Old Mar 01, 2012, 05:10 PM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
HOW TO FIX WARPS, DENTS, TWISTS OR UNCRUNCH FOAM PLANES and PARTS
HOW TO FIX WARPS, DENTS, TWISTS OR UNCRUNCH FOAM PARTS
by Ed Anderson
I never crash, but maybe you do. Crashing can crunch the foam of a Radian or other foam planes to the point that the parts donít fit or it introduces a twist or warp as you try to put it back together. Or it can introduce a twist or warp in the fuselage. I am going to outline a method of getting the foam back to straight or uncrunching parts. This can also be used to take twists or warps out of new parts and it will take dents out of your foam wings or even bagged wings, like DLG wings.
Letís suppose your Radian, Easy Glider, Easy Star, etc. has a tendency to turn in the air requiring you to trim in a lot of rudder to get it to fly straight. How can you fix it? Well first you have to find the cause. Turn your foamy over and site down the fuselage seam. It should be straight from nose to tail. Or, tape a piece of string to the tail end of the fuse, again inverted and then gently stretch the string to the nose. It should track down the center of the fuse. If it does not, you have a warp. We are going to fix it.
This can happen at the factory, from a fuse not sitting right in the box or from a crash where one side of the fuselage compressed from an impact. This can also happen if you leave a foam plane in a hot car for a long time. Believe me, what you will learn here will come in handy for the rest of your foam flying life.
Heat does wonderful things to foam. It can stretch it, expand it and help straighten it. You can put twists in or take them out. You can use this when making some foam replacement parts too.
Since we are fixing the fuse, take the wings off, you won't need them. Take the h-stab off if it comes off. Tape the rudder so it is straight.
Try to figure out where the warp is centered. I am going to guess it will start behind the wings, somewhere along the boom. Flex the fuse to see if you can get it to look straight. You may have to use something to apply pressure in the center of the curve on the opposite side to get it straight. If you can flex it to straight, you can fix it.
Basically you are going to apply heat to the inside of the curve as you flex the boom away from the curve and a bit past straight. As you apply heat the gas that is trapped in the foam beads will expand. As the beads expand they extend that side of the fuselage making the heated side longer and helping you take that warp out. If this was caused by a crash this will uncrunch the crunched beads.
This goes under various names, but you might hear it called the Elapor soup method as it really became popular with the Mulitplex Elapor foam planes. But it works well with most beaded type foams. Easy Star pilots would crunch the nose of the plane in a crash. They would plunge the nose, Elapor foam, it into boiling water and the foam would expand, thus the soup reference.
Heat Methods.
HOT running tap water - You hold the part to be expanded under the hot water while you shape it. In this case you flex the fuse just a little past straight while it is under the running hot water. The foam beads will expand, extending that side of the fuse. After a minute or two you take the fuse out from under the water, still holding it and let it cool. Then site and see if it took. Go back under the water if needed. As tap water is only 100 to 140 degrees sometimes this is not hot enough to do the job. So we need more heat.
Placing the part into boiling water - this works well for small pieces like a rudder a wing tip or a crunched nose. You can also pour boiling water over the area.
Steam from boiling water sometimes works. Use a BIG pot and make lots of steam. This works well for large areas like wings.
My favorite is using a heat gun/hair dryer to heat a wet cloth or paper towels. Don't let the towels dry out completely. You heat the wet cloth till it steams and starts to dry out. You have the part stretched while you do it, just as above.
BTW this works well for bagged composite wings, like DLG wings. It can take a dent our by heating the foam under the skin. I use paper towels and my covering iron. They just magically disappear. Works well for dents in your Raidan, Easy Glider, etc. here you want to be more focused, so a covering iron or a hot clothes iron is best. Just use the tip to focus the heated area over the dent.
In each case the purpose of the water is to keep the foam from getting too hot and melting. We want to get it up to about the temperature of boiling water, though sometimes hot tap water, 120 to 140 degrees can do it too.
Using these methods I have taken Radians and Easy Gliders that have been broken into numerous smashed and crushed pieces, reshaped the foam and glued it back together with great success. Recently I shredded my Radian while slope soaring. A high speed crash through bare tree branches did a nice job on the fuse. The wings just came and got a few dents, but the fuse was in 5 pieces. It flies today!
Regardless of the method, you want to spread the expand over a somewhat broad area, not a pinpoint. Again, in the case of dents in a wing you want to be more targeted. That is why I use my covering iron rather than a heat gun.
In the case of the fuse we are using as our example, you want to expand the most in the center of the warp curve but you want to extend that somewhat forward and back of the center or you will have to overheat one area too much and perhaps not have enough expansion ability to make it work.
Try it! If you have some scrap Styrofoam or other beaded foam you can try this out for practice. Take a foam drinking cup. cut out the bottom. Now do a top to bottom slice. Use the method above and see if you can take the curve out of the foam and make it flat. You may not get it totally flat but you will see the impact. Note that the cup material is thin so donít heat it to much at once or you will expand all the bead instead of just the ones on the inside of the curve. The heated beads will get bigger.
When working on a fuse, wings or other parts, be sure you don't introduce a twist as you do this or you will have another problem. But no worry, that can be fixed too.
Clear Skies and Safe Flying.
aeajr is offline Find More Posts by aeajr
Old Mar 01, 2012, 11:12 PM
RexSe7en is offline
Find More Posts by RexSe7en
Go Ducks
RexSe7en's Avatar
United States, OR, Milwaukie
Joined Feb 2012
Great info! This is now in my favorites as I'm quite certain this will be a necessary project here at some point in my flying future. I just hope its later rather than sooner!
RexSe7en is offline Find More Posts by RexSe7en
Old Mar 02, 2012, 07:23 AM
aeajr is offline
LI, New York, USA
Joined Mar 2003
I hope others will ad their tips and tricks too.
Old Mar 02, 2012, 03:20 PM
epyonxero is offline
Find More Posts by epyonxero
Joined Feb 2012
Today the ground broke my nose of my bixer off right behind the payload bay. What is thre best way to reattach it? Gorilla Glue/Epoxy or this heating method?
epyonxero is offline Find More Posts by epyonxero
Old Mar 02, 2012, 03:44 PM
aeajr is offline
LI, New York, USA
Joined Mar 2003
I don't know the Bixer. What kind of foam is is made of?
Old Mar 02, 2012, 04:03 PM
Joined Feb 2012
I think its EPO
Old Mar 02, 2012, 05:22 PM
aeajr is offline
LI, New York, USA
Joined Mar 2003
I believe EPO can take regular and foam save CA when used with kicker. Some people like Gorilla glue too. Not sure how well Goop works.
When you are not sure about a glue, put a drop of it in an out of the way place and leave it there for an hour or two. If it has not disolved the foam it probably won't.
Old Mar 02, 2012, 10:30 PM
Great_Goose is online now
Find More Posts by Great_Goose
Flying from Vic Park
Great_Goose's Avatar
Australia, SA, Adelaide
Joined May 2011
Given it is structural repair and requires strength I would use Epoxy.
Great_Goose is online now Find More Posts by Great_Goose
Old Mar 02, 2012, 11:06 PM
aeajr is offline
LI, New York, USA
Joined Mar 2003
BTW, the heat method mentioned is not a glue process. It is use to get things back into their proper shape.
For example, if your broken Bixer nose is "crunched" you can use the heat methods to take the crunch out before you glue it back together. Both the nose and the fuse probably have some crunch. By taking the compression out you can get it straight again.
Old Mar 03, 2012, 12:01 AM
Hance is offline
Find More Posts by Hance
Expo is built into my thumbs
Hance's Avatar
USA, ID, Niter
Joined Jul 2008
II have never crashed so these tips aren't for me Well actually do you have any tips for putting foam confetti back together? The last plane I really stuffed in shortened a 4s 2200 lipo by an inch and a half it wasn't pretty.
Great post aeajr !
Hance is offline Find More Posts by Hance
Old Mar 18, 2013, 05:06 PM
aeajr is offline
LI, New York, USA
Joined Mar 2003
Anyone need advice on how to fix foam?
Old Mar 20, 2013, 05:19 AM
Mac50L is online now
Find More Posts by Mac50L
New Zealand, Canterbury, Rolleston
Joined Oct 2011
Today the ground broke my nose of my Bixler off right behind the payload bay. What is thre best way to reattach it? Gorilla Glue/Epoxy or this heating method?
Gorilla polyurethane glue. Tape the outside of the join (after gluing it) so that the foaming goes in and doesn't make as much mess. The polyurethane glue gets into what ever cracks there are and makes as good a grip as it is possible with any foam.
The heating is only used to expand any crushed foam and to allow reshaping before gluing. You can mould the foam once it is hot. I use water that is just off boiling. Boil the water in the kettle, wait 1/2 a minute and then pour slowly over the area. The foam will start to bubble a little and can now be shaped. Rubbing the foam will flatten the bubbling.
Glad to hear it was the ground and not pilot error caused the accident.
Mac50L is online now Find More Posts by Mac50L
Old Dec 09, 2015, 11:47 AM
syed is offline
Find More Posts by syed
United States, NJ, Edison
Joined May 2007
EPP wing
How can we fix/straighten the wing (chord) is warp.
Thank you
Syed
syed is offline Find More Posts by syed
Old Dec 09, 2015, 12:48 PM
aeajr is offline
LI, New York, USA
Joined Mar 2003
Thank you
Syed
Did you read the first post?
Old Dec 09, 2015, 01:20 PM
syed is offline
Joined May 2007
I am already aware of what the first post is talking about as I used that method for my easystar, My situation is little different as the epp wing seems to have been cut in such a way that it effecting the straightness of the rib and it is only happening to one out of 4 parts of the wing.
Thank you
Help! How to fix bent wingtips on a foam plane? 4075aaron Beginner Training Area (Aircraft-Electric) 12 Dec 05, 2011 02:39 PM
Discussion How do you get small dents out of Multiplex foam? eng30 Foamies (Kits) 2 Nov 30, 2011 07:00 AM
Question how to fix "elapor" dents David22 Foamies (Kits) 10 May 09, 2009 09:47 PM
Finger dents on a foam wing - worth trying to fix? Hostage-46 The Builders Workshop 6 Oct 01, 2004 01:40 PM
how to fix foam planes light JetDaddy Foamies (Kits) 3 Feb 10, 2003 07:43 PM
