Old Feb 29, 2012, 07:24 AM
justincredibleg is offline
Find More Posts by justincredibleg
United States, TN, Knoxville
Joined Feb 2012
Help!
5Ch BlitzRCWorks F-16 Pro 3D Thrust Vectoring 64mm EDF
Hello all, regular vistor first time poster! I just bought the BlitzRCWorks 5Ch F-16 64mm EDF:
http://www.bananahobby.com/2141.html
It came in yesterday and despite the lack of instructions I was able to get it pieced together. I am using a DX6i and AR6210 with satellite.
Here is where I need help. On the website it says you can switch the thrust vectoring on and off. Here are the servo leads that are running to the front:
1 - Left Aileron & Left Elevator(elevon?)
2 - Right Aileron & Right Elevator/elevon
3 - Throttle
4 - Rudder/steerable wheel
5 - Up/Down Vectoring
6 - Left/Right Vectoring
On my receiver I have
Bind Data
Throttle
Aileron
Elevator
Rudder
Gear
Aux 1
Which ports should I plug each servo into?
How can I set up my DX6i to allow me to turn vectoring on and off.
Do I have to get a Y - harness for my two separate aileron servo leads?
Thanks in advance everyone!
justincredibleg is offline Find More Posts by justincredibleg
Old Feb 29, 2012, 11:03 AM
Joined Feb 2012
Also, how do I set it up so that the elevator controls elevation if the ailerons and elevators are on the same channel?
Old Feb 29, 2012, 08:29 PM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
You will have much better luck posting this, in here. http://www.rcgroups.com/foamy-edfs-377/
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Feb 29, 2012, 08:38 PM
Joined Feb 2012
Ok, I will try there. I thought that since this category said "Discussion of topics unique to EDF RC airplanes, including assembly, setup, power systems, and flying techniques" that this would be the place to post.
Old Mar 02, 2012, 11:28 PM
pedrobraulio is offline
Find More Posts by pedrobraulio
Joined Feb 2012
F16 5ch TV how to program Futaba 7ch?
Just received the thunderbird version of this F16 5ch 64mm from banana hobby and don't know how to make the thrust vector work with my Futaba 7ch so please anyone help me out! Plane is all set and looks awesome everything came nice in place and is all set except TV.
pedrobraulio is offline Find More Posts by pedrobraulio
Last edited by pedrobraulio; Mar 03, 2012 at 12:56 AM. Reason: Need HELP F16 5Ch Thrust vector with Futaba 7ch
Discussion Banana hobby 5 CH 64mm BlitzRCWorks Thunderbird F-16 Pro 3D Thrust Vectoring RC Fight arsovhome Foamy EDFs 14 Apr 14, 2015 11:19 AM
Build Log M64mm EDF F-16 arrowking Scratchbuilt EDFs 64 Nov 15, 2012 10:24 AM
Discussion F-22 Dual 64mm EDF with Thrust Vectoring nez_fer Foamies (Scratchbuilt) 13 Oct 24, 2012 05:19 PM
Discussion blitzrcworks 5 channel f16 with thrust vectoring ramboner Foamy EDFs 9 Aug 06, 2012 11:19 AM
Discussion Need help wiring up Thrust Vectoring on f-16 Rone3 Foamy EDFs 10 Jan 07, 2012 01:42 PM
