Old Mar 01, 2012, 07:59 PM
warbird_cowboy is offline
Find More Posts by warbird_cowboy
Cowboy of the skys
warbird_cowboy's Avatar
United States, Mt, Whitefish
Joined Oct 2010
Build Log
hanger 9 p- 40b warrhawk 50
well here it is, the hanger 9 p-40b warhawk.
first impressions
very clean finish and overall a impressive model.
comes with the options to be glow or electric. i will be doing this plane in electric
directions are straight forward and typical of hanger 9
stay tuned and feel free to chime in on this build
warbird_cowboy is offline Find More Posts by warbird_cowboy
Old Mar 01, 2012, 09:42 PM
Mobyal is offline
Find More Posts by Mobyal
Mobyal
United States, VA, Lexington
Joined Apr 2007
I'll watch this one and follow you along. I'll be starting mine in a week or so..
Mobyal is offline Find More Posts by Mobyal
Old Mar 01, 2012, 10:14 PM
V2rider is offline
Find More Posts by V2rider
V2rider's Avatar
USA, MD, Hagerstown
Joined Jun 2009
Subscribed. Looks like the covering and cowl match up pretty good in color.
V2rider is offline Find More Posts by V2rider
Old Mar 01, 2012, 10:41 PM
Cowboy of the skys
Joined Oct 2010
due to my location my electronic may be slow to get here so if any of yall get further then me please feel free to pick up where i leave off
now back to the p-40, after i glue in the CA hinges i went on to cutting the holes for the retrract. the give you a template to make it easy
Old Mar 01, 2012, 10:42 PM
brati4 is offline
Find More Posts by brati4
brati4's Avatar
Wichita,Ks
Joined Feb 2007
As was discussed in the previous thread, can you tell what the purpose of the oversized cowl flap area? Is it that way for cooling?
What power setup are you going with?
brati4 is offline Find More Posts by brati4
Old Mar 01, 2012, 10:57 PM
Cowboy of the skys
Joined Oct 2010
the oversize cowl area dose not appear to be used for anything. when it was molded it was done in the open cowl position. i wish it was done in the closed position. in the electric set up on the manual the esc is located on top of the electric motor box instead of the bottom for cooling.
as far as my setup goes i haven't decided yet. i was hoping to hear what others have done for 50 size planes.
Old Mar 01, 2012, 11:01 PM
buracho topspin is offline
Find More Posts by buracho topspin
Joined Feb 2012
So are you installing the power 52 or the power 60? Also, are you going to run 5S or 6S?
buracho topspin is offline Find More Posts by buracho topspin
Reply With Quote  (Disabled)
Old Mar 01, 2012, 11:06 PM
Cowboy of the skys
Joined Oct 2010
im thinkin a rimfire 60
Old Mar 02, 2012, 08:41 AM
V2rider is offline
V2rider's Avatar
USA, MD, Hagerstown
Joined Jun 2009
I've run the numbers through ecalc on the 52 for a couple 3 blades. Also flight tested the 52 with the 14x9x3 on 4s in my 190. It flew it ok, probably about the same as the P-46 turning a 13x8x3 on 4s, maybe a hair faster. The 190 has way more drag with the open cowl than the P-40 will have though so it may actually be a good scale setup.
I just ran the numbers again for a 5s on the 52 turning a 13x8x3 and they look pretty good. It's saying 69 amps( my test numbers have been coming up 3-4 amps less than the calc) a little over 7 minutes run time on a 5s 5000ma, should give just under 10lb thrust and a pitch speed of 66-68 mph. Looks like I need to buy some 5s packs as well as some of the Graupner 3 blades to do some more testing.
Old Mar 02, 2012, 02:23 PM
FieldofDreamsFlyer is online now
Find More Posts by FieldofDreamsFlyer
Field of Dreams Flyer
FieldofDreamsFlyer's Avatar
United States, CA, LA
Joined Sep 2004
I think the great setup would be the power 60 on 5s with a 3 blade prop. The same setup whats on my friends Kyosho P-40 and flies it great.
FieldofDreamsFlyer is online now Find More Posts by FieldofDreamsFlyer
Old Mar 02, 2012, 02:51 PM
Cowboy of the skys
Joined Oct 2010
well whats cool about the spinner they give you has only one hole cut into it and the option of cutting hole for 2 or 3 blade props
Old Mar 02, 2012, 03:11 PM
V2rider is offline
V2rider's Avatar
USA, MD, Hagerstown
Joined Jun 2009
Do you know what 3 blade he is running? I just ordered a couple of the 15.75x13x3 APC's and a 16x10x3 MAS. I think I'll spend the money I was going to use on the Graupners for a couple 5s packs instead.
Old Mar 02, 2012, 07:40 PM
Joined Sep 2004
I think its the 15.75x13x3 APC
Old Mar 03, 2012, 03:54 AM
raaf1 is offline
Find More Posts by raaf1
Australia, SA, Mt Barker
Joined Jan 2012
Looking forward to this thread.Not certain when they arrive in australia hoping this month.
I've got all my motor [dulesky xm5050 ] electronics and retracts .I've used this setup in a cmpro 50 size p40 and its very quick.
How far are you going detail it cowboy.?
raaf
raaf1 is offline Find More Posts by raaf1
Old Mar 03, 2012, 06:17 AM
Michael in Toronto is offline
Find More Posts by Michael in Toronto
E-flyer since 1981
Michael in Toronto's Avatar
Joined Oct 2000
I built the 50-size Hanger 9 Corsair, and use the recommended .46 brushless motor on 4 cells, and it provides excellent scale flight; I have no desire to fly a scale plane at rocket speeds.
Staying away from a bigger and heavier power system keeps the weight down and the landings easy.
I would think their recommended Power 52 brushless motor would be more than adequate.
Michael in Toronto is offline Find More Posts by Michael in Toronto
Discussion P-40 B; 50 size; Hangar 9 TripleW Electric Warbirds 1714 Mar 30, 2016 08:16 AM
Discussion P-40 B; 50 size; Hanger 9 brati4 Fuel Warbirds 5 Feb 29, 2012 02:13 PM
Discussion Hangar 9 P-40B Warhawk olllian Electric Warbirds 7 Feb 19, 2012 11:23 AM
Wanted set of Hanger 9 2nd gen retracts for 1.50 p-51 or p-47 jazsop Aircraft - Fuel - Airplanes (FS/W) 3 Apr 20, 2007 12:03 AM
Wanted set of new 2nd generation Hanger 9 1.50 p-51 or p-47 retracts jazsop Aircraft - General - Miscellaneous (FS/W) 0 Apr 13, 2007 02:32 AM
