Old Feb 29, 2012, 09:22 PM
fabmaster911 is offline
Find More Posts by fabmaster911
Clinton, Utah
Joined Apr 2008
Help!
Speedo Pro Mark II battery selection etc.????
What setup are you guys using in your Speedo Pros? I seem to be really really tail heavy no matter what battery i try to fit in the nose. I have even set a 4.8v AAA up on there and it's still heavy in the tail. I haven't actually tried to officially cg it because I don't have a manual and don't know where the CG is supposed to be but I was just shooting for the spar. I haven't done anything non traditional to add weight to the tail. Do I need to just load the nose with lead or what?
fabmaster911 is offline Find More Posts by fabmaster911
Old Mar 01, 2012, 01:27 AM
gizzo is online now
Find More Posts by gizzo
Live slow, Die whenever
gizzo's Avatar
Adelaide, Australia
Yep. It needs a bunch of lead in the nose as well as the battery. Put the battery in, canopy on and set it up on your CG device. Tape a plastic cup or something to the nose and load it with weights until it balances where you want it. Weigh the cup and contents, then whatever that weighs, add the same weight of lead to the nose in whatever form you prefer. HTH.
gizzo is online now Find More Posts by gizzo
Old Mar 01, 2012, 10:48 AM
rvsixer is offline
Find More Posts by rvsixer
rvsixer's Avatar
United States, CA, Orange County
Joined Sep 2005
Speedo instruction manual including setting CG:
http://www.rcgroups.com/forums/showt...ghlight=speedo
rvsixer is offline Find More Posts by rvsixer
Discussion Battery selection for DJI F550 hex kit copters3d Multirotor Talk 16 Mar 30, 2015 07:43 AM
Sold BaoFeng UV-3R Mark II UHF/VHF & Two Freq. display, Watch dual band radio UV3R terriwang Aircraft - General - Radio Equipment (FS/W) 6 Mar 15, 2012 02:43 PM
For Sale BRAND NEW: Canon Pixma PRO 9000 Mark II scoobiemario Non R/C Items (FS/W) 3 Oct 29, 2011 10:06 AM
Discussion Speedo Pro Mark II build thread? fabmaster911 Sailplane Talk 3 May 29, 2011 12:48 PM
Wanted Bagged wing for Speedo Pro Mark II fabmaster911 Aircraft - Sailplanes (FS/W) 0 May 09, 2011 05:15 PM
