Old Mar 01, 2012, 07:07 AM
Stormchase is offline
Find More Posts by Stormchase
Joined Oct 2011
Help help help
Ok so he I sit with my head down.
I picked up a hobby king parkjet kit thinking it would be gluing a couple pieces together and plug and mount electronics and that's about it. Well I got this kit a while ago and things are not as I expected. I have never done a kit before and am still pretty new to rc planes. I have a few questions about building and right now feel I know nothing abou it so go with that.
I don't know if I need more parts or what. This is what I have:
I understand what the parts are for but assembly
For the motor and esc the tips seem different then what I have seen soldering other things.
I expected the tips would have been installed already but this is what they look like on the motor as well.
These is the bag of connectors and shrink. I do not know what the gear looking pieces are otr the proper mounting of anything. The connectors have a hole in the side of the hollow center
I'm pretty sure I got the HTX 900 servos in tight and correctly. Tell me pkz
I have an issue with assembling the body. I got the epoxy in the kit that I didn't use. I tried the quick glue that didn't work.
So I bought 15 min and it didn't hold either.
Yet another issue is the canopy. The 2 pieces I got don't seem to match. Even trimming the glass doesn't seem right to be able to fit.
How is this done.
I'm really at a loss.
Need lots of help.
What's a good way to mount the stick mount?
Thanks ahead of time. Would like to get it in the air one day.
Stormchase is offline Find More Posts by Stormchase
Old Mar 01, 2012, 07:51 AM
Gerry__ is offline
Find More Posts by Gerry__
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
Try searching RC Groups: http://www.rcgroups.com/forums/showthread.php?t=1565475
That Eflight CA and kicker is the stuff to use not epoxy which doesn't stick EPO very well.
Gerry__ is offline Find More Posts by Gerry__
Latest blog entry: Eflite Gee Bee Racing
Old Mar 01, 2012, 08:24 AM
Joined Oct 2011
Good write up but still left with the same questions. Thanks for the tip on the glue. The person at the local hobby shop sold the 15 min to me. Neither glue worked for me tho. Any tips? Was clean and new when I used the e-flight glue.
Old Mar 01, 2012, 09:50 AM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
Did you clean the surfaces prior to gluing? There might be some residual mould release on them. It's also a good idea to lightly sand the the foam before gluing. Did you follow the kicker instruction? You need to spry that onto a rag and then apply it to one surface and the CA to the other.
Old Mar 01, 2012, 09:52 AM
Doubletap is offline
Find More Posts by Doubletap
Si Vis Pacem Para Bellum!
Doubletap's Avatar
United States, CA, El Segundo
Joined Jul 2005
That model is molded in EPO correct?, Foam safe CA is only for EPS, it won't bond properly with EPO, EPP, Elapor, Aerocell, ZFoam , etc. Must use standard CA with these types of foam.
Doubletap is offline Find More Posts by Doubletap
Old Mar 01, 2012, 10:05 AM
BEA flyer is offline
Find More Posts by BEA flyer
Concord, MA
Joined Jun 2002
I like the gorilla glue but it's messy. It sticks to EPO and you cut or sand excess off, as it expands as it dries, but it sticks and is lighter than epoxy. Don't get it on your fingers too. Worse than CA for that. It cures in an hour.
BEA flyer is offline Find More Posts by BEA flyer
Old Mar 01, 2012, 10:12 AM
Concord, MA
Joined Jun 2002
The 3 plugs connect the ESC and motor. Male on the motor and female for the ESC. The shrink wrap is important as you don't want these to short against each other. The other end of the ESC gets the plug you have for the battery, Deans or XT60 or whatever, With particular attention to (+) red wire and (-) black not getting reversed or you will smoke the ESC, maybe radio too.
I think you are putting the canopy on backwards.
Old Mar 01, 2012, 10:16 AM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
Good point. I missed the 'foam compatible' bit on the label.
Old Mar 01, 2012, 11:16 AM
Joined Oct 2011
Gary, I did wipe the edges with a clean rag and roughed the surface with my fingernail lightly. For bonding.
I did follow the kicker instructions but didn't say anything about a rag wipe.
Doubletap,
Yes it's EPO. I am trying the eflight glue one more time. Hope I'm not messing it up.
BEA, time to find my hot pen. Hope I have solder still. I got the deans ultra a few min ago.
This what your talking about?
It doesn't fit my batteries.
For the canopy that's just a pic for what I got. I know it is backwards in the pic but I tried both ways of coarse. The clear is much bigger then the outside of the foam.
hope the pic helps.
For the glue I guess I should look at gorilla glue? I also need a motor mount for this tiny engine. Local doesn't carry.
Old Mar 01, 2012, 03:16 PM
Concord, MA
Joined Jun 2002
You need to have plugs for the ESC that match what the battery has. The yellow one in the photo is an XT60. This is kind of standard now on HK batteries like turnigy and Zippy/Rhino for lower capacity. The blue one I have seen on a Super Tigre ESC. You could put the Deans on the ESC and the other mate to it on the battery. Then you need another one for the charger.
I have tried standardizing my ESC and battery plugs, but I have a set of XT60 batteries and ESC's and a set of Deans. I made Deans to XT60 adapters. I have Deans on my wattmeter, so I can see discharge rates for both setups.
I found the XT60 easier to solder. Be sure you plug the Deans together first and don't overheat them as the plastic can distort (melt). If you are soldering one to a battery, please be careful not to short the battery wires as you are soldering them to the plug!!!!
Old Mar 01, 2012, 04:32 PM
Joined Oct 2011
I don't want to change anything over if I don't have to. My local guy had me under the impression it was more universal. He only gave me males. I don't get him... U would think it would come in pairs.
Old Mar 01, 2012, 09:31 PM
Pete Miller is offline
Find More Posts by Pete Miller
Beaumont, TX
Joined Feb 2007
They do come in pairs. They also come in packs of all males and all females.
Think about it:
If you have one plane with a battery and then buy five extra batteries, do you really want to spend the money on six pairs of plugs or do you want to buy one pair and a bag of five females for the extra batteries.
Pete Miller is offline Find More Posts by Pete Miller
Old Mar 02, 2012, 08:45 AM
Joined Oct 2011
I would have thought the salesman would have sold me a pair knowing that I have never heard of Deans. Wouldn't ya think?
So I would think ht60 would be the right choice but... Really worth changing over?
Old Mar 02, 2012, 08:47 AM
Joined Oct 2011
I can't seem to find a mount. Any suggestions?
I have been looking but to no luck. Could use help on this. No one else has answers.
Old Mar 02, 2012, 09:38 PM
Beaumont, TX
Joined Feb 2007
This might work:
http://www.headsuprc.com/servlet/the...Plastic/Detail
Measure the distance between the motor mounting holes. Two of the holes should be farther apart then the other two. MIGHT BE something like 16 mm between the two closest and 19 mm between the two furthest. THIS IS MEASURED ACROSS THE CENTER OF THE MOTOR.
Post your numbers and we will see what we can do. Where have you been looking? And what have you been looking for?
Also, in one of your pics, I see a blue plug and a yellow plug. They look like XT 60's, but I cant be sure. What are they hooked up to?
Help! help help please rickstringer Electric Plane Talk 3 Mar 02, 2012 10:48 PM
Discussion Help Help Help Have to order stuff tonight PetroMonkey FPV Talk 12 Dec 05, 2011 07:51 PM
Joke Help ! Help ! The Russians are Going to Kill Us ! Chophop Humor 24 Oct 28, 2011 10:07 PM
Wanted Help Help!!! Mr. foambuilder Aircraft - Electric - Airplanes (FS/W) 0 Sep 28, 2011 11:48 AM
