hmm, you might be right about those being the trim tabs. I thought I read something about them being flaps, but looking at the drawing it does seem like they would be too small for flaps and likely trim tabs.
| Thread Tools | |
| Wanted klingberg wing rib patterns | dbrimm | Aircraft - Sailplanes (FS/W) | 1 | Feb 21, 2012 05:51 PM |
| Build Log EPP 3D wing rib 40.5" WS with Plan | Jhon-Jhon | Foamies (Scratchbuilt) | 5 | Nov 28, 2011 06:23 PM |
| Discussion Wing Rib Spar Material | Rob_P | Vintage & Old-Timer Designs | 6 | Sep 14, 2011 11:17 AM |
| Help! 60" Bolt on wing,Root rib arrangement on a bagged wing? | avago | Slope | 4 | Mar 29, 2007 06:09 PM |
| Freeflight conversion rib shape ? | Feodosia Flyer | Parkflyers | 3 | Jan 22, 2003 06:49 PM |
