This thread is privately moderated by Lindy757, who may elect to delete unwanted replies.
Old Mar 01, 2012, 09:19 AM
Lindy757 is offline
Find More Posts by Lindy757
Trader Rating: 4
"Hey Watch This!"
Weston, FL
Joined Apr 2009
Trader Rating: 4
Sold
Mini Ultra Stik EP Ready-to-fly + new ARF kit! $225
Mini Ultra Stik EP Ready-to-fly + new ARF kit!....the original wing was destroyed when I moved so, I bought a whole new ARF kit to use only the wing on my original Ultra Stik. So, it's like getting two full planes. $400 invested!
BUY IT NOW for only $225!!
Sellers Notes: RTF. Very clean aircraft.
LPU Only
E-flite Mini Ultra Stick ARF
[EFL2250]
Motor: Turnigy C3530-1100
Spektrum AR-500 receiver
HexTronic 36 Amp ESC (Deans)
E-flite S75 servos install
Required BatteryLiPo 3S 2200mah
Based on the popular Hangar 9 Ultra Stick, the E-flite Mini Ultra Stick comes 95% prebuilt from balsa and light-ply and is covered in genuine UltraCote. At the heart of the Mini Ultra Stick’s fun factor are two firewall options that let you use a wide variety of motor sizes, types and brands. This along with the ample clearance for larger props that its tall, lightweight aluminum landing gear provides gives the Mini Ultra Stick huge performance potential. You can push the envelope even further by adding the optional split quad-flaps.
The Mini Ultra Stick can be assembled and ready for flight in just 1 to 2 hours thanks, to:
Preinstalled control surfaces and hinges
Preinstalled control horns
Preinstalled pushrods
Bolt-on horizontal and vertical stabilizers
Preassembled landing gear with wheels attached
Features
Perfect transitional airplane for advancing pilots who want to learn aerobatics and for sport flyers who want easy comfortable sport flyer
95% factory-built; get flying in 2 hours or less
Lightweight balsa and plywood construction
Two firewall options to use a variety of motor sizes, types & brands
Includes molded firewall stick mount
Control surfaces have factory-installed hinges and control horns
Bolt-on tail requires no gluing and secures with two lock nuts
Optional quad-flap configuration
Tough, lightweight aluminum landing gear that's factory-assembled and tall enough to accommodate larger prop sizes
Covered in genuine Hangar 9 UltraCote
Great match for E-flite Park 450 Outrunner Brushless Motor
Easy access top battery hatch
Design based on Hangar 9’s popular line of Ultra Sticks
Specifications:
Wing Span: 38.75 in (985mm)
Overall Length: 34 in (865mm)
Wing Area: 325 sq in (21 sq dm)
Flying Weight: 22 - 25 oz (625 - 710g)
Motor Size: Park 400 Inrunner or Park 450 Outrunner
Radio: 4-channel or greater (7-channel for quad flaps)
Servos: 4 sub-micros (6 sub-micros for quad flaps)
Trim Scheme Colors: UltraCote Fluourescent Blue, Flame Red, Transparent Red & White
CG (center of gravity): 2.25 in (57mm) behind the leading edge
Prop Size: 10x7 - 11x7
Hardware Included: Yes
Speed Control : 20A Brushless
Recommended Battery: 2100 mAh 3-Cell 11.1V Li-Po
Flaps: Yes (optional)
Control Throw (Ailerons): 1/2 in (15mm) Up/Down Low Rate or 5/8 in (19mm) High Rate
Control Throw (Elevator): 9/16 in (18mm) Up/Down Low Rate or 7/8 in (23mm) High Rate
Control Throw (Rudder): 7/8 in (23mm) Right/Left Low Rate or 1-1/4 in (32mm) High Rate
Approx. Flying Duration: 10-20 minutes
Scale: Park Flyer
Approx. Assembly Time: 1-2 hours
Gear Ratio: 6.5:1 when using Park 400 Brushless Inrunner
LPU Only
Lindy757 is offline Find More Posts by Lindy757
Old Mar 02, 2012, 01:04 PM
Troutbum is offline
Find More Posts by Troutbum
Trader Rating: 16
Just Fly!
Troutbum's Avatar
United States, WV, Bridgeport
Joined Feb 2011
Trader Rating: 16
Do you have any idea what it might cost to pack and ship to 26330?
Troutbum
Troutbum is offline Find More Posts by Troutbum
Old Mar 20, 2012, 11:54 PM
Almason124 is offline
Find More Posts by Almason124
Trader Rating: 0
United States, FL, Key Biscayne
Joined Mar 2012
Trader Rating: 0
Interested in Buying Mini $225
Bruce, I am in Miami and agree to purchase for $225 and can pick it up.
I sent you a private message, you can reach me at 305-283-7937.
My name is Al Mason, I am mostly Heli but my son is interested in fixed wing RC as well.
Almason124 is offline Find More Posts by Almason124
For Sale Nexstar Mini Ready to Fly Package NEW ! propflipper Aircraft - Electric - Airplanes (FS/W) 2 Jan 27, 2012 01:53 PM
For Sale Mini Ultra Stik EP Ready-to-fly + new ARF kit! $225 Lindy757 Aircraft - Electric - Airplanes (FS/W) 2 Mar 18, 2011 07:10 PM
For Sale For Sale - Bob Selman Mini Stik - Ready to Fly Allan Wright Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Feb 02, 2009 02:35 PM
Discussion Great Planes Big Stik 40 ARF versus Hanger 9 Ultra Stik 40 ARF fishingships Scale Fuel Planes 2 Oct 23, 2008 10:29 PM
