Old Feb 29, 2012, 09:47 AM
KevinSharbonda is offline
Find More Posts by KevinSharbonda
Make Flying Fun
United States, MD, Lutherville-Timonium
Joined May 2003
Alert
F3K pilot now retired and chained to building board
Well, as some of you might know, I worked for Baltimore County MD. They offered a retirement incentive program and after looking at all the possibilities I elected to take it. Won't go into details but the RIP was offered and I took it. So now I'm home and pondering my newly acquired freedom. Would certainly like to expand some part construction activities and brush up on flying skills as well. I don't have too bad of skills with epoxy etc. and am looking to maybe break into some more building time in the near future. So if you have some ideas or maybe would like to collaborate on something, give me a shout and I'd be glad to entertain anything F3K related. Thanks for the bandwidth and launch high - range far and by all means, stay thirsty my friends. ... Kev.
KevinSharbonda is offline Find More Posts by KevinSharbonda
Old Feb 29, 2012, 10:38 AM
sporter is offline
Find More Posts by sporter
Come out swinging
sporter's Avatar
San Diego
Joined Mar 2005
Lucky you. I wish that would happen to me...
Sean
sporter is offline Find More Posts by sporter
Old Feb 29, 2012, 12:18 PM
eschlitzkus is offline
Find More Posts by eschlitzkus
eschlitzkus's Avatar
Stewartstown PA
Joined Oct 2005
Sounds good Kevin! If you want to learn how to use my CNC router to make some wings and tails that OK with me. Just give me some parts for the use of it .I just don't have the time to do make scale planes and DLG stuff. Would like to see you do some 3D cores on it. Maybe someone will give you some code that you can use.
Erich
eschlitzkus is offline Find More Posts by eschlitzkus
Old Feb 29, 2012, 04:53 PM
Make Flying Fun
Joined May 2003
Sounds like a plan Eric, ... trolling for some code now I suppose!
Old Feb 29, 2012, 05:10 PM
samc99us is offline
Find More Posts by samc99us
Aurora Builder
United States, MD, Lusby
Joined Nov 2003
Number of people in the area can generate code...
samc99us is offline Find More Posts by samc99us
Old Feb 29, 2012, 05:15 PM
Kenny Sharp is offline
Find More Posts by Kenny Sharp
turn, turn, turn.
Athol, Massachusetts
Joined Oct 2005
Congratulations Kevin.
Couldn't happen to a nicer guy.
Kenny Sharp is offline Find More Posts by Kenny Sharp
Old Mar 06, 2012, 07:54 AM
Make Flying Fun
Joined May 2003
Thanks guys, staying tuned ! Cut some cnc cores yesterday and locked in the basement for a while! Trying some experiments that have been on the back burner for a whiile.
Old Mar 06, 2012, 07:59 AM
soholingo is offline
Find More Posts by soholingo
BANNED!!!
soholingo's Avatar
Laurel, MD
Joined May 2001
Kevin,
You have won! Congrats!
J
soholingo is offline Find More Posts by soholingo
Old Mar 06, 2012, 08:05 AM
tom43004 is offline
Find More Posts by tom43004
Father of Fr3aK, DLG Pilot
tom43004's Avatar
USA, OH, Worthington
Joined May 2002
Nice.
tom43004 is offline Find More Posts by tom43004
Old Mar 06, 2012, 01:06 PM
Make Flying Fun
Joined May 2003
Ditto Tom, I just read your treatise on tail and boom moments over in Jiim's group build thread, excellent!
I did some straight math on tail sizing when I did the design for the Fr3aK, which is where the tails come from. This is the second generation of tails on the Fr3aK with very similar sizing but different shapes and airfoils. The smaller tails on the Edge are designed to provide adequate stability and control when at 660mm. The horizontal on the Fr3aK was scaled up a bit under 10% as I wanted to keep the overall length of the boom a bit shorter. It will fly great at 630 or 660mm, whichever you choose. I have flown both with these tails. They are different but not significantly for the most part.
That's the simple explanation. Here's the nitpicky stuff.
Longer tail moment means more noseweight, and that increases the radius of gyration of the aircraft after release, resulting in a pinch more tail wag. It typically increases damping in the pitch axis as well, which results in an airplane that doesn't "show" active air quite as well. Larger tails allow you to carry a more aft CG position if you'd like, which alot of the expert pilots prefer, without the airplane getting "pitchy." The larger tail with an aft CG will have plenty of controllability with very little elevator deflection, which creates less drag when maneuvering. Larger tails also give better controllability as your airspeed decreases, which can bail you out of situations when you're not flying "perfectly" because of turbulence, distance, or generally nervous thumbs.
Wherever you choose to put them (within reason) will result in a decent flying model. Remember that 30mm is only a bit over an inch, so we're not talking about an order of magnitude difference. In theory, assuming linear scaling, my tails are still quite a bit oversized even at 630mm considering that the 30mm difference in length (4.5%) is smaller than the sizing difference (8.4%)
I think it's important for you guys to build them similarly, and I would defer to Jim for that decision. We had a brief conversation about the boom length a couple of weeks back but it wasn't very detailed.
Found Open Pilot CC Board Casey_S Aircraft - Electric - Multirotor (FS/W) 4 Feb 23, 2012 09:30 PM
For Sale open pilot board, paris v3 board, motors, props, escs, & dx6 (transmitter).how much$? jtbullet Aircraft - Electric - Multirotor (FS/W) 9 Jan 02, 2012 03:15 PM
Retired Heli pilot trying to comeback with GWS model. Comments appreciated... jasonsjwou Parkflyers 21 May 21, 2003 11:07 PM
