If you follow Tom's advice then let me offer one more to throw on the coals... I would consider changing out the airfoil making it into a S3014. Here is why, the E205, although is a great airfoil apparently has a nasty stall characteristic. However by reshaping the airfoil to the S3014 you can greatly improve the overall performance with very little effort. See attached.
Kurt Source: http://worldofkrauss.com |
United States, OH, Toledo
Joined Aug 2003
Saggita build
Two things not mentioned, Move spoliers out one bay. Double thickness of stab. I have built eight sagitta,the last one flys the best. laminate carbon fibre to spar pryor to build. I vacum bag carbon to spar. Also replace balsa ribs with plywood were spar block is installed
All good stuff...I always heard they flew pretty good built the way designed, but I think that there is at least one thing that ought to be considered along with all the other mods .....
If you do nothing else... this may be the mod that ought to be No. 1. on the list of mods for the 900 (maybe for the 600 too, but I'm only building my first 600 now). I will be doing this critical mod when I build my next 900 soon ...(yes, just can't not have one 900 in my stable). You need to address the wing joiner box at the root of each wing where it slides onto the steel wing rod ...this is the failure point that got mine on a winch, along with several others where I flew. On the wing plans it is called the "pine tube carrier block"...located at the ply wing root and ending at the third rib W-1 inside the sheeted root of each wing. Section 2 B shows it clearly - it is seated between the upper 1/8 spruce spar and lower spruce spar, just like a shear web. It comes drilled with a diagonal hole to receive the brass tube which is where the steel wing rod goes in - this is where you mount each wing and where the wing rod eventually breaks out of the pine carrier block under winch load... You can consider several ways to fix this...carbon thread wrapped around it soaked in CA, ply laminate on the face of it...or get radical and throw the part out altogether and replace with something beefier (rohacell?) but don't leave it as is - unless you enjoy watching wings fold on launches...(I didn't) Even though I reinforced it with a laminated ply plate before I planked the wing roots (as suggested in RCM Soaring column at the time - it eventually fractured under load...allowing the wing rod the break out of the wing and the wings to fold. That said.....I built my 900 with the popular "club mods" at the time in 1989.... -thicken the horizontal stab from the 3/8 by about 50 - 60 %. sanded to a symetrical airfoil shape, with sharpened trailing edge. Also increased stab area by about 10% and you can lighten the tail by putting lightning holes on thickened part - move spoiler bay out ward to wing tips at least one bay to keep airflow to the stabs clean and help control it during low speed landings using spoilers - straighten rudder..remove the flying counterbalanced portion of the vertical stab/rudder and mount the rudder perpendicular to the fuselage centerline (ever notice that most modern hi perf. sailplanes appear to have a straight vertical rudder and not that sexy canted LE on the rudder...?) -sand two pieces of 3/16" hard balsa to the stab root shape and glue to each side of the vertical fin on a neutral line of the horizontal stab root..this will get rid of the notorious stab wobble that develops over time...(you'll need a longer brass tube for the stab mounting music wire joiners ...(I put in a nice little RC car ball bearing in the vertical fin where the stab wire joiners mount in the vertical fin and trued it up during the build ..which made for a very clean fixture for the stab to rotate on...very solid). - drill out nose block and fill with lead - you'll be putting on more nose weight later anyway... - if you don't have the replacement FG fuselage...thicken the skinny fuselage where it narrows back near the vertical fin, it is a failure point on hard landings. ...(you have a FG fuse so thats good...I fiberglassed my entire fuse and will do so again so I never had a problem, even when it came in hard after the wings folded and destroyed everythng else.... |
| Thread Tools | |
| Discussion New Sagitta 900 Build | Axle209 | Sailplane Talk | 10 | Dec 31, 2008 11:36 PM |
| Build Log Sagitta 900 Build | kmacva | Thermal | 21 | Nov 18, 2008 04:11 PM |
| Build Log Modified Sagitta 900 build | Fotor | Thermal | 29 | Oct 11, 2008 10:25 PM |
| Discussion Sagitta 900 build | Curare | Thermal | 63 | May 28, 2008 07:42 AM |
| Sagitta 900 build | evan | Sailplane Talk | 141 | Jul 09, 2005 12:39 AM |
