Old Mar 02, 2012, 09:58 AM
hog2soar is offline
Find More Posts by hog2soar
hog2soar's Avatar
Central California
Joined Jan 2010
Help!
Need tips on installing push rods inside boom
Anyone have any good tips on how to install pushrods inside a boom?
How do you glue the tubing against the inside of the boom?
Thanks for any advice.
Eddie
hog2soar is offline Find More Posts by hog2soar
Old Mar 02, 2012, 10:05 AM
John Walter is offline
Find More Posts by John Walter
John Walter's Avatar
USA, IL, Naperville
Joined Feb 2003
Put a piece of music wire inside the pushrod tube, then use magnets on the outside of the fuse to hold the tube firmly to the inside of fuse. Run thin CA inside the fuse along the tube, wait for it to set and you are done.
John Walter is offline Find More Posts by John Walter
Old Mar 02, 2012, 10:30 AM
soarx4 is offline
Find More Posts by soarx4
United States, IL, New Lenox
Joined Feb 2005
Do as John suggest, but additionally, put 2-3 wraps of masking tape around the push rod housing every 2 inches or so. This will better bond the CA to the rod.
soarx4 is offline Find More Posts by soarx4
Old Mar 02, 2012, 02:17 PM
ozmo01 is offline
Find More Posts by ozmo01
ozmo01's Avatar
USA, MO, Ozark
Joined Nov 2006
Nice tip! Just remember to put the fridge magnets back on the fridge
Knock or break old motor magnets out of dead electric motors for this kind of use. They are also good for hatches etc
ozmo01 is offline Find More Posts by ozmo01
Old Mar 02, 2012, 08:03 PM
glidermang is online now
Find More Posts by glidermang
Eddie:
What John Walter suggests is the most common way to do it, and works well. I endorse it.
This also works: fix the tubing (with push rod inside) to the external fuselage at one end, then pull it tight at the other. When it's tight, CA the other end. In the one case I have had of looseness inside (I could hear something banging when I shook the boom), what I did was stuff a packing peanut down the boom. I've done push rods this way on many airplanes (including my two, present Blaster 3's; and a 2-meter Dove I found in 2009) and nothing yet has ever come loose in flight or otherwise.
It's an esthetic thing for me. The best bet is still to run the push rods outside: you can see them, they are secure 100%, there is no measureable drag.
Good luck!
Yours, Greg
glidermang is online now Find More Posts by glidermang
Old Mar 03, 2012, 08:22 AM
Bob Cook is offline
Find More Posts by Bob Cook
The Lone Blue Plaid Flyer
Bob Cook's Avatar
Seattle
Joined Jan 2003
HI Hog,
It also helps to lightly sand the push rod housing to take off the glossy sheen.
Bob in Seattle
Bob Cook is offline Find More Posts by Bob Cook
Old Mar 04, 2012, 06:22 PM
Airbud is offline
Find More Posts by Airbud
Airbud's Avatar
Canada, BC
Joined Jan 2010
Its a good idea to also wrap tape around both ends of the tube to prevent CA from getting into the tube while gluing. It would reduce the inside diameter of the tube if it got in.
Airbud is offline Find More Posts by Airbud
Sold need V1 or V2 cheap tail servo push rod/s & plastic boom rod guides boom support rods blueindian Aircraft - Electric - Helis (FS/W) 2 Feb 06, 2012 10:53 PM
Discussion Supra tail boom push rods.. friction issue. Upvector Multi Task F3X 12 Apr 16, 2011 02:08 AM
Discussion control rods inside the boom or out? planepainter Sailplane Talk 14 Aug 17, 2009 11:52 AM
Tail boom slotting and push rods pgleich Hand Launch 5 Jul 07, 2005 12:10 PM
need tips on securing push rods electrohead Electric Sailplanes 3 May 13, 2001 01:34 AM
