Old Jun 19, 2012, 04:10 PM
flyandi is offline
Find More Posts by flyandi
United States, CA, Aliso Viejo
Joined Aug 2009
flyandi is offline Find More Posts by flyandi
Old Jun 19, 2012, 06:33 PM
shahram72 is offline
Find More Posts by shahram72
United States, SC, Irmo
Joined Sep 2011
I'm now waiting for a Multiplex Funcopter and then I'll order again.
shahram72 is offline Find More Posts by shahram72
Old Jun 19, 2012, 07:59 PM
Left Coast DJ is offline
Find More Posts by Left Coast DJ
Left Coast DJ's Avatar
Joined Jan 2012
+1
And the Funjet too.
Left Coast DJ is offline Find More Posts by Left Coast DJ
Old Jun 20, 2012, 11:50 AM
radio freak is offline
Find More Posts by radio freak
United States, NJ
Joined Dec 2006
Looks like he will be selling electronics too...
http://www.ebay.com/sch/gooddayrc/m....&_trksid=p3686
radio freak is offline Find More Posts by radio freak
Old Jun 20, 2012, 03:50 PM
flyinwalenda is offline
Find More Posts by flyinwalenda
EIEIEIO Classic is dway ta go!
flyinwalenda's Avatar
Northeast Pa. .Heyna or No?
Joined Aug 2009
I've seen in the past they have sold servos, rx's , motors, etc...
flyinwalenda is offline Find More Posts by flyinwalenda
Old Jun 24, 2012, 05:15 AM
shot151 is offline
Find More Posts by shot151
United States, OR, Salem
Joined Feb 2012
Another batch of Easycubs RR, and some new stuff as well, LiPo Battery Balancer, Himax 2815-3100 motors.
shot151 is offline Find More Posts by shot151
Old Jun 24, 2012, 12:04 PM
Bombay is offline
Find More Posts by Bombay
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
is that a great deal on the HiMax motor?
Himax Brushless Motor - 2815-3100
Bombay is offline Find More Posts by Bombay
Old Jun 24, 2012, 06:21 PM
Joined Aug 2009
No, a great deal would be $5.00 but it's a good deal. I got one. HiMax are pretty good motors.
Old Jun 30, 2012, 08:31 PM
Hot_Wheels is online now
Find More Posts by Hot_Wheels
United States, IL, Carol Stream
Joined Nov 2009
i got my fun cub today, its alot bigger then i thought! i want to know if i can run a 3s with the stock brushless set up? in the directions they recommend a 2s 1800mah with the supplied prop, so do i just need to change the prop? i have a 30 amp esc i was thinking of throwing in it just cause it already has a xt60 connector and is much bigger.
Hot_Wheels is online now Find More Posts by Hot_Wheels
Old Jun 30, 2012, 08:41 PM
Bugman Jeff is offline
Find More Posts by Bugman Jeff
I'm a Registered User
Evansville, WI
Joined Dec 2006
I'm running a 3S 2250 with a GWS ep-9050 prop on an otherwise stock EasyCub. I'm easily getting 15-20 minute flights, with lots of battery left to spare.
Bugman Jeff is offline Find More Posts by Bugman Jeff
Old Jun 30, 2012, 09:50 PM
waynemia is offline
Find More Posts by waynemia
A trail of smoke is GOOD!
waynemia's Avatar
USA, TX, Springtown
Joined May 2008
You should use the ESC that comes in the power set. The FunCub is not an EasyCub. The FunCub you should run on 3S, 2200mAh pack. Item 19 in the manual. If you are talking about an EasyCub, I don't have a clue.
waynemia is offline Find More Posts by waynemia
Old Jul 01, 2012, 06:04 AM
Joined Aug 2009
The easy cub is a fun cub or vice-versa with a different wing. The easy cub typically uses a 200w motor on 3 cells and the fun cub typically uses a 300-400w motor on 3 cells.
Old Jul 01, 2012, 08:32 AM
jcstalls is offline
Find More Posts by jcstalls
Dragons, WindMills, all Same
jcstalls's Avatar
United States, IN, Indianapolis
Joined May 2002
So what are the major differences between the Fun and Easy?
Would this Easy Cub with a flatened wing and set up full house be just about the same?
jcstalls is offline Find More Posts by jcstalls
Old Jul 01, 2012, 09:11 AM
Evansville, WI
Joined Dec 2006
The Fun comes with a bigger motor and flat aileron wing, I think the Fun might have bigger "tundra" type wheels on it too. Using the Easy with a modded wing would probably feel just like the Fun. With 3S and a smaller prop on my stock Easy, it's got more than enough power and unlimited vertical( after all, it's a Cub, not a pylon racer ).
Old Jul 01, 2012, 10:47 AM
Joined Aug 2009
The most difficult part is to remove the dihedral from the wing(especially if you want to keep it a two-piece). I wanted to buy the nylon wing joiner for the fun cub but it is part of a $30.00 plastic set so I just cut the old one. After that it's just cutting out the ailerons and flaps, mounting the servos, installing a larger motor and wheels.
Discussion What better EDF for Multiplex Twister ? zaguruinzasky Electric Ducted Fan Jet Talk 2 Mar 18, 2012 05:02 AM
Off Site Multiplex Twister for $50 + $6 shipping on Ebay,, 13 hours left 8ballfever Aircraft - Electric - Jets (FS/W) 1 Feb 25, 2012 12:45 AM
For Sale NEW!!! Multiplex MiniMag RTF (99% Pre-assembled) M13209 w/PC Flight Simulator-$139.00 Van Leuven Aircraft - Electric - Airplanes (FS/W) 0 Feb 20, 2012 03:01 PM
For Sale Multiplex MiniMag, RR with Esskay Brushless Butch777 Aircraft - Electric - Airplanes (FS/W) 0 Jul 21, 2008 09:04 PM
For Sale Multiplex Minimag RR + Custom Wood Case (Bay Area) Spamurai Aircraft - Electric - Airplanes (FS/W) 0 Jan 13, 2008 10:35 PM
