Old Feb 29, 2012, 09:30 PM
SJackson is offline
Find More Posts by SJackson
SJackson's Avatar
Queensland, Australia
Joined Jan 2010
Question
Quad Build Using HobbyKing Multi-Rotor Control Board V3.0 (Atmega328 PA)
hi all,
i've decided to build a quadcopter using the "HobbyKing Multi-Rotor Control Board V3.0 (Atmega328 PA)". As i am a noob to multi rotors of any kind, i am looking for the best set up for flying in + configuration. as mentioned by HK the control board firmware is already set to this config.
I have a couple of questions, mainly concerning the number of lipo batteries that is normal to have running the one quad, and the best frame design.
(as a side note: i will be building the frame myself, and want the quad to be fairly small 405 mm from the tip of the blades along the arms is the maximum length.
Also i have a 10x750 hollow carbon fibre tube which i was planning to use for the arms)
cheers to all that can share help in one way or another.
SJackson is offline Find More Posts by SJackson
Old Mar 01, 2012, 10:15 PM
pug398 is offline
Find More Posts by pug398
VA
Joined Nov 2009
Welcome to the club!
I would adjust the size to either a 5" or 7" prop. One 2s or 3s battery should do the job depending on the size and weight you end up with.
pug398 is offline Find More Posts by pug398
Old Mar 01, 2012, 11:02 PM
SJackson is offline
SJackson's Avatar
Joined Jan 2010
im using 5" prop and a ZIPPY Flightmax 1000mAh 2S1P 20C, ive got 4 of them, but if im only using one on the quad at one time, ill need to make my own split cable to power the 4 esc's yes?
Old Mar 02, 2012, 09:16 AM
pug398 is offline
VA
Joined Nov 2009
For that size (actually most) I use a spider harness. Solder all black esc power wires together and all red esc power wires together. Solder a power pigtail (short two wire cable with battery connector) across the spider harness where all the wires are soldered together and tape or coat the soldered connections. All esc are then powered when you plug the battery in. A few esc have very short power wires on them but I just solder extension extension wires to them and still wire it up the same. The 2s 1000ma battery may get you 10 min or so flight time if you are just under 200g.
Old Mar 02, 2012, 09:20 AM
SJackson is offline
SJackson's Avatar
Joined Jan 2010
cheers, this infomation is very interestng and helpful. this will certainly save in connectors as well.
Old Mar 02, 2012, 09:37 AM
pug398 is offline
VA
Joined Nov 2009
I recently built three of them so it is fresh in my mind
With 5" props you will need a minimum of 2000kv on 2s to hover 200g in the air about half throttle. They pull about 4A each. 3000kv motors with 5" tri blades pull about 5.9A .
Old Mar 02, 2012, 09:46 AM
SJackson is offline
SJackson's Avatar
Joined Jan 2010
the current motor im using is 2100kv with the suggested prop 5x3, supposed to pull just over 300g, so i think it would be fine
Old Mar 02, 2012, 01:20 PM
Dave8888 is offline
Find More Posts by Dave8888
United States, AZ, Seligman
Joined Nov 2011
You can also use one of these for connecting ESCs. http://www.goodluckbuy.com/multicopt...ion-board.html
Also you will like the board you chose. I am flying with a Hobby King v2 (now v2.1) board, also still in + mode. Flys really good right out of the box, even before you "dial it in" (gyro pots).
Dave8888 is offline Find More Posts by Dave8888
Old Mar 02, 2012, 09:25 PM
SJackson is offline
SJackson's Avatar
Joined Jan 2010
thats great news, i built a tricopter before this, but have had no luck at flying it... my friend has got a couple of years experiance flying planes and heli's helped build it, and programed the tx so it wold work... just having a few problems taking off (ie. the motors start at different times and it wants to flip over cuz the motors arnt pulling (roughly) the same at the same time)
cheers for the new about the control board though, this has increased my confidence in this project.
Old Mar 02, 2012, 10:16 PM
Dave8888 is offline
Joined Nov 2011
Did you calibrate the throttle on the ESCs?
Old Mar 03, 2012, 12:17 AM
SJackson is offline
SJackson's Avatar
Joined Jan 2010
no im not sure how to do that on these esc's
they are hobbyking 40-50amp esc's
if you could help that would be great
Old Mar 03, 2012, 12:29 AM
Flightbox is offline
Find More Posts by Flightbox
Flightbox's Avatar
United States, OR
Joined Jan 2010
This will help you with your build and set up. beast of luck
[URL="file:///C:/Documents%20and%20Settings/David/Desktop/ALL%20FOLDERS/Quad%20Set-up/KK%20flight-controller%20Quadcopter%20setup%20guide.htm"]
Flightbox is offline Find More Posts by Flightbox
Old Mar 03, 2012, 12:54 AM
SJackson is offline
SJackson's Avatar
Joined Jan 2010
wel i think i calibrated my escs for my tri... it flew about 0.5m off the ground.
and then had a bit of a spaz, the escs are still running at different times. but they seem to hold it in the air sortof well
Old Mar 03, 2012, 12:55 AM
SJackson is offline
SJackson's Avatar
Joined Jan 2010
sorry mate but this doesnt want to open...?
Old Mar 03, 2012, 01:42 PM
Dave8888 is offline
Joined Nov 2011
This is how I did mine. I have Hobby King SS Series 18-20 (card programmable) ESCs and now they all start at the same time. Are yours the SS Series?
Calibrating the throttle range on the ESC’s
This is to ensure that all the ESC’s have the same throttle range end points. This step only
needs to be performed once. Fail to do this calibration can result in an uncontrollable
platform. If you ever install new ESC’s this step needs to be performed again.
Never perform this step with the props mounted!
- Make sure that the flight-controller is turned off
- Turn the Yaw pot to the MIN position
- Turn on the transmitter
- Move the throttle stick to top (full)
- Turn on the flight-controller
- Wait until the ESC's beeps twice after the initial beeps. (Plush and SS ESC's)
- Swiftly move the throttle stick fully down (closed). The ESC’s beeps
- Power off the flight-controller
- Restore the yaw pot to around 50%
Discussion !!NEW!! HobbyKing Multi-Rotor Control Board V3.0 ishaan65 Multirotor Talk 8 Jul 25, 2012 05:36 AM
For Sale Paris control board v2.0 and v3.0 Talajouy Aircraft - Electric - Multirotor (FS/W) 3 Feb 28, 2012 02:52 PM
Help! Can someone uploade the firmware for a hexcopter on the new HobbyKing kk board v3.0 W123 Multirotor Talk 1 Feb 17, 2012 10:52 PM
Help! Can someone uplade the fimware for a hexacopter useing the Hobbyking kk board v3.0 W123 Multirotor Talk 1 Feb 15, 2012 11:19 AM
New Product Hobbyking KK Board V3.0 Atmega328 PA shelterock Multirotor Talk 2 Feb 01, 2012 09:15 PM
