Old Mar 01, 2012, 03:24 PM
Joined Sep 2011
Wheels rounding off
I have an Arrma granite with the traxxas velinion setup and keep rounding my wheels out, bolt is tight have aluminum hex any ides or suggestions how to prevent this or if there is a company how is "stronger"others thanks.
Sent from my DROID2 using Tapatalk
2000yamahar6 is online now Find More Posts by 2000yamahar6
Old Mar 01, 2012, 03:25 PM
Joined Sep 2011
Ps this is 2s haven't tryed 3s it doesn't need more power
Old Mar 01, 2012, 03:48 PM
wparsons's Avatar
Canada, ON, Markham
Joined Aug 2008
is the hex the right size for the wheel?
wparsons is offline Find More Posts by wparsons
Old Mar 01, 2012, 09:24 PM
Joined Sep 2011
Yes it is rite I just upgraded aluminum because plastic stripped out too
Old Mar 02, 2012, 09:03 AM
winfield Ia
Joined Jul 2009
What tires and surface? Also how tight is the slipper clutch?
Reddog170 is offline Find More Posts by Reddog170
Old Mar 02, 2012, 10:05 AM
Joined Sep 2011
Stock tires and wheels and dirt/grass slipper is around 3 and 1/2 turns out, was tighter but snapped drive shaft
Old Mar 02, 2012, 10:29 AM
why am i here???????
United States, OR, Oregon City
Joined Mar 2009
wierd i run a 2wd slash with vxl brushles and i have yet to round out any wheels. and my slipper is at roughly 1/2 turn out.
traxxas13 is offline Find More Posts by traxxas13
Old Mar 02, 2012, 10:53 AM
Joined Sep 2011
Well stock slipper setting was 5 turns out I figure 3ish would be better,still new to all of this
Old Mar 02, 2012, 12:59 PM
Joined Mar 2009
i am still baffled about your problem. ive never rounded out a wheel? how many hexes have you rounded out so far?
Old Mar 02, 2012, 01:45 PM
Joined Sep 2011
Well its 2wd so 3 both on back and one off front before I got the aluminum I guess I may try to locate some praline wheels over the week end
Old Mar 02, 2012, 01:46 PM
Joined Sep 2011
That's proline.
Old Mar 03, 2012, 06:10 PM
wparsons's Avatar
Canada, ON, Markham
Joined Aug 2008
You rounded out a front hex on a 2wd car?!?! Are you tightening the wheels enough? Are you making sure they're lined up properly before tightening the nuts?
There's virtually no load on the fronts, there has to be something else wrong if you rounded out a front one.
Old Mar 03, 2012, 06:50 PM
Joined Sep 2011
No I took it off the front and put it on the rear since front just spines the front didn't strip it I did
Old Mar 04, 2012, 08:11 AM
wparsons's Avatar
Canada, ON, Markham
Joined Aug 2008
Looking at the pictures of it online, the stock wheels look like they might be pretty soft. I would try some higher quality wheels and see what happens with them.
Old Mar 04, 2012, 05:38 PM
winfield Ia
Joined Jul 2009
Run it slow in a controlled manner so that you can see if a gear is binding or skipping. A sudden load or choppy load may cause it to break stuff.
Link Foam Wheels, Off-Road Tires, & Plastic Wheels at ServoCity ServoCity ServoCity.com 0 Nov 09, 2011 10:19 AM
Discussion suitable wheels to take off the beach (wet sand) tdriver Fuel Plane Talk 8 Sep 26, 2011 09:10 PM
Discussion Rounding off the edges of EPP foam? RC-Archer Foamies (Scratchbuilt) 5 May 03, 2011 02:41 PM
Discussion Rounding off a square wood fuse nose? flyboy320 Electric Sailplanes 9 Dec 10, 2009 05:37 AM
