Old Nov 15, 2012, 06:57 AM
e_lm_70 is offline
Find More Posts by e_lm_70
Austria
Joined Jan 2004
Originally Posted by BadBert View Post
Could i fit in a 2s 460 mah nanotech lipo in it? could i get the cg right?
I did use 300mAh 2S ... and I'm quite sure that you can fit also the 460mAh .. just push it as back as possible ...
Anyhow ... more heavy you get your bird ... and less pleasure will be to fly it ..
e_lm_70 is offline Find More Posts by e_lm_70
Old Nov 16, 2012, 02:01 AM
BadBert is offline
Find More Posts by BadBert
BadBert's Avatar
Nederland, Noord-Brabant, Hoogerheide
Joined Mar 2007
For outside flight it should be fine then?
And how slow can this puppy go? (with the 180 mah)
BadBert is offline Find More Posts by BadBert
Old Nov 16, 2012, 02:10 AM
e_lm_70 is offline
Austria
Joined Jan 2004
Outside it fly perfectly ... it is inside that can be challenging ... it is not very slow ... ... (or maybe it is just me that I can't fly slow )
Old Dec 03, 2012, 10:08 AM
ballores is offline
Find More Posts by ballores
UK, West Sussex, Chichester
Joined Aug 2008
Would the micro stryker brick be a good candidate for a transplant as i have a couple lying around.
ballores is offline Find More Posts by ballores
Old Dec 07, 2012, 01:03 PM
Dakrat is offline
Find More Posts by Dakrat
Sky good, Earth bad!
Dakrat's Avatar
Anchorage
Joined Dec 2005
HobbyKing has the parts back in stock, just ordered with a 10g motor...
Some new buddycodes:
Radjet 420 - Replacement Fuselage w/ Motor Mount: http://www.hobbyking.com/buddy.asp?c...5-A62C9ABCD579
Radjet 420 - Replacement Main Wing: http://www.hobbyking.com/buddy.asp?c...2-1BED5A0F2346
Radjet 420 - Replacement Vertical Stabilizer: http://www.hobbyking.com/buddy.asp?c...0-80865F8DCDFF
Radjet 420 - Replacement Canopy: http://www.hobbyking.com/buddy.asp?c...C-82857C37D23B
I am going to fly it with 3S 180mah Lipos
Dak
Dakrat is offline Find More Posts by Dakrat
Old Dec 12, 2012, 05:06 PM
WiiCopter is offline
Find More Posts by WiiCopter
Joined Jan 2011
Originally Posted by planekrazy View Post
stalyoni, absolute travel measurements for elevons were provided because D/R settings from one TX do not necessarily map to every other tx brand/model.
In case you are still looking for tx settings, I use an old JR XP9303 TX and my D/R settings for the RadJet 420 are elevator low rate 35% and high rate 50%; aileron low rate 45% and high rate 75%.
btw, I wanted to share with everyone that the Turnigy B1230-4100 motor started stuttering after about 20 flights of running on the 3S setup. No surprise given that I was really pushing the motor well beyond its rated limits. This is the same stuttering that the AP05 in my Critical Mass started doing after running on 3S setup for 8 flights. The good news is that all 3 of my Plush 6A ESCs still work great, and never had a problem with 3S setups so far. I ordered one of those new BL1230-4200kv motors from HK to see if it will survive 3S using a less aggressive prop such as the GWS 2510.
I have this motor NTM Prop Drive 13-12 2600KV / 42W
And put the esc on high eff.
Then you get more power on 3S because the 2600kv is lower then the 3000kv from AP05.
My radjet flies still very good after 30 flights without smoke the motor.
Maybe helps this late post!
WiiCopter is offline Find More Posts by WiiCopter
Old Dec 13, 2012, 11:27 AM
ballores is offline
Joined Aug 2008
i transplanted a micro stryker brick into it had to solder the servo wires and slice the fuze to remove the esc,all worked well with no servo heating issues.
Old Dec 19, 2012, 10:42 PM
gchrisgo34 is offline
Find More Posts by gchrisgo34
gchrisgo34's Avatar
United States, GA, Jonesboro
Joined Nov 2010
hello all, im thinking of getting this little plane for christmas. can anyone tell me the motor size? and shaft size? im wanting to try out one of the new micro turnigy motors HK has. thanks
gchrisgo34 is offline Find More Posts by gchrisgo34
Old Dec 19, 2012, 11:06 PM
gchrisgo34's Avatar
Joined Nov 2010
and what size batteries are people using? i know it suggests 2s 180, but i always try to get the biggest battery i can get away with. thanks
Old Dec 20, 2012, 06:41 AM
Ben D Wing is offline
Find More Posts by Ben D Wing
Ben D Wing's Avatar
The Peak District
Joined Dec 2006
Keep to the 2s 180mAh as this little model flies best when kept light. I've even removed the decals off the lower surfaces to save a few Grammes in weight. The endurance is long enough with the recommended battery without having the penalty of extra weight.
Ben D Wing is offline Find More Posts by Ben D Wing
Old Jan 02, 2013, 07:08 PM
Joined Jan 2011
I fly with 3S 180mA.
More power more fun
Weigt is equal stock.
Old May 01, 2013, 12:46 PM
gchrisgo34's Avatar
Joined Nov 2010
OH BOY!!!!!! I finally ordered a 420! been drooling over it ever since it came out. I went ahead and ordered an extra body "kit" to go with it. I ordered the recommended 2cell 180's, and one 3cell 180 to fly with. have any of you noticed those new turnigy micro motors they've recently came out with? they look very nice, and their specs say they can handle 3-4 cell batteries? I don't plan to run the 420 on 4cell, but those motors look really nice.
Old May 01, 2013, 01:04 PM
kenstogie is offline
Find More Posts by kenstogie
Can we lift the embargo?
kenstogie's Avatar
menands flats, NY
Joined Dec 2006
I have a RJ 420 the is still in the box!!! The elevons never worked right, I have a couple of new servos to throw in but have to get around to doing it.
kenstogie is offline Find More Posts by kenstogie
Old May 01, 2013, 04:19 PM
gchrisgo34's Avatar
Joined Nov 2010
my multiplex funjet is without a doubt my favorite airplane!! ive had 2 original funjets, 1 funjet ultra, and 4 flyjet x-830's. funjet ultra was heavy & didn't fly as well as the original funjet, so I sold it. but it is my favorite, and im looking forward to this one. ill be able to carry it pretty much everywhere. and fly it just about anywhere.
Old May 02, 2013, 06:31 AM
kenstogie's Avatar
menands flats, NY
Joined Dec 2006
Funjets look cool but isnt this a radjet forum?
Discussion RadJet from the KING! vettster Foamy EDFs 1 Jun 01, 2014 06:00 PM
Discussion HK Skyfun or Radjet?? nogas Pusher Prop Jet Models 5 Feb 17, 2014 01:51 AM
Wanted Wtb wtb hk radjet lectroglide Aircraft - Electric - Jets (FS/W) 0 Feb 27, 2012 09:49 PM
Help! Turnigy 420 Charger Problem LukeSkywalker Batteries and Chargers 6 Feb 26, 2012 09:35 PM
New Product New Funjet clone- HobbyKing Radjet Kmart FPV Talk 7 Oct 20, 2011 10:33 AM
