http://www.rcgroups.com/forums/showp...01&postcount=9 Rafa |
Australia, NSW, Sydney
Joined Nov 2012
Do you mean I should disconnect 3 motors from the FCB and test 1 motor at a time? |
Also make sure the rotation direction is correct and remember which motor goes into which FCB plug. What I did was to use a fine permanent marker to label the FCB sockets (FR, FL, RR, RL). |
If all 4 motors/blades spin, put on some throttle and see if you feel wind above the quad. If you do, it's because the blades are in the wrong positions (cw and ccw) and it's forcing air up instead of down to create lift. Lard4Hire |
Joined Nov 2012
Problem solved. Very emberassing to admit but the blades were swapped... Now for the next question: when she takes off she immediately goes backwards and I have to correct by forward stick. I'm guessing at least one motor needs replacing but is there an easy way to tell which without trial and error? Can I assume it's one of the front motors? (same behavior with old and new blades) |
Leeds, UK
Joined Dec 2003
That would be a rear motor, or calibration/trimming somewhere. I've noticed my v2 sets the gyros whenever the throttle is zero, so if you take off from a slope it won't hover.
And if you accidentally drop the throttle too low and it tumbles from height... |
Also if you don't quickly get it out of ground effect it will slide as well. Make sure you are popping it up a few feet off the ground. Having to adjust some from ground effect is normal. The question is once you adjust it to be level does it still want to go backwards after that?
| Thread Tools | |
| Build Log Project QR-1 - Rutan Quickie Racer | Geode | Slope | 110 | May 04, 2010 11:25 AM |
| Discussion Ladybird Special | imp.bob | Vintage & Old-Timer Designs | 4 | Feb 03, 2008 10:08 PM |
| ladybird beetle/gws easybug | nebuchadnezzar | Foamies (Kits) | 1 | Aug 14, 2004 08:48 AM |
