Old Feb 05, 2013, 10:35 AM
staib is offline
Find More Posts by staib
staib's Avatar
London,UK
Joined Jun 2001
Originally Posted by Stitch1615 View Post
.. It would help if you know what is front and rear on the screen. On most quads I see the red blades on the front so I am assuming that is the front...
You are right. The virtual quad model is facing 'into' the screen, so the red rotors are further in and partially hidden... It's so you can see the virtual quad move the same way as you move the real one, just to check the gyros are all sensing movement correctly...
staib is offline Find More Posts by staib
Old Feb 05, 2013, 02:39 PM
fantomphish is offline
Find More Posts by fantomphish
gold coast
Joined Jan 2010
here's my current setup on my ifly-4s since I see theres a bit of talk about different FC's
http://www.rcgroups.com/forums/showp...&postcount=216
fantomphish is offline Find More Posts by fantomphish
Old Feb 05, 2013, 09:14 PM
vichito is offline
Find More Posts by vichito
vichito's Avatar
Caracas,Venezuela
Joined Jan 2004
Problems with my Ifly-4
Hello, I cant do that the Ifly-4 arm the motors.
I dont have to do
upgrade the firmeware and nothing.
Ideafly ifly-4 (2 min 8 sec)
Thank you
I hope you can understand may poor english
vichito is offline Find More Posts by vichito
Old Feb 06, 2013, 03:12 AM
Matt Halton is offline
Find More Posts by Matt Halton
Wannabe B-26 pilot!
Matt Halton's Avatar
Southwold, Suffolk, UK.
Joined Nov 2002
Did you try moving the rudder stick to the right to arm the board?Worth a try...
Seems that everyone who has attempted to install the latest firmware are having problems like this?
Getting the IFLY staff to comment and assist on here is becoming rarer and rarer...I'd hoped they'd want to show support to buyers of their products ...
Matt Halton is offline Find More Posts by Matt Halton
Old Feb 06, 2013, 03:50 AM
discv is offline
Find More Posts by discv
United Kingdom, England, Croydon
Joined Jan 2013
I dont have to do
Thank you
I had a similar problem. I forgot to 'write' after calibrating. Motors will not arm if full rudder is not seen by the FC. Motors will also not arm unless throttle is right down.
Tony
discv is offline Find More Posts by discv
Old Feb 06, 2013, 04:35 AM
Wannabe B-26 pilot!
Joined Nov 2002
Anyone in the UK getting frustrated by the endless windy days? My local forecast indicates no change until the middle of February.....I just want to get out there and fly, but all efforts to do so are continually thwarted by this rotten weather
Old Feb 06, 2013, 04:41 AM
dazza44 is offline
Find More Posts by dazza44
who put that tree there
dazza44's Avatar
Joined Jun 2010
Originally Posted by Matt Halton View Post
Anyone in the UK getting frustrated by the endless winds days? My local forecast indicates no change until the middle of February.....I just want to get out there and fly, but all efforts to do so are continually thwarted by this rotten weather
ditto..
no let up for ages..
dazza44 is offline Find More Posts by dazza44
Old Feb 06, 2013, 04:48 AM
Wannabe B-26 pilot!
Joined Nov 2002
Originally Posted by dazza44 View Post
ditto..
Annoying....So, decided to start building my Q450 quad instead, probably wise, as knowing luck and how it can be, when the weather does improve it's likely my '4 will be unservicable or something so wise to have a back up!
IFLY -4 is now in the HK UK warehouse if anyone wants to know
Old Feb 06, 2013, 04:57 AM
dazza44 is offline
dazza44's Avatar
Joined Jun 2010
heres a buddycode for a tenner of it too(uk
http://www.hobbyking.com/buddy.asp?c...9-2DD03AA904ED
just built a 450 clone with naza tested in garden with the wind (i couldnt wait)
got a whole box full of foam sheets build build build!!!
as if i iant got enough need a bigger house soon
Old Feb 06, 2013, 05:19 AM
Wannabe B-26 pilot!
Joined Nov 2002
How's the Naza for you? I want one but no funds as yet..
Going to use a KK2 board in mine, see how it goes. I read you on the building, winter means you can't do a lot else!
Have fun!
Matt
Old Feb 06, 2013, 05:48 AM
staib is offline
staib's Avatar
London,UK
Joined Jun 2001
Oh yes... but meanwhile I have been trying to get my head around using Virtualdub and the deshaker plugin. It's not the easiest software to use (it's downright daunting, to be honest), but test output is looking promising...
Just need it to read my flying camera's mov files, rather than the test avi files...
Old Feb 06, 2013, 05:49 AM
dazza44 is offline
dazza44's Avatar
Joined Jun 2010
Have fun!
Matt
bought a used naza with gps had a brief go in the garden held a hover very good in the wind.
got a crius aiop with gps im still setting up on turnigy h.a.l frame.
and in process of building a sopwith swallow foamie..
Old Feb 06, 2013, 05:57 AM
h.300 is offline
Find More Posts by h.300
h.300's Avatar
France, Aquitaine, Bordeaux
Joined Dec 2012
same for me in France, we have the same rotten weather
I have not yet tried the monster
h.300 is offline Find More Posts by h.300
Old Feb 06, 2013, 06:13 AM
Wannabe B-26 pilot!
Joined Nov 2002
Nick, I hope you get that working, I gave up, it only reads avi files so after converting, then run 2 passes of deshaker, but it uses phenomenal amounts of memory, something like 16 gigabytes on each pass the last time I tried...Must be missing something, but there must be easier ways to remove shake?
Let us know how you get along with it please?
Old Feb 06, 2013, 06:15 AM
Wannabe B-26 pilot!
Joined Nov 2002
Interesting, how much was the S/H Naza?
I used to build a lot of foamies such as you're doing, I still have tons of Depron, I'd really like to build something like the transport bicopters as seen in the last Resident Evil incarnation, they look really cool!
Wanted PARIS - MultiWiiCopter aerial photography board mcguyver9111 Aircraft - Electric - Multirotor (FS/W) 3 Feb 25, 2012 10:42 PM
Wanted PARIS - MultiWiiCopter aerial photography board - v4.0 LLC semi-naked or populated mcguyver9111 Aircraft - General - Miscellaneous (FS/W) 1 Feb 23, 2012 02:18 PM
Discussion S-606 Aerial photography combo/TMF Pro FC batusaix Multirotor Talk 7 Feb 03, 2012 03:39 AM
Discussion Vimeos Group Aerial photography & video also on facebook aeropics Aerial Photography 0 Sep 12, 2011 02:25 PM
Discussion Use of RC Aircraft for Aerial Videos and Photography BJADA Aerial Photography 1 Sep 06, 2011 04:35 PM
