Old Mar 23, 2012, 06:26 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
twisters are back up for those that miss the last time
http://www.ebay.com/itm/Multiplex-Tw...#ht_500wt_1415
3drcparts is offline Find More Posts by 3drcparts
Old Mar 23, 2012, 06:58 PM
porcia83 is offline
Find More Posts by porcia83
United States, CT, Hartford
Joined Jun 2009
Originally Posted by shahram72 View Post
Got my twister. The box had no damage, but the corner of the elevator and slightly on the corner of one wing is dented. Can this be fixed? I heard if you apply heat with a hairdryer it can be done. It's a shame he could not outer box it, although I did not see any crushing on the box. I also have another Multiplex model I got in a trade that has similar dents and is made of the same foam so I hope this can be fixed. The foam beads are slightly separated at the outside of the bend. Can a tiny bit of CA be used there while I bend it back? Still, very minor damage compared to what others have experienced. Here's a pic of my damage.
I'd bend it back my hand, or put it in very hot water for a minute, then work it!
porcia83 is offline Find More Posts by porcia83
Reply With Quote  (Disabled)
Old Mar 23, 2012, 07:01 PM
porcia83 is offline
Joined Jun 2009
Two left....I went for another !
Old Mar 23, 2012, 07:26 PM
kw5368 is offline
Find More Posts by kw5368
United States, WV, Beverly
Joined Mar 2004
He has 29 left now. He added another 30.
Ken
kw5368 is offline Find More Posts by kw5368
Old Mar 23, 2012, 08:52 PM
flyinwalenda is offline
Find More Posts by flyinwalenda
EIEIEIO Classic is dway ta go!
flyinwalenda's Avatar
Northeast Pa. .Heyna or No?
Joined Aug 2009
Originally Posted by Krash n Burn View Post
I got my Easy Cub.... Good news it does have the cut outs for flaps and ailerons, but not for servos. I think it was reported earlier in this stream that it didn't.
It also looks like you can take the dihederal out if you modify the center plastic mounting brace. I am going to try and drill it out and run a straight carbon fiber rod through it. I will report back.
I didn't get mine in yet but I may do it to one of them. Not sure exactly how the wings join but I might try cutting the center plastic "saddle" section in the middle and gluing it back together with no dihedral. Will have to glass that center section too and maybe insert a cf spar. Would be nice to keep it a two piece wing. Will just have to wait until I see it.
The wing servos cavities will have to be routed out and the servos mounted on their sides. With a little work this should make a very nice cub. If the wing is going to be straightened it could also be made into a clipped wing cub!
flyinwalenda is offline Find More Posts by flyinwalenda
Old Mar 23, 2012, 09:31 PM
interplanet is offline
Find More Posts by interplanet
interplanet's Avatar
Sheboygan Falls, WI
Joined Nov 2006
I you should be able to incorperate the flap hardware from the funcub, its a bummer they dont sell single parts though, only parts sets. I dont know if you could get the same thing from another place.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXZWM2
interplanet is offline Find More Posts by interplanet
Old Mar 23, 2012, 09:37 PM
Joined Aug 2009
You could accomplish, almost, that same scale flap set-up using hinge point hinges along with the sockets.
Old Mar 23, 2012, 09:53 PM
Sheboygan Falls, WI
Joined Nov 2006
what sockets are you referring to? the thing I like about the multiplex hinges is that they himg a good deal below the wing, offering separation of the flap from the wing.
Old Mar 23, 2012, 09:59 PM
Sheboygan Falls, WI
Joined Nov 2006
I just found a good source for flap hinges
http://www.iflytailies.com/store/win...s/flap-hinges/
Old Mar 23, 2012, 10:37 PM
Bugman Jeff is offline
Find More Posts by Bugman Jeff
I'm a Registered User
Evansville, WI
Joined Dec 2006
What's the advantage to having the flap separate from the wing instead of being hinged like a standard control surface? Just curious.
Bugman Jeff is offline Find More Posts by Bugman Jeff
Old Mar 23, 2012, 10:52 PM
Joined Aug 2009
Pockets actually(I call them sockets), along with the hinge point hinges set at the scale angle to give full 90 degree deflection. Similar to the hinges on a Stuka.
http://www.robart.com/store/control-hinges?page=1
Old Mar 23, 2012, 10:54 PM
Sheboygan Falls, WI
Joined Nov 2006
I really don't know, I just like how they look. Also you can get a full 90 degree throw without any bind.
Old Mar 23, 2012, 11:01 PM
Sheboygan Falls, WI
Joined Nov 2006
uggg, just went to purchase two sets, I cannot force myself to buy them when shipping is more than the parts
Old Mar 23, 2012, 11:12 PM
saltydog56 is offline
Find More Posts by saltydog56
William from Windham NH USA
saltydog56's Avatar
United States, NH, Windham
Joined Apr 2005
flap hinges
Greetings
Is there a part # for the fun cub that includes the hinges and control horns to set up the flaps?
Thanks Will
saltydog56 is offline Find More Posts by saltydog56
Old Mar 23, 2012, 11:14 PM
Sheboygan Falls, WI
Joined Nov 2006
well this might be a slick way to set up flaps,
these come in a 6 pack,
http://www.gravesrc.com/SONICTRONICS...E_p/sot130.htm
then these are the same hinges but have the control horn built in, comes in a 2 pack
http://www.gravesrc.com/SONICTRONICS...L_p/sot131.htm
Discussion What better EDF for Multiplex Twister ? zaguruinzasky Electric Ducted Fan Jet Talk 2 Mar 18, 2012 06:02 AM
Off Site Multiplex Twister for $50 + $6 shipping on Ebay,, 13 hours left 8ballfever Aircraft - Electric - Jets (FS/W) 1 Feb 25, 2012 01:45 AM
For Sale NEW!!! Multiplex MiniMag RTF (99% Pre-assembled) M13209 w/PC Flight Simulator-$139.00 Van Leuven Aircraft - Electric - Airplanes (FS/W) 0 Feb 20, 2012 04:01 PM
For Sale Multiplex MiniMag, RR with Esskay Brushless Butch777 Aircraft - Electric - Airplanes (FS/W) 0 Jul 21, 2008 10:04 PM
For Sale Multiplex Minimag RR + Custom Wood Case (Bay Area) Spamurai Aircraft - Electric - Airplanes (FS/W) 0 Jan 13, 2008 11:35 PM
