Old Feb 29, 2012, 10:43 PM
Cdcdude is offline
Find More Posts by Cdcdude
United States, CA, San Jose
Joined Dec 2011
Help!
Stripped screw on 480 Bl outrunner motor
I stripped one of the 2 mm hex screws on the outrunner. It's the screw attached to the donut looking piece behind the shaft. Anyone have any advice?
Cdcdude is offline Find More Posts by Cdcdude
Old Mar 01, 2012, 06:30 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
Is that the aluminum cylindrical piece that slides up the shaft and against the Ci-clip? If so, that reinforces the shaft and keeps it from being pulled out of the inner races in the event of the C-clip failing or being lost.
It is only needed when you are using the motor in the radial mounting method (rotating part facing in the direction of flight). If you have a firewall mounting (rotating part to the rear) you can leave that "donut" off.
If the C-clip is in place and up against the inner bearing race (as it should be) you can fly without it and take the chance that the C-clip will hold as failures are not very common.
To "save it" you may be able to tape the screw hole to a 3mm thread and use the larger grub screw.
Jack
jackerbes is offline Find More Posts by jackerbes
Sold Parkzone 480 Bl Outrunner 2200Kv Motor. Like New $35 shipped! rcwarrior Aircraft - Electric - Power Systems (FS/W) 2 Oct 30, 2011 09:11 PM
For Sale ParkZone 18A BL ESC & 480 BL Outrunner Motor; 960Kv photocycler Aircraft - Electric - Power Systems (FS/W) 1 Jun 29, 2011 09:35 AM
For Sale ParkZone 18A BL ESC & 480 BL Outrunner Motor; 960Kv photocycler Aircraft - Electric - Power Systems (FS/W) 3 Apr 02, 2011 09:55 PM
For Sale ParkZone 18A BL ESC & 480 BL Outrunner Motor; 960Kv photocycler Aircraft - Electric - Power Systems (FS/W) 4 Mar 07, 2011 11:03 AM
Question Stripped Wire on BL-480/4D Any Ideas On How to Fix or Replace Prindle19 Electric Motor Design and Construction 2 Apr 14, 2009 10:03 PM
