View Poll Results: Elevon Location?
Outer most part of the Wing? 17 50.00%
Next Angle in from the outer most part? 17 50.00%
Voters: 34. You may not vote on this poll
Old Feb 29, 2012, 08:05 AM
PecanPatch's Son
Jmurdock's Avatar
USA, GA, Griffin
Joined Feb 2011
B-2 Bomber
Alright My First Build thread. Go easy on me.
I'm going to attempt to build a B-2 Bomber. I'm going to build it very similar to the way we have been building the Paintball Wing. http://www.rcgroups.com/forums/showthread.php?t=1551613
I'm going to not try to big deal it and Keep it pretty simple. But I do want dual motors with thrust differential for yaw, since the B-2 has no rudder(s) and to try to keep from losing to much altitude when I'm in a bank. Plus I just think it would be cool.
So, more info and pictures coming later. I could probably get the pdf plans posted later if anyone is interested, and I gotta get to the Perry RC swap meet this weekend and try and get some electronics for it.
Jmurdock is offline Find More Posts by Jmurdock
Old Feb 29, 2012, 08:13 AM
PecanPatch's Son
Jmurdock's Avatar
USA, GA, Griffin
Joined Feb 2011
The "plans" were created by Pecanpatch and basically just took a aerial photo of the plane and dumped it in auto-cad, traced it, and printed it. So I'm figuring it out as I go along.
Old Feb 29, 2012, 08:19 AM
PecanPatch's Son
Jmurdock's Avatar
USA, GA, Griffin
Joined Feb 2011
I'm going to attempt a poll. Why wouldn't I?
Originally I planned on putting the elevons on the outer most part of the wing. But now that I have it cut out. The outer most part of the wing is pretty thin and if I cut elevons out of them they would be really skinny. So, now I'm thinking I'll put them on the first angle in from the outer most part of the wing, since there is so much more room there for them. Also they would get prop wash on them there. So make sure and vote.
Old Feb 29, 2012, 10:18 AM
GoldCraft's Avatar
Hickory Flat , Ga.
Joined Jan 2007
I like it...cant wait to see more.
GoldCraft is offline Find More Posts by GoldCraft
Old Feb 29, 2012, 11:10 AM
One with the machine
X--ALIEN--X's Avatar
Antarctica
Joined Jul 2010
Cool
X--ALIEN--X is offline Find More Posts by X--ALIEN--X
Old Feb 29, 2012, 12:48 PM
Flite Test Fanclub Dictator
Flying-Monkey's Avatar
USA, FL, Miramar Beach
Joined Nov 2005
Where are the duckerons?
http://media.photobucket.com/image/d.../Duckerons.gif
Flying-Monkey is offline Find More Posts by Flying-Monkey
Old Feb 29, 2012, 02:17 PM
PecanPatch's Son
Jmurdock's Avatar
USA, GA, Griffin
Joined Feb 2011
I considered doing those for yaw control, but with the dual motors with thrust differential I feel like i'll have efficient yaw control. Plus I'm trying to not make it a super detailed build. Like the paintball wing I want it to be simple. I may regret it and start over one day, but I want to have this one ready for Seff in time.
Old Feb 29, 2012, 02:21 PM
PecanPatch's Son
Jmurdock's Avatar
USA, GA, Griffin
Joined Feb 2011
Also I've never felt that airbrakes, although they are cool, were ever worth the trouble. But if and when I build a second one. It will have duckerons, airbreaks, dual motors, etc.
Old Feb 29, 2012, 03:03 PM
Total Noob
bkboggy's Avatar
United States, CA, Yucaipa
Joined Nov 2008
RCGroups build log:
http://www.rcgroups.com/forums/showt...ight=Simple+B2
Also:
Source: http://www.wattflyer.com/forums/showthread.php?t=32591
-BK
bkboggy is offline Find More Posts by bkboggy
Old Feb 29, 2012, 04:08 PM
gpw
“There’s no place like Foam”
gpw's Avatar
Joined Jul 2002
This one flies very well ... Simple ... http://www.rcgroups.com/forums/showt...=simple+b2+gpw
gpw is offline Find More Posts by gpw
Old Feb 29, 2012, 06:29 PM
Revo Dave's Avatar
Newnan, GA
Joined Feb 2010
Looking good Josh. You are a pioneer!
Revo Dave is offline Find More Posts by Revo Dave
Old Feb 29, 2012, 08:20 PM
PecanPatch's Son
Jmurdock's Avatar
USA, GA, Griffin
Joined Feb 2011
I also want the prop slits inside of the wing, I don't want the prop hanging off the back. But good references though.
Old Feb 29, 2012, 09:44 PM
I wish I was a bird.
electrich's Avatar
United States, GA, Atlanta
Joined Feb 2011
Looking good Josh. Can wait to see ya golf cart it
electrich is offline Find More Posts by electrich
Old Mar 01, 2012, 11:19 AM
"Spike"
DelRay's Avatar
Cedar Rapids, Iowa
Joined May 2010
I'm excited.........
Way to go Josh, two thumbs up,
I will be following this build very closely, looks like a fun project, indeed one that will be different at the field.
I've got a small twin motor plane that uses motor speed diffetrential for directional control. Very small motors, I wonder if I can use any of it for this project, probably not.
I'm anxious to see what you come up with as far as electronics.
Here's a print I did up that shows the basic placing of parts for Josh's B-2
I drew it up as I was building mine. Let me know if you see any errors or have any additions.
C.F. LEADING EDGE PLACEMENT+ As shown on print is where I placed mine, although moving the c.f. rods rearward, closer to the main spar will allow lifting the l.e. per Josh's build.
The c.f. rods placed as shown on the print pretty much dictate a flat bottom wing shape, without much allowance to pull up the l.e. towards a more semi-symmetrical shape.
Moving the l.e. more towards a semi-symmetrical shape also adds back top sheet length that is lost due to the main spar height.
On mine the top sheet comes out about 3/8 to a 1/2 inch shorter when meeting with the bottom sheet at the t.e. center. This is not a big issue, but one you can plan for in advance.
DelRay is offline Find More Posts by DelRay
Old Mar 01, 2012, 04:11 PM
Home of "Golf Cart Flying"
pecanpatch's Avatar
Griffin GA
Joined Aug 2008
I'm not sure of the wingspan of these B2's you guys posted up....
But this one jmurdock is building is the max size you can get out of a piece of 24 x 48 foam. (for one side of plane)
We are going to set him up with a v-tail mixer for the differential thrust sort of like in the "Twins" build thread.
pecanpatch is offline Find More Posts by pecanpatch
Added a few pics of B-2 Bomber Art Newland Electric Plane Talk 8 Jul 17, 2010 03:19 PM
B-2 bomber by Chris Golds LotusTRBO Electric Ducted Fan Jet Talk 287 Nov 12, 2008 09:01 AM
B-2 fanfold stealth bomber livingwater Foamies (Kits) 14 May 17, 2003 08:12 AM
B-2 stealth bomber question livingwater Foamies (Kits) 4 May 08, 2003 08:02 PM
F/S Electric Park Flyer B-2 Bomber NIB! CLARKE Aircraft - Electric - Airplanes (FS/W) 0 Mar 22, 2002 04:22 PM
