This thread is privately moderated by sliderguy, who may elect to delete unwanted replies.
Old Feb 29, 2012, 05:21 PM
sliderguy is offline
Find More Posts by sliderguy
Joined May 2010
modify cheap rc cars possible
Hi guys its been a while. I have stumbled across a situation that to be honest i can avoid but thought what if its possible to modify cheap rc cars.
I have 2 rc cars cheap models. Both are on the 27MHz band and when operated both of them receive the same signal on the transmitter.
Is there a way to modify the rc cars so they use different frequencies. There are no crystals in both the transmitter and the car itself. There are built in but clearly labeled RX and TX when i opened the transmitter and also opened the shell of the rc car and located the chip labeled RX.
thanks
sliderguy is offline Find More Posts by sliderguy
Old Mar 01, 2012, 08:56 AM
dedStik is offline
Find More Posts by dedStik
Redacted per NSA "suggestion"
dedStik's Avatar
United States, VA, Virginia Beach
Joined Feb 2012
Are the is it using frequency coils? You could adjust the coil to change the frequency of one of the vehicles, it would need to be done to both the TX and RX. Without knowing what models and what the innards of each looks like it may be difficult to really get help with it.
You should also be aware of the frequency of devices like that in your country. You should have a look here. It looks like your only choice is to move it 49mhz range and I don't think that will be possible without changing out the coils.
http://radiocontrol.wikia.com/wiki/27_MHz
dedStik is offline Find More Posts by dedStik
Old Mar 01, 2012, 05:51 PM
Joined May 2010
modifying cheap rc cars
Hi these are the images showing the inside of the transmitter
http://imageshack.us/photo/my-images/3/img0090zy.jpg/
http://imageshack.us/photo/my-images/407/img0089az.jpg/
These are the images shown inside the rc car
http://imageshack.us/photo/my-images/811/car2st.jpg/
http://imageshack.us/photo/my-images/534/car1sz.jpg/
http://imageshack.us/photo/my-images/337/car3hb.jpg/
I bought the cars on ebay, heres the link.
http://www.ebay.co.uk/itm/R-C-DRIFT-...a#ht_941wt_932
Models vary but they are set to 27MHz frequency.
Would be great to modify the frequency, these cars are awesome indoors and are pretty fast.
Old Mar 01, 2012, 08:26 PM
dedStik is offline
dedStik's Avatar
Joined Feb 2012
I don't think you will be able to change the frequency by adjusting them. You may be able to change the a few digits past the decimal by adjusting it, but it would still interfere with the other vehicle. You could try to find another coil to replace that one in both the tx and rx if you don't mind some soldering. You will need to know what kind of power is going through that circuit and what the coils are rated for.
Old Mar 06, 2012, 07:30 AM View Post
santana wang
A moderator felt this post violated the following rule: Off Topic Advertisement. Show it to me anyway.
Old Mar 21, 2012, 07:17 PM
cale10 is offline
Find More Posts by cale10
AMA Another Mans Airplane
cale10's Avatar
United States, OH
Joined Jul 2011
what i did
this is what i did with a modifoed servo a 20 amp brushed esc a 3s 100mah battery and a spare reciever. IT IS VERY VERY FAST!!!!!!!!!!!!!
http://www.youtube.com/watch?v=Fi4O4j5-ZU4
cale10 is offline Find More Posts by cale10
Old Mar 25, 2012, 12:00 PM
Joined May 2010
Old Mar 25, 2012, 12:37 PM
Joined May 2010
modify cheap cars
Hi I have the same model you have. Im trying to modify it. It was hard to track down the motor as the one that was fitted wasnt working properly. I tracked down a venom fireball motor from a 1:8 scale rc motor bike. A dollar on ebay. The motor is brushed. The motor slotted in perfectly in the rc car. The size basically needed to be exact. I powered it up using a 9.6V Nikko slot-in battery which i had laying around and it powered up. The motor is very very fast, i felt the power on that. I tried using lower voltage such as a 4.6V nicad battery and got decent power, i also used a 5 battery pack 6v and got even better power. The 9.6 V was really powerful though.
I have all the bits needed such as Futaba transmitter and a Futaba receiver 6 channel. Because the motor is brushed which ESC would you recommend considering i dont want to spend more money, and which battery would be suitable.
This is the link to a website. This is the motor i have - http://www.rchobbyexplosion.com/VENO...p/vnfm-106.htm
Here are some pics of what i have done, its a bit messy but really does do the job. Im planning to finish the inside to concentrate the exterior as its a ford ranger body and i want to make it nicer, probably respray it, decals, put some bull bars, light etc etc. Something to do on weekend i suppose.
http://imageshack.us/photo/my-images/21/img0135mpe.jpg/
http://imageshack.us/photo/my-images/534/img0134jx.jpg/
http://imageshack.us/photo/my-images/196/img0133er.jpg/
http://imageshack.us/photo/my-images/856/img0132ec.jpg/
http://imageshack.us/photo/my-images/850/img0131fd.jpg/
Theres 2 suspensions that are missing, any ideas where i can get them from
maybe you may have a set. Thanks.
RC Modify Cheap Battery Test (2 min 35 sec)
Old Apr 17, 2012, 01:37 PM
shaneperch is offline
Find More Posts by shaneperch
Joined Jul 2004
The simplest method to change the frequency is to install a hobby grade 2.4 GHZ set inside with a decent speed control . Or find used gear. May not be the cheapest but would be the best.
shaneperch is offline Find More Posts by shaneperch
Sold blade mcp x heli bnf trades for rc cars boss777 Aircraft - Electric - Helis (FS/W) 10 Feb 29, 2012 01:01 AM
Discussion Flying rc cars???? Is it possible celuffka Off-road Cars 0 Aug 07, 2011 09:42 PM
Sold All RC stuff (cars, boats, planes) CHEAP!!! toxic-trip Non R/C Items (FS/W) 6 Jun 14, 2010 10:02 PM
Cheap battery packs for RC cars Vonbaron Electric Plane Talk 1 Feb 14, 2002 01:37 AM
