Old Mar 02, 2012, 10:26 AM
pilot_keeter is offline
Find More Posts by pilot_keeter
pilot_keeter's Avatar
United States, GA, Atlanta
Joined Nov 2008
Help!
Is my canopy done for? :(
Hey there,
I was working on this edge 540 last night that I bought from HK a while back. After gluing some parts I noticed that I accidentally got a couple drops of CA on the canopy.
Like the RC world's biggest dumb ass I (without thinking) took some CA remover to the spots and now have this fogged mess that seems up-fixable. I've heard of people using some type of Pledge floor polish to fix it, but I'm doubtful on this one.
No replacement parts exist and I'm at a loss. Does anyone know a solution or maybe some way to make a new copy of the canopy. If anyone knows someone that can do that I'd be willing to pay for a close-to-exact copy of the canopy!!!
I've probably screwed this one beyond repair
Any help would be great
Thanks guys!
pilot_keeter is offline Find More Posts by pilot_keeter
Old Mar 02, 2012, 10:31 AM
Joined Nov 2008
Here's the canopy:
png image hosting
Old Mar 02, 2012, 11:58 AM
fmw is offline
fmw
Find More Posts by fmw
fmw
fmw's Avatar
Joined Jul 2009
Why not just spray paint the inside of it a nice gray color?
fmw is offline Find More Posts by fmw
Old Mar 02, 2012, 12:04 PM
Joined Nov 2008
Yeah, that's probably my best option
Old Mar 02, 2012, 12:25 PM
warhead_71 is offline
Find More Posts by warhead_71
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
Spray-paint on the inside will still show the CA. Have you tried using straight Nitro? It should remove the CA without melting the plastic. I have also read that WD-40 works at removing "fog". Otherwise sand it out with 600-grit to 1000-grit then use the floor wax as a finish.
warhead_71 is offline Find More Posts by warhead_71
Old Mar 02, 2012, 12:27 PM
Joined Nov 2008
I have not, where can I get straight nitro? Like nirto fuel?
Old Mar 02, 2012, 12:31 PM
Joined Nov 2008
When I mistakenly used the CA remover I believe it thinned out the CA that was on the canopy. This made the the situation worse and hopefully there's something that can help.
Old Mar 02, 2012, 12:35 PM
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
Yes - nitro fuel. Do a tiny test area first. Maybe someone at your flying field or the LHS will let you dab some onto a cloth. If all else fails, you'll have to sand it out (I edited my comment above - so re-read it).
I know car parts stores (Autozone) sells plastic restorer for headlight/taillight lenses... it buffs out UV-hazed plastic so it's clear again. And motorcycle shops sell the same stuff for plastic windscreens and helmet visors.
Old Mar 02, 2012, 12:37 PM
Joined Nov 2008
thanks for the help!
Old Mar 02, 2012, 12:45 PM
Captain Dunsel is offline
Find More Posts by Captain Dunsel
United States, NJ, Southampton Township
Joined May 2005
Aren't a lot of CA removers made with a high-proportion of nitromethane?
CD
Captain Dunsel is offline Find More Posts by Captain Dunsel
Old Mar 02, 2012, 01:04 PM
ausf is online now
Find More Posts by ausf
ausf's Avatar
United States, NY, CENTRAL VLY
Joined May 2011
Future does remarkable things with clearing scratches in styrene. If you can buff out or remove the glue residue, it might work.
ausf is online now Find More Posts by ausf
Old Mar 02, 2012, 07:42 PM
Joined Nov 2008
Just tried WD-40 with zero luck :/
Old Mar 02, 2012, 08:03 PM
bjaffee is offline
Find More Posts by bjaffee
Brett
bjaffee's Avatar
So Cal
Joined Apr 2002
I know 3-in-1 oil will work to remove CA fogging from canopies. Not sure if it would have any effect when straight liquid CA got on the plastic, though.
bjaffee is offline Find More Posts by bjaffee
Old Mar 02, 2012, 08:26 PM
Pete Miller is offline
Find More Posts by Pete Miller
Beaumont, TX
Joined Feb 2007
Damp, not soaked, Cotton balls and toothpaste. Start polishing. Make sure you have something supporting the inside of the canopy, like your finger.
Pete Miller is offline Find More Posts by Pete Miller
Old Mar 02, 2012, 08:50 PM
Joined Nov 2008
I may try nitro, then the toothpaste, then floor polish. If there's no progress by that time then I'll have to settle for painting it
Question How do I know when my battery is done charging on my thunder ac6? skarface Batteries and Chargers 5 Jan 19, 2012 07:00 AM
Discussion 120 sr fiberglass canopy fresh out my new mold.. Soon for M120D01 & MCPX USMC0351CPLRICCI Micro Helis 1 Sep 29, 2011 04:54 PM
Found Trade for a cx3 canopy ( DEAL DONE) n6nev Aircraft - Electric - Helis (FS/W) 1 Apr 26, 2009 07:58 PM
Found Trade for a cx3 canopy (DONE, GONE) n6nev Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Apr 26, 2009 07:39 PM
Discussion Done my first canopy! quadracer111 Coaxial Helicopters 21 Apr 29, 2008 04:29 PM
