Old Mar 18, 2012, 05:40 AM
aeromaniac is offline
Find More Posts by aeromaniac
Glow 😡 no no no
Australia, SA, Evanston Park
Joined Mar 2010
Hi Mike
Thanks for another video, its really great.
aeromaniac is offline Find More Posts by aeromaniac
Old Mar 21, 2012, 11:07 PM
miketre is offline
Find More Posts by miketre
miketre's Avatar
Joined Dec 2010
This thread's been awfully quiet for a sweet flying plane
How's everyone's flight going? anyone else have problems with the servo or have tried putting in bigger batteries?
miketre is offline Find More Posts by miketre
Old Mar 22, 2012, 02:28 AM
Glow 😡 no no no
Joined Mar 2010
Mine just arrived today and I have been playing with it, gee the battery does want to go where it's meant to to get CofG.
Old Mar 22, 2012, 05:16 AM
Glow 😡 no no no
Joined Mar 2010
It seems the servo's are only for 1s which is 4.2v and the turnigy 6a puts out 5v, considering taking the esc out and putting a diode in the rx lead to drop voltage ?.
Old Mar 22, 2012, 05:40 AM
miketre is offline
miketre's Avatar
Joined Dec 2010
hmmm.. I didn't notice any heating of the servos. will check it out.
I have the HK 1.7g servos lying around
When I plug them to a turnigy plush 6A ESC, it gets very hot after 10 seconds.
Perhaps the supplied ESC puts out 4.2A ? I'll need to poke around with a multimeter to confirm this. If it is, it is good news for me as I can replace the fluttering servo.
*edit*
Hey, wait a minute. According to the specs on the Radjet 420 product page, it is using the HK-5320 Digital 1.7g servos. These are the servos that I have. Doh!
Old Mar 22, 2012, 05:45 AM
Glow 😡 no no no
Joined Mar 2010
I just got the esc out and it is indeed a turnigy 6a and the motor appears to be a ap05, i got some 4004 diodes from the electronics shop and was going to put in the negitive lead but someone said it should be the postive one ?.
Old Mar 22, 2012, 05:48 AM
miketre is offline
miketre's Avatar
Joined Dec 2010
will an LED work in place of a regular diode, assuming the voltage drop requirement is met?
Old Mar 22, 2012, 05:55 AM
Glow 😡 no no no
Joined Mar 2010
Your asking me lol, Im looking for answers lol
Old Mar 22, 2012, 06:19 AM
RealGambler is offline
Find More Posts by RealGambler
Way to many airplanes!
Canada, QC
Joined Oct 2009
Diode would work on negative as long as you reverse it, but this is not a good "standard". Why not using the positive???
A led would not work, because it's designed to work with very low current (unless it's one of those high power led found in flashlights). So typically, it can draw only about 5 to 20mah. All the current from the servos and receiver would flow through the led, which mean more than likely, a lot more than 20mah. The led would burn out. You typical diode (unless it's very small and glassy) is usually designed to go up to 1 amp. All three servos and receiver draw a LOT less than that. (Your motor does, but current do not flow through that diode...)
RealGambler is offline Find More Posts by RealGambler
Old Mar 22, 2012, 06:32 AM
Glow 😡 no no no
Joined Mar 2010
Thanks positive it will be, I didn't know which line to put it and the negative is easier to get to being on the outside. Lol
Old Mar 22, 2012, 08:35 AM
AJWoods is offline
Find More Posts by AJWoods
Aircraft Designer Guy
AJWoods's Avatar
United States, CA, Santa Clara
Joined Jul 2005
I got mine yesterday, and it is one sweet little plane. I found CG happier closer to 22cm, vs the 23-24cm in the manual, made things much smoother and launch/landing were still fine. I has some rubbing on the motor bell out of the box, so I removed it and filed down the case a bit, runs much smoother now. running throws at about 60% ATV with 40% expo on everything.
I find it to be much faster (or at least look that way) compared to my Micro Stryker. Looks a lot like my 5s FunJet in the air, perhaps a new paint job is in order.
-Adam
AJWoods is offline Find More Posts by AJWoods
Latest blog entry: Star Wars Lambda Shuttle
Old Mar 22, 2012, 01:10 PM
kenstogie is online now
Find More Posts by kenstogie
Can we lift the embargo?
kenstogie's Avatar
menands flats, NY
Joined Dec 2006
So I was setting mine up on my dx6i and how the heck do I do it??
Whenever I do elevon set ups it seems I have down go up or up go down or Elevator stick moves ailerons and vice versa. Then I start hitting servo reverse switches on the tx and it gets all messed up..........arrrrgh!
It looks like a sweet plane though and can't wait to fly it.
kenstogie is online now Find More Posts by kenstogie
Old Mar 22, 2012, 03:42 PM
Glow 😡 no no no
Joined Mar 2010
are you reversing both ailerons and elevator together, ?.
Old Mar 22, 2012, 04:58 PM
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
Adam
Looks good, you sponsored by Monster? lol
-Adam
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Mar 22, 2012, 07:29 PM
miketre is offline
miketre's Avatar
Joined Dec 2010
Try this;
1) reverse one channel only
2) if it doesn't work, unreverse that channel and reverse the other channel
3) SWap the connections of the 2 servos
4) repeat steps 1 & 2
Discussion RadJet from the KING! vettster Foamy EDFs 1 Jun 01, 2014 07:00 PM
Discussion HK Skyfun or Radjet?? nogas Pusher Prop Jet Models 5 Feb 17, 2014 02:51 AM
Wanted Wtb wtb hk radjet lectroglide Aircraft - Electric - Jets (FS/W) 0 Feb 27, 2012 10:49 PM
Help! Turnigy 420 Charger Problem LukeSkywalker Batteries and Chargers 6 Feb 26, 2012 10:35 PM
New Product New Funjet clone- HobbyKing Radjet Kmart FPV Talk 7 Oct 20, 2011 11:33 AM
