Old Apr 27, 2012, 06:51 PM
HobbyCool_tech is offline
Find More Posts by HobbyCool_tech
Joined Jan 2012
I love this mini quad. Lots of fun!
http://www.hobbycool.com/walkera-qr-...rtf-p-467.html
Walkera QR ladybird (2 min 6 sec)
HobbyCool_tech is offline Find More Posts by HobbyCool_tech
Old Apr 28, 2012, 03:17 AM
OnceAFly is offline
Find More Posts by OnceAFly
OnceAFly's Avatar
Singapore, Singapore
Joined Oct 2011
For those of you guys here having problem on the ladybird, why don't you post your setting here and we can see whats wrong and advice accordingly?
OnceAFly is offline Find More Posts by OnceAFly
Old Apr 28, 2012, 01:39 PM
Morphin is online now
Find More Posts by Morphin
Schweiz, BE, Münchenbuchsee
Joined Jun 2011
Which Transmitter
HI
Which Transmitter does have working telemetry?
2402D
DEVO 10
DEVO 12S
DEVO 6S
DEVO 7
DEVO 8S
Which one to choose for this little monster (and future copters...)
Andy
Morphin is online now Find More Posts by Morphin
Old Apr 28, 2012, 07:12 PM
KcaKamakazi is offline
Find More Posts by KcaKamakazi
KcaKamakazi's Avatar
Canada, BC, Victoria
Joined Jan 2012
Hey guys just fopr the previous question any of the Devo S series remotes have telemetry, but the question I have an issue rather is does anyone else have an issue with the yaw rate freezing and becomming unresponsive while in flight also I have the Devo 7 that came in the bundle and many times on startup of the transmitter the little "jingle" that plays on startup is sometimes different and ends up not syncing with the heli? Anyone else having these issues?
KcaKamakazi is offline Find More Posts by KcaKamakazi
Old Apr 29, 2012, 03:29 AM
boxhead530 is offline
Find More Posts by boxhead530
AMA 965811, FAA FA3MTYYYCK
United States, CA, Chico
Joined Nov 2010
This flys real nice, and it flys wild nicely.
On the kit I got, devo7 with ladybird, why would they set that right side top switch to full throttle? I can't think of any quad flying that would. Need that...
Yeah, I played with it before reading 78 pages of tx MANULE, I hope I can fix that.
I went for three batts, and spent 30 minutes doing them. I think I want to make batt adapter to use my charger and see what mah is going back in, the charger that came with qr LB is neat, but I am afraid of red lit green lite....
Oh, wind was about 7-10 mph, and it handled fine.
boxhead530 is offline Find More Posts by boxhead530
Old Apr 29, 2012, 08:44 AM
Boomer Jim is offline
Find More Posts by Boomer Jim
Joined Jun 2010
Devo 7 that came with Lsdybird. Also, trim keeps changing with battery use during flight.
Boomer Jim is offline Find More Posts by Boomer Jim
Old May 01, 2012, 01:47 PM
HoverX is offline
Find More Posts by HoverX
HoverX's Avatar
France, Pays de la Loire, Pornic
Joined Mar 2008
Hi,
What's the size of the props on this little beast?
HoverX is offline Find More Posts by HoverX
Old May 02, 2012, 02:32 AM
FlyingPriapism is offline
Find More Posts by FlyingPriapism
United States
Joined Nov 2011
Originally Posted by HoverX View Post
Hi,
I too would like to know the answer to this question, as well as any cheap alternatives that can be used?
FlyingPriapism is offline Find More Posts by FlyingPriapism
Old May 04, 2012, 07:39 PM
mitmit is offline
Find More Posts by mitmit
Moscow
Joined Jul 2006
can someone measure voltage on pin marked red please? seems I've burned mine somehow, after power up it started to spin all motors at full throttle, now voltage on regulator is 0.8v so board doesnt start..
thanks
dimitri
mitmit is offline Find More Posts by mitmit
Old May 05, 2012, 05:31 PM
United States
Joined Nov 2011
Since no one answered, I went to wowhobbies and picked up some props today. They measure 5.5cm, just under 2.17inches.
Hi,
Old May 06, 2012, 12:08 AM
flying-llama is offline
Find More Posts by flying-llama
Sopwith Camel's Cousin
Between my tx and crashed aircraft
Joined Mar 2006
One complication for finding alternative props is to find both cw and ccw props.
One possible source are replacement props for something like the AirHogs or Silverlit small twin motor planes.
flying-llama is offline Find More Posts by flying-llama
Old May 06, 2012, 03:31 AM
United States
Joined Nov 2011
Awesome, thanks! I tried the AirHogs ones; bought them off ebay. I'm actually using these props for a mini quad about the size of the ladybird. The ladybird props worked better than the AirHogs. Still waiting on these from GLB. Anyone tried those or other props on their ladybird, other than stock?
Old May 06, 2012, 07:58 PM
lift_off is offline
Find More Posts by lift_off
Joined Oct 2006
Originally Posted by Boomer Jim View Post
Think I'm getting some of the same. Just after liftoff, it just screams up until I kill the throttle. Problem is, this only happenes sometimes indoors. Hope someone has answer for this.
Originally Posted by loquacious View Post
Mine does it indoors and outside which is bad because I almost lost sight of it the other day and killed the throttle only to crash land and break the battery cage!!!
Originally Posted by lift_off View Post
Ditto! Exactly the same obscure phenomenon!
I'm using a Devo 10.
Hi,
Better late than never, I think I figured out the problem:
On my Blade mQX (3-axis gyro) I was used to plug in battery upside down, then let it initialize. Never had any problem.
BUT it seems as if the 6-axis gyro of the Ladybird requires to be upright while initializing!!!
Otherwise the gyro is getting messed up, not working properly.
Since the maiden flight I was having serious "throttle-pulsing". Had some unavoidable crashes as a result of this.
Now, after dozens of those damn nasty flights everything is finally going nicely.
Great events often come from little causes...
lift_off is offline Find More Posts by lift_off
Old May 10, 2012, 08:59 AM
Joined Jun 2010
Lift_Off
Hi,
Wish answer was that easy. Have always pluggrd in my QR's battery right side up on level plane. Still has unintended acceleration.
Old May 13, 2012, 11:59 AM
Kopteri2010 is offline
Find More Posts by Kopteri2010
Kopteri2010
Joined Feb 2011
FPV with QR Ladybird
Hi, I made a FPV test with the Ladybird...
Walkera QR Ladybird 2.4GHZ link test (3 min 38 sec)
Cheers, Eki
Kopteri2010 is offline Find More Posts by Kopteri2010
Build Log Project QR-1 - Rutan Quickie Racer Geode Slope 110 May 04, 2010 11:25 AM
Discussion Ladybird Special imp.bob Vintage & Old-Timer Designs 4 Feb 03, 2008 10:08 PM
ladybird beetle/gws easybug nebuchadnezzar Foamies (Kits) 1 Aug 14, 2004 08:48 AM
