Put 808 cam on the DSM ladybird this morning. Using a 30mah battery instead of stock on the cam to save weight. Flies well!!
Don't hate on the kickin' PJ bottoms!! hahahaa
Joined May 2012
Have you tried other switches? I'm not familiar with devo7e but I'm pretty sure the problem is in controller settings, "device output" maybe. I couldn't get this thing to work on my devo6 until I installed deviation firmware, but as far as I know, people were able to do it on stock devo 7/8.
This could work also, 2pcs for 4.29, but I'm not sure if motor and shaft diameters are the same. |
The stock Walkera dual charger just has a solid red light when battery is plugged in. Which is normal, and then you've used it after the light goes off yes? All normal. Make sure the battery cable is solidly soldered to the board and that the pins in the board cable and the battery cable are all still lining up and making contact. I can't think of anything else except a board problem. |
Latest blog entry: Change Your Perspective
Really nice vid and flyin Turbo, did you strip the shell off the cam? I can't believe that 30 mAH battery lasted that long, what do you think the temperature might've been?
Australia, NSW, Lake Macquarie
Joined Sep 2012
I love my mother-in-law!
Her Christmas present to me, arrived today. As you can see, I was sick of waiting for parts! Photo shows unpacked parts (including 11x main frames, 3x canopies, V2 receiver and 3x 280mAh batteries), together with new LB V1 and new Devo7E. All from Banggood. In the modified tool box, is my original LB V2. It currently is awaiting a PCB transplant. It does not to bind to new Devo7E Tx, nor old Devo 4 Tx, after it was flown into the local park's perimeter fence! |
Nice Gman - you got hooked up!! I need to modify my ladybird case now that I use my DX8 to control it.. Did you just cut up the original to make that? Nice!
Thanks for the good words on the video! The camera is nice.. NIce and clear.. Yes, the shell is stripped off.. With the 30mah battery it weighs about 8.5g's. 11.8g's with the stock battery. The temp outside was about 40. THe only complaint I have is that in a crash, it tends to either delete the video it was recording, or truncate the last minute or 30 seconds.. In this video, I tried to land on my hand but bounced off onto the lawn... It cut that out I also had it on my Edge 540QQ and had a nose-over in which it cut out the end.. Must be pretty sensitive to shock or G forces..
Nice gift G Man...all I got from my mom in law was a kiss on the cheek...
You'll enjoy the V1 & Devo 7E combo, that's what I'm flying alot right now too.
Joined Sep 2012
Yes, she is nice... we've been In-laws for 25 years. She must wonder what her daughter was thinking, hooking up with me.
![]() Quote:
I would like to thank all the contributors who has made the selection a 'no brainer'. Plans are (after I learn to fly it) video set up on the LB, then I'll have a go building an arduino based quad. Cheers! |
I take power directly from the battery for my light set by soldering directly to the positive and negative terminals on the PCB. My 9 LED light set doesn't affect flight times at all...still 6 to 8 minutes. Regards, John |
| Thread Tools | |
| Build Log Project QR-1 - Rutan Quickie Racer | Geode | Slope | 110 | May 04, 2010 11:25 AM |
| Discussion Ladybird Special | imp.bob | Vintage & Old-Timer Designs | 4 | Feb 03, 2008 10:08 PM |
| ladybird beetle/gws easybug | nebuchadnezzar | Foamies (Kits) | 1 | Aug 14, 2004 08:48 AM |
