Old May 08, 2012, 09:31 PM
aeromaniac is offline
Find More Posts by aeromaniac
Glow 😡 no no no
Australia, SA, Evanston Park
Joined Mar 2010
You should be able to take the collet prop adaptor off and push on the 3030 on the motor shaft.
aeromaniac is offline Find More Posts by aeromaniac
Old May 09, 2012, 01:22 AM
stalyoni is offline
Find More Posts by stalyoni
high flyer
stalyoni's Avatar
Australia, WA, Geraldton
Joined May 2008
that wont keep it very secure though
stalyoni is offline Find More Posts by stalyoni
Old May 09, 2012, 03:22 AM
Glow 😡 no no no
Joined Mar 2010
It's the way the 3030 was put in the fegio inrunners a few years ago
Old May 09, 2012, 01:58 PM
IFlyRCs is offline
Find More Posts by IFlyRCs
ICrashRCs
United States, TN, Memphis
Joined Jun 2011
Don't forget the part about "specially wound motor" in the introduction video.
If you ruin the stocker, you're out of luck with an exact replacement.
They need to to get some stock replacement motors in stock.
at 1:15
HobbyKing Daily - Radjet 420 (2 min 39 sec)
IFlyRCs is offline Find More Posts by IFlyRCs
Old May 09, 2012, 05:14 PM
Glow 😡 no no no
Joined Mar 2010
at 1:15
http://www.youtube.com/watch?v=ZuGsy...tailpage#t=75s
Lol I have had my motor out and it is a ap05 just like the rest of the micro range from hobbyking, no doubt it is a specially wound motor lol but not just for this model.
I have 2 spare ap05's here anyway.
See previous link supplied for motor.
Old May 22, 2012, 03:05 AM
suzanne lee is offline
Find More Posts by suzanne lee
China, Guangdong, Shenzhen
Joined May 2011
Love Radjet 420
This plane is amazing,soooo cool~~~~~~~~love this bird ,fly so fast !
suzanne lee is offline Find More Posts by suzanne lee
Old May 23, 2012, 11:29 AM
memnuts is offline
Find More Posts by memnuts
United States, NJ, Rockaway
Joined Feb 2011
Welp another Radjet 420 went to the big airport in the sky. I had three flights on mine. one the third flight I was about 60% through the flight I was dropping low to start a highspeed run and the receiver locked up and the plane drove itself right into the pavement. I will admit I giggled a bit when foam went flying into the air from the impact. The front end of the plane got obliterated up to the wing root. The guts will live on in a scratch build plank style flying wing.
memnuts is offline Find More Posts by memnuts
Old May 24, 2012, 06:28 AM
planekrazy is offline
Find More Posts by planekrazy
planekrazy's Avatar
United States, CA, Redwood City
Joined Mar 2002
RadJet 420 3S setup
Thanks for all of the info on everything from everyone here. This is a very fun plane indeed, great to see more of them showing up now.
Wrt 3S setups, be careful if using the stock 5 gram motor for that. For planes like this RadJet 420, I tend to fly at full throttle pretty much the entire flight. So ditched the stock motor and used a Turnigy B1230-4100 motor that I had on-hand. Note, that this older inrunner motor appears to have been replaced with a newer part: BL1230-4200
The B1230-4100 (and pretty much all of those little Feigao style inrunner motors) will run hot normally, couple that with a 4100kv rating and I ended up having to run a very small prop when all was said and done. I consider "big props" like the GWS 3030 and even 3020 as being too much for this motor on 3S if planning to fly at full throttle throughout the flight. The motor really liked the GWS 2508 (2.5x0.8) however top-end speed was missing. The GWS 2510 (2.5x1) was better, however still wanted more pitch so ended up converting a GWS 3020 (3x2) prop to approximately 2.5x1.5 to keep WOT load below ~4 amps.
Below are power readings from a 1 minute static full throttle run using the Nano-tech 180mAh 3S 25C pack:
Peak Amps = 4.12
Peak Watts = 46.2
After 1 minute of full throttle:
- Amps = 3.41
- Volts = 10.31
- Watts = 35.2
Here is a video of my RadJet 420 with custom 2.5x1.5 prop, 4100kv inrunner and Nano-tech 180mAh 3S lipos:
RadJet 420 micro with NT 3S lipo (3 min 13 sec)
Here are some pictures of how the inrunner motor was mounted to the RadJet micro fuse.
planekrazy is offline Find More Posts by planekrazy
Old May 24, 2012, 07:26 AM
Glow 😡 no no no
Joined Mar 2010
Peak Amps = 4.12
Peak Watts = 46.2
- Amps = 3.41
- Volts = 10.31
- Watts = 35.2
Here is a video of my RadJet 420 with custom 2.5x1.5 prop, 4100kv inrunner and Nano-tech 180mAh 3S lipos: http://www.youtube.com/watch?v=UscgGNekR5Q
Thats insane lol.
Old May 24, 2012, 09:22 AM
roo_ster is offline
Find More Posts by roo_ster
Standing Athwart History
roo_ster's Avatar
United States, TX, Dallas
Joined Mar 2011
Where did you get that motor mount? I have a couple of 12-30-5300kv inrunners that could benefit from such a critter.
And they can handle 3x3 props without getting too hot on 2S for sure and reportedly on 3S.
roo_ster is offline Find More Posts by roo_ster
Old May 24, 2012, 11:15 AM
planekrazy's Avatar
Joined Mar 2002
The fiberglass motor mount was included with this motor:
http://www.hobbyking.com/hobbyking/s...dProduct=10575
It was sitting around not being used with the included motor so put it to use since the inner mount holes lined up perfectly with the 1230 motor, and the three outer mount holes would line up within the diameter of the donut plywood plate.
In absence of the fiberglass motor mount part, it should be possible to make it out of 1/32" plywood (drenched with thin-CA for strength) or a 1mm carbon plate.
Old May 24, 2012, 03:19 PM
planekrazy's Avatar
Joined Mar 2002
I think there's no need to mimic the fiber motor mount plate like the one that I had on-hand. I can imagine two simple round plywood mounts each with different sized donut holes. The 1st plywood mount with larger donut hole would be glued to the foam fuse like the one pictured above. The 2nd plywood mount with smaller donut hole would be screwed to the motor face and to the first plywood mount plate. Should be a simpler part to make.
For the plywood plate, I used 1/32 plywood sheet from hobby store, used a Quarter (coin) to trace the outer circle size and cut-out round plate using curved tip hobby scissors. Then used a dremel tool to make the inner hole large enough for the motor can to slide through. Then I drenched the place with thin CA and sanded both sides smooth and colored black with magic marker.
Maybe the above process could be used to make the 2nd plywood plate with a inner hole made only large enough for the motor shaft to clear.
Hope to see that 5300kv motor put to use, the RadJet should be super fast with that. A GWS 3x3 prop on 2S seems like a good place to start. IIRC, the 4100kv on 3S was pulling something like 5.5 amps with the GWS 3030 and the power system was putting out ~57 watts at peak. Was too afraid to cook something so started to back-off going to smaller props.
I wonder if anyone is working on a 4S setup for this little RadJet, maybe the GWS 2508 could be used for that.
Old May 24, 2012, 03:37 PM
roo_ster is offline
roo_ster's Avatar
Joined Mar 2011
Your 1/32 plywood idea is great.
I already used the 12-30-5300 on a 12" WS delta with 2S & a 10amp ESC. It moved right on out. It was a bit draggy, so top end wasn't great, but zero heat issues.
Old May 25, 2012, 09:58 AM
planekrazy's Avatar
Joined Mar 2002
Thanks for the info on the motor, maybe the 4100 can be pushed further than I thought before. Will have to try some more props...
Old May 31, 2012, 10:47 PM
3d astronaut is offline
Find More Posts by 3d astronaut
3d astronaut's Avatar
United States, MI, Kalamazoo
Joined Sep 2011
I am a little late to the party but I just ordered my radjet 420 cannot freaking wait!!!
3d astronaut is offline Find More Posts by 3d astronaut
Discussion RadJet from the KING! vettster Foamy EDFs 1 Jun 01, 2014 06:00 PM
Discussion HK Skyfun or Radjet?? nogas Pusher Prop Jet Models 5 Feb 17, 2014 01:51 AM
Wanted Wtb wtb hk radjet lectroglide Aircraft - Electric - Jets (FS/W) 0 Feb 27, 2012 09:49 PM
Help! Turnigy 420 Charger Problem LukeSkywalker Batteries and Chargers 6 Feb 26, 2012 09:35 PM
New Product New Funjet clone- HobbyKing Radjet Kmart FPV Talk 7 Oct 20, 2011 10:33 AM
