Mar 01, 2012, 09:56 AM
Joined Aug 2011
Screw set and piston pin retainers for OS 10 FP
OS 21106003 (piston pin 10FP/FSR)
Actually I just need the teflon retainers that fit on the edges of the pin.
UPDATE: I used the retainers from 21206000 (10-12 piston pin) and these work.
OS 21313000 (screw set 10FP)
UPDATE: 21013000 (10LA screw set) has 4 long screws that sub for the 10FP head bolts. 21313030 (12CV-X screw set) has the M2.6x6 screws for the backplate. These will also work on the 10FSR.
Hopefully this info helps others in the future.
Happy Flying,
Greg
Reason: Found some subs
