Old Mar 01, 2012, 02:04 PM
liteglow is offline
Find More Posts by liteglow
Joined May 2005
Help!
Help! How do you solder these motor wires??
I am replacing all my 6 motors, and when I remove the isolation from each wire, there is only cobber wire directly from the motor ?
Not so easy to see on the picture maybe, but the wire is like a regular Transformator wire.
I have tried to scratch away the isolation part, but the solder will not stay on the wire part
How can I solder this ??
need help right now.
thank you
liteglow is offline Find More Posts by liteglow
Old Mar 01, 2012, 02:06 PM
AlPackin is offline
Find More Posts by AlPackin
AlPackin's Avatar
United States, CT
Joined Mar 2011
clean the enamel off with fine sand paper
AlPackin is offline Find More Posts by AlPackin
Old Mar 01, 2012, 02:15 PM
chaosdestro0 is offline
Find More Posts by chaosdestro0
Quad lover.
chaosdestro0's Avatar
Joined Dec 2011
Put some flux on it.
chaosdestro0 is offline Find More Posts by chaosdestro0
Old Mar 01, 2012, 02:24 PM
liteglow is offline
Joined May 2005
2 great tips.. I will try
Old Mar 01, 2012, 02:51 PM
Saneless is offline
Find More Posts by Saneless
Joined Jun 2011
Flux won't work if the enamel is still present. Your best bet is to sand it off as already mentioned, or use a knife and very carefully scrape it off without damaging the wire. Also be sure to get all of it, and not just one side. It can be tricky but it's possible.
Saneless is offline Find More Posts by Saneless
Old Mar 01, 2012, 04:05 PM
liteglow is offline
Joined May 2005
It was very tricky... but indeed possible !
Finnish soldering all my 6 motors now.
Thank god I did not had to sand every wire..
Question Do you know how old these cars are? sparkles46 Car Talk 2 Jan 03, 2012 01:39 AM
Help! How do you solder conectors for genius batteries? Hot_Wheels Micro Helis 4 Nov 15, 2011 08:32 AM
Discussion How do you test your solder job? stockman20 Batteries and Chargers 7 Oct 07, 2011 01:34 PM
Discussion Solding two wires - how do you join them pre-solder? infopimp Batteries and Chargers 14 Jan 31, 2007 04:01 PM
How do you get solder to stick to BL wires? randall1959 Electric Plane Talk 9 Oct 17, 2005 11:04 AM
