View Poll Results: what should I do?
repair it with lots of glue! 7 87.50%
buy a new fuselage 0 0%
go for a 1.6mt skywalker 0 0%
buy a new 1.9mt skywalker 0 0%
buy a bixler 0 0%
buy an easystar 2 1 12.50%
Voters: 8. You may not vote on this poll
Old Feb 29, 2012, 04:16 PM
emerge is offline
Find More Posts by emerge
Joined Oct 2010
should/can I repair this? (crashed EZ*, pictures inside)
hello, I had a bad luck during an FPV flight. I was flying LOS while my gf was wearing goggles, I lost orientation and my ez* fell straight on the ground
I have all parts back, battery is ok, only esc lost the capacitors but I was going to replace it anyway (it was a 60amp hobbyking esc for hely that resets himself after some seconds with throttle at minimum).
so I can try to repair this with some glue but it seems so bent, I already have a spare set of wings; I can buy a new fuselage for 20eur or should I go for a skywalker/skywalker 1.9mt/bixler/easystar 2?
I love flying FPV and I am deep into electronics so I'd love some big space for batteries and big homemade circuits
look at the photos and just tell me if is this worth the pain or if skywalker is such a best option that I should buy it now (1.6 or 1.9mt?) and buy a new fuselage in future to make this one fly again
thank you!
emerge is offline Find More Posts by emerge
Old Feb 29, 2012, 04:36 PM
Gerry__ is offline
Find More Posts by Gerry__
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
Hardly anything wrong with it. Nothing there that a bit of low heat won't straighten out.
Gerry__ is offline Find More Posts by Gerry__
Latest blog entry: Eflite Gee Bee Racing
Old Feb 29, 2012, 04:37 PM
emerge is offline
Joined Oct 2010
I own an smd soldering station (aoyue 852), you think that some hot air will make it straight?
Old Feb 29, 2012, 04:42 PM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
If you blow some warm air on it, you will be ably to straighten it out no problem. If you have any dents, pouring water will re expand them. You should be able to get that EZ back to 99.5% as good as new. I has years of life left in it.
Even if you broke it into 8 bits, it would still be salvageable.
Old Feb 29, 2012, 09:25 PM
MRGTX is offline
Find More Posts by MRGTX
MRGTX's Avatar
United States, CT
Joined Aug 2005
The common trick is to use hot water...but it has to be sub-boiling. An easy way to do this is to brew a pot of water in your coffee maker and pour it over bent/dented sections....the foam will largely come back to shape....just be sure to keep your electronics dry, of course.
If the water is any hotter than the typical coffee pot, the cells will blister...so be careful. The hot air could certainly cause it to blister too.
MRGTX is offline Find More Posts by MRGTX
Old Feb 29, 2012, 09:31 PM
MRGTX is offline
MRGTX's Avatar
United States, CT
Joined Aug 2005
BTW, Easy Stars are supposed to be roughed up. They fly best that way.
Old Feb 29, 2012, 09:58 PM
eckace1 is offline
Find More Posts by eckace1
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
You can buy A New fuse for $20.
Some people say it can last years but I like to go by flights.
eckace1 is offline Find More Posts by eckace1
Old Mar 01, 2012, 01:41 AM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
If the cells do blister, you can flatten them with the back of a spoon.
Old Mar 01, 2012, 01:55 AM
emerge is offline
Joined Oct 2010
what glue do you suggest me? I used super attack but it makes a strong and fragile join between parts, I like this, what do you think?
http://www.hobbyking.com/hobbyking/s...rge_100ml.html
Old Mar 01, 2012, 03:53 AM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
Use white Gorilla Glue and use modelling pins to hold the surfaces together while it dries.
Old Mar 01, 2012, 04:44 AM
emerge is offline
Joined Oct 2010
bought it. what kind of colours will make it more visible? I have heard something like bright colors on bottom are not a good idea because they make it invisible when flying high.
Old Mar 01, 2012, 04:58 AM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
Black stripes on the undersides of the wings are good. The further away it gets the less you will notice colour, so the more important contrast becomes.
Old Mar 01, 2012, 07:25 AM
MRGTX is offline
MRGTX's Avatar
United States, CT
Joined Aug 2005
Medium CA works superbly on Multiplex Elapor foam.
Old Mar 01, 2012, 07:28 AM
Pete Miller is offline
Find More Posts by Pete Miller
Beaumont, TX
Joined Feb 2007
Red and Yellow are the most visible and then some dark stripes as Gerry said for contrast.
Pete Miller is offline Find More Posts by Pete Miller
Discussion ** crashed composite repairs, i can fix your expensive crashed plane xzatx High Performance 1 Feb 23, 2012 10:06 PM
Link ** crashed composite repairs, i can fix your expensive crashed plane xzatx Electric Sailplanes 0 Feb 23, 2012 06:40 PM
Link ** crashed composite repairs, i can fix your expensive crashed plane xzatx Dynamic Soaring 0 Feb 23, 2012 06:39 PM
Discussion ** crashed composite repairs, i can fix your expensive crashed plane xzatx Sailplane Talk 0 Feb 23, 2012 06:39 PM
