View Poll Results: Elevon Location?
Outer most part of the Wing? 17 50.00%
Next Angle in from the outer most part? 17 50.00%
Voters: 34. You may not vote on this poll
Old Dec 31, 2012, 07:55 AM
DelRay is offline
Find More Posts by DelRay
"Spike"
DelRay's Avatar
Cedar Rapids, Iowa
Joined May 2010
Jeeeesh................
Thanks for that info Lee, very interesting.
Now, I have even more doubts if my B-2 is going to fly, I'm sure it's not even remotely close to any of the specs you've mentioned.
DelRay is offline Find More Posts by DelRay
Old Dec 31, 2012, 08:09 AM
xlcrlee is offline
Find More Posts by xlcrlee
Joined Apr 2006
Of COURSE it will!!
And the more attention to detail, incl.those I mentoned, the better it will.
....but fly it will [sorry, Yoda]
xlcrlee is offline Find More Posts by xlcrlee
Old Jan 17, 2013, 06:55 AM
DelRay is offline
"Spike"
DelRay's Avatar
Cedar Rapids, Iowa
Joined May 2010
My B-2 wants to be one..............
Slowly, the progress is going forward to completion. Adding the retracts set the schedule back a little, but I'm hoping it'll be worth the time and effort.
It's foam, and being on the build table for so long, it's received more than it's share of hangar rash, so I'm doing a little fill n' sand with light weight filler before prepping it for the color coat.
I've got the plastic canopy and air scoops cut out and shaped and ready to epoxy onto the wing, I think they add a lot of pazazz to the project, and I'm trying to copy Josh's as closely as I can.
The wheel wells were filled in with some block foam I had, I made patterns and installed them through the openings in the wing. This would have been a lot easier if I was installing the retracts on the start of the project before the top sheeting was down, but it worked out.
When I bought the retracts and struts from a club member I never thought I'd be using them so soon, they're perfect for the B-2, and the price was perfect also.
My first plan was to "maiden" it before going on to the finishing/detailing steps, well, that plan got changed and changed again.
I'm hoping to have it finished and ready for the mall show in March, I'll probably wait to "maiden" it until after the mall show just in case I break it.
Old Jan 17, 2013, 03:24 PM
Jmurdock is offline
Find More Posts by Jmurdock
PecanPatch's Son
Jmurdock's Avatar
USA, GA, Griffin
Joined Feb 2011
Awesome! Looks great
Jmurdock is offline Find More Posts by Jmurdock
Old Jan 17, 2013, 04:45 PM
pecanpatch is online now
Find More Posts by pecanpatch
Home of "Golf Cart Flying"
pecanpatch's Avatar
Griffin GA
Joined Aug 2008
Thanks for sharing Jim.... am I gonna have to fly up to Iowa and test hop that thing for ya?
pecanpatch is online now Find More Posts by pecanpatch
Latest blog entry: 6th Annual South Eastern FPV...
Old Jan 18, 2013, 07:00 AM
DelRay is offline
"Spike"
DelRay's Avatar
Cedar Rapids, Iowa
Joined May 2010
There's no anchor attached to your backside, is there?
Mark, that would make my day, c'mon up and let's get er' done.
Be sure to bring Josh and his B-2 along, we'll get some formation flights in.
The topside is all precoated for final finish, now to do a little fill n' sand and precoat on the bottom.
I filled in the two slots in the air scoop pieces , just some minor fill n' sand there and they're ready for paint.
Today I'm going to cut the back portion of the canopy, get it shaped and ready for paint. I've got some large chunks of nice foam, I think I'll use some of it for this piece.
Mark, let me know what time your flight arrives, I'll be at the airport to pick y'all up.
Old Mar 17, 2013, 06:38 AM
DelRay is offline
"Spike"
DelRay's Avatar
Cedar Rapids, Iowa
Joined May 2010
Gettin' closer, a little bodywork goin' on ..
Wow, I look at the dates on the beginning of this build thread and it's been a year already. Time flies when you're havin' fun.
I did finally get the 3000mah battery from Grayson, it's a little different in size, but fits the canopy perfectly.
I was surprised when I called the hobby shop and she had three cans of Testors Gunship Grey paint, so I have that waiting to be applied after the maiden flight.
I still have to get the C.G. set and then it's ready to fly.
Then I'll finish the plug for the rear of the canopy and apply the gunship grey paint.
This project has taken me a little longer than I thought it would, but stuff happens.
I hope mine looks and flies as good as Josh's, thanks Josh for a fun project.
Old Mar 17, 2013, 07:17 AM
pecanpatch's Avatar
Griffin GA
Joined Aug 2008
It looks Fantastic Jim!
Old Mar 17, 2013, 08:22 AM
Jmurdock is offline
PecanPatch's Son
Jmurdock's Avatar
USA, GA, Griffin
Joined Feb 2011
Looks Great!
Old Mar 20, 2013, 10:05 AM
pecanpatch's Avatar
Griffin GA
Joined Aug 2008
Josh's B2 had one engine acting up... we have to get her ready for SEFF.
I snapped a coupla shots of the lexan vertical fins we installed. We proved it would fly with out them. But now he is ready to just have fun.
Old Mar 21, 2013, 06:20 AM
DelRay is offline
"Spike"
DelRay's Avatar
Cedar Rapids, Iowa
Joined May 2010
Fins....
A little P.M. now is time well spent, one doesn't need the workbench time at an event.
The twin fins look great, they won't be that easily seen being clear, but what the heck, if they improve flight performance.
Maybe there will be another B-2 at SEFF, hopefully, someone has been building stealthy.
Old Apr 04, 2013, 06:03 AM
DelRay is offline
"Spike"
DelRay's Avatar
Cedar Rapids, Iowa
Joined May 2010
Patio paint shop......
The weather is finally letting me get outside for a little paint work on the B-2, the smell is a definite NO-NO in the basement, per the wife's orders.
I did sneak a few small spots awhile back, thought I'd better not press my luck.
I've found that the white, light weight spackling compound doesn't make good fillets for me, it tends to crack out. I'm using a water based , natural color wood filler by Ace. It smoothes out nicely and sands easily, and stays where it's put.
The primer is light weight, fast drying, and sands very easily. It helps fill in some of the dings, etc. I need to remember this is foam and it ain't gonna ever be perfectly smoothe.
The final color coat of gunship grey and detailing will come after the test flight, which will be soon if the weather continues to improve.
Old Apr 04, 2013, 06:15 AM
gpw is online now
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
Looks SUPER Del !!!
gpw is online now Find More Posts by gpw
Old Apr 30, 2013, 09:56 PM
lv2soar is offline
Find More Posts by lv2soar
Los Angeles, CA
Joined Mar 2004
How many sheets of FFF foam required for this plane? Thanks
lv2soar is offline Find More Posts by lv2soar
Old May 01, 2013, 03:53 AM
pecanpatch's Avatar
Griffin GA
Joined Aug 2008
4
the leading edge is the original fold in the material.
So you need 2 sets. Make sure you also orient the ugly writing to the inside as well.
Added a few pics of B-2 Bomber Art Newland Electric Plane Talk 8 Jul 17, 2010 03:19 PM
B-2 bomber by Chris Golds LotusTRBO Electric Ducted Fan Jet Talk 287 Nov 12, 2008 09:01 AM
B-2 fanfold stealth bomber livingwater Foamies (Kits) 14 May 17, 2003 08:12 AM
B-2 stealth bomber question livingwater Foamies (Kits) 4 May 08, 2003 08:02 PM
F/S Electric Park Flyer B-2 Bomber NIB! CLARKE Aircraft - Electric - Airplanes (FS/W) 0 Mar 22, 2002 04:22 PM
