Old Feb 29, 2012, 07:57 PM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
F-86 Sabre--A Feasibility Study
Recently saw a F-86 build thread in the scratch build section, and kinda pushed my button. He is using a set of Paul Thorpe plans, for the F-86. WS 53" fuse 54" - 1:8.25 scale. Would have to be scaled up for the dynamax.
It seems to have it all . Slow, fast, agile, and even graceful.
So, I know there are more than a few of you out there that have flown this bird, and was hoping you might share your thoughts on the F-86. Mark
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Feb 29, 2012, 08:43 PM
PlumberJohn is offline
Find More Posts by PlumberJohn
John Green
USA, FL, St Petersburg
Joined Dec 2007
Were you contemplating using the Dynamax? The Sabre is one of my favorites and I've done a number of them including a stringer built balsa scratch ( without prints) build.
The ones I've done have been in the 50-60 inch range. JHH and BVM.
John
PlumberJohn is offline Find More Posts by PlumberJohn
Old Feb 29, 2012, 09:11 PM
Joined Dec 2008
I see the the BVM has a 63" WS and fuse is 60". About 1:7.5 scale. What is the approx. intake size?
Old Feb 29, 2012, 09:27 PM
John Green
Joined Dec 2007
The reason I asked is that even in the BVM there really isn't room for a Dynamax and the batteries without a whole lot of squeezing going on.
In my 52" JHH I ran a Midi on 8s and it filled the fuse, but I was able to have a rotating nose gear because the ducting is smaller. In the 63" BVM I have a Stumax 110-52 and just have room for 12s 5000's. I have a couple of smaller F-86's as well with Midi fans. Seems to be a sweet spot.
You're going to need a fuse that's about 8.5" at the center section above the wing to fit a 5" fan in there comfortably with batteries. Now I usually place my batteries at CG or oriented around the CG so that changes in weights of battery sets are negated, so that may be why I'm thinking so large.
A 50-55 inch bird is a good size. It can be built one piece or with removable wing equally well. But it's a lot easier to start with a glass fuse with any of them.
Be interesting to see what size you come up with.
John
Old Feb 29, 2012, 09:45 PM
Joined Dec 2008
I found a set of Thorp plans on E-bay, and they are on there way. Will have to resize, I think.
Then it all comes down to size/weight VS thrust. I know that my fan/motor will put out 16#+ thrust, Lee's rewind, so in that area I'm OK.
OR, I could get the plans for this: I am sure my dynamax would fit in there!
Old Feb 29, 2012, 10:26 PM
John Green
Joined Dec 2007
The nice thing about a scratch build is you can make it any size you want. Just change the zoom on your printer.
A 5" fan will fit in a frame as small as Zhia or JHH at about 50". It's the batteries that are the problem. That 'Lee's Wind' motor will want 11s at least I think, though maybe you could do 10s.
This will be fun to watch.
John
Old Feb 29, 2012, 10:56 PM
Joined Dec 2008
Lee rewound it to 695KV and with the tests he had , should be most capable
Old Mar 01, 2012, 12:50 AM
mrshea is offline
Find More Posts by mrshea
michigan jet guy
mrshea's Avatar
USA, MI, Caledonia
Joined Jul 2007
mark those are the plans i have. I just scaled them down for 70mm because i have no way to transport anything that big yet or i would have done the full size. After all bigger flies better. Will be following if you decide to do this. Phil
mrshea is offline Find More Posts by mrshea
Build Log f-86 sabre build mrshea Scratchbuilt EDFs 196 Jan 18, 2015 02:15 PM
Off Site Great Planes 30mm Brushless Micro EDF F-86 Sabre battery adapters glenn2626 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Feb 26, 2012 01:17 PM
Help! Alpha Model F-86 Sabre bigdog100 Foamy EDFs 5 Sep 23, 2011 04:54 PM
