Old Feb 29, 2012, 08:28 PM
Matt Gunn is online now
Find More Posts by Matt Gunn
RCGroups Editor
Matt Gunn's Avatar
United States, OH, Parma
Joined Jul 2009
need advice. prop for large scale electric warbird.
I just ordered the new ESM Texan II from Troybuiltmodels.com
80" wingspan, in the range of 18-21 lbs AUW.
Another RCG member electrified the ESM Hurricane, which is roughly the same size and weight with an E-Flite Power 160 on 12s 5000.
Since I have a handful of 12S 5000 packs, Im going 12S as well, and my motor choice was the Monster Power 160. My esc is undetermined yet.
However, I want to run a 4-blade prop. SInce this is setup for gas, they recommend an 18x10 4-blade.
Im not sure:
a.) what size prop to go with
b.) what ESC (leaning towards a CC 120HV)
Thanks in advance for any advice.
Matt
Matt Gunn is online now Find More Posts by Matt Gunn
Administrator
Old Mar 07, 2012, 09:33 PM
RCGroups Editor
Matt Gunn's Avatar
Joined Jul 2009
No replies... HMM, maybe I can narrow it down
I bought the Eflite Power 160 and it will be on 12S 5000. ESC is the CC ICE2 120HV.
Should I go with the 17.3x8 4-blade, or 18x10 4-blade?
Administrator
Old Mar 08, 2012, 03:22 AM
Lardog is offline
Find More Posts by Lardog
ex-noob
Lardog's Avatar
Sammamish, WA, USA
Joined Jan 2010
As long as you're not over Amping things, go with the 18x10 for moar speed!
Lardog is offline Find More Posts by Lardog
Old Mar 11, 2012, 10:56 AM
snoopy_schulz is offline
Find More Posts by snoopy_schulz
snoopy_schulz's Avatar
Germany, lake of constance
Joined Oct 2010
Hi webdr
Due to motor spec. of the eflight power 160 the max continous current is 60 A. With a 17.3x8 4-blade, or 18x10 4-blade the motor current
is too high. I would try an apc 16x10 or 16x12 2-blade prop. The prop efficiency of a 2-blade is also much higher compared to a 4-blade prop.
Maybe you can find a 15x10 or 15x12 3-blade prop.
Best regards
Micha
snoopy_schulz is offline Find More Posts by snoopy_schulz
Old Mar 11, 2012, 02:34 PM
RCGroups Editor
Matt Gunn's Avatar
Joined Jul 2009
Yep. I ended up going with a 16x8 4blade. Thanks
Matt
Administrator
Old Mar 12, 2012, 02:30 PM
Joined Oct 2010
Hi webdr
The pitch speed with a 16x8 4blade is maybe too low for your Texan II. I have calculated a speed of
22 m/s of your Texan II, horizontal flight. If the 16x8 4blade is to slow use e.g a 15x10 4blade prop.
Motor and speed calc see:
http://snoopy-schulz.square7.ch/
Best regards
Micha
Old Mar 12, 2012, 03:08 PM
RCGroups Editor
Matt Gunn's Avatar
Joined Jul 2009
Im getting a little higher numbers from ecalc...around 64mph pitch speed.
However, Im taking your advice into consideration... a 15x10 does produce some sweet numbers.
74amps
89mph
400oz torque
On 12S.
I can drop it down to 10S and still pull 300oz of torque and 74mph
Menz makes a 15x10 4 blade. I'll try it out.
Administrator
Old Mar 12, 2012, 03:56 PM
Joined Oct 2010
Hi webdr
My drive calculation as well as others is a point of start. Due to variation of prop, lipo and motor data it is
only a means to start. I would also use a watt meter to check the current/power.
Next point is than to see the performance during flight.
In the attachment i have a rough way to calculate the power needed to lift a model.
Best regards
Micha
Help! landing gear on an fpv radian. need advice. ne1 try it? g3f0rc3 FPV Talk 5 Feb 28, 2012 12:48 AM
Discussion New to large electric models, need advice Raymond_Gaskins_ Giant Electric Planes 6 Dec 04, 2011 11:06 AM
Discussion New to RC ...and need a little advice with Honey Bee imortal98 Beginner Training Area (Aircraft-Electric) 10 Nov 15, 2011 08:50 AM
Help! Need opinions on motor and battery for large electric. haasjj Electric Plane Talk 13 Sep 24, 2011 03:19 AM
Discussion Need LARGE electric model advice oldeflyer Electric Heli Talk 18 Jan 30, 2008 11:23 PM
