This from Jesolins; BD, It is better not to power LEDs that can create DC noise through the power points that were designed for firmware updates. That and the LEDs will have a better power source if you solder a connector to the same points the lipo is attached to the FCB. It is a best practice and not that it won't work when you power from those firmware points on the board. There is just less that can go wrong if they are more directly connected closer to the lipo. Note also that the flight controller boards that do have LED connection sockets intentionally filter those power points with a Vreg or transistor to prevent DC noise from getting to the controller. Hope that helps. Cheers, Jim |
USA, GA, Kennesaw
Joined Dec 2003
Ok, this makes sense. Although I admit when I get a chance to complete mine, I'm just gonna plug em in. I'm actually going to take some spare wire and random bits this weekend and practice my soldering. I need to improve my skills for the leds, and the fpv stuff I'm working on ordering as well.
United Kingdom, England, Sheffield
Joined Jun 2012
Are all the direct drive 7mm motors the same? Can I mix and match 939 and ladybird motors?
I find the ladybird motors are actually cheaper than the 939 ones. Are they better or longer wires or something? http://www.banggood.com/Wholesale-7m...l?currency=GBP and http://www.banggood.com/Wholesale-Wl...6-p-49473.html |
Hi all,
I finished up a couple of 8 LED Navigation Light Sets for the Ladybird. They consist of 8-0805 SMD LED's, 2-Red for Port, 2-Green for Starboard, 2-Blue for Aft and 2-White for Forward. I power them with my Low Drop Constant Current Driver (LDCCD) and solder it directly to the Ladybird's PCB for power. The entire light set weighs only 1.38 grams and when installed distributes it's weight so as to not affect the Ladybird's CG at all. I'm very happy with the end result. These first two are going out to a couple of forum members for testing, hope they give me good reports. I've posted this little video before but here's my Ladybird prototype lights on an early morning flight.
Also a few pictures of the Navigation Light Set and it's installation. Regards, John
USA, CA, Piedmont
Joined Jun 2010
Very nice work 1Hammer...nice install. Makes mine look like a 'rats nest under the hood'. I need to keep practicing, using the absolute minimum of materials. Micro soldering is just part of the total package. The wiring and end result install is just as tricky...at least for me and my brautwurst fingers...
Latest blog entry: Change Your Perspective
The easiest way to explain my Low Drop Constant Current Driver (LDCCD) is as follows. It converts the voltage and current of the LiPo to a constant current and voltage suitable for the LED's included in the light set so the LED's remain a consistent brightness as the LiPo discharges. My LDCCD doesn't use resistors to reduce the voltage and current, resistors will shorten flight time as they use additional power to regulate the voltage and current. For the Ladybird 8-LED Light Set the LDCCD I've built for this application takes the 240mAh and 4.2 V of the LiPo down to a constant 3.0V @ 30mAh for Blue, Green, White LED's and 2.7V @ 30mAh for Red LED's. This particular LDCCD will work with 2S @ 7.2V and 3S @ 11.1V as well. Hope this explains the LDCCD somewhat. Regards, John |
I'm an architect and building contractor by trade, it took me about 2 years to figure out how to build the LDCCD...I don't think I'm willing to give that up just yet. BTW, it's "Heat Shrink" not "Shrink Wrap", shrink wrap is what the box is covered with when you buy a new product. ![]() Regards, John |
Joined Jun 2012
Hey BD, you may find this page useful.
http://www.dimensionengineering.com/...ing-regulators I have a purchased unit that has a pot for a range of voltages out and uses switching for efficiency. It's much bigger at about the size of a thumb nail but can take a couple amps and under a tenner. I'm new to electronics so can't help on an exact schematic yet. I'm sure something built for a specific voltage in and out would be much cheaper and smaller What about those motors guys, are they all the same? |
| Thread Tools | |
| Build Log Project QR-1 - Rutan Quickie Racer | Geode | Slope | 110 | May 04, 2010 11:25 AM |
| Discussion Ladybird Special | imp.bob | Vintage & Old-Timer Designs | 4 | Feb 03, 2008 10:08 PM |
| ladybird beetle/gws easybug | nebuchadnezzar | Foamies (Kits) | 1 | Aug 14, 2004 08:48 AM |
