Latest blog entry: Win a frame
![]() Quote:
![]() I finished and tested my tilt cam for my GoPro today, am pleased to say it works great, no vibes at all. Here's a short video proving the fact ![]()
Now I can't wait to try this outside...Weather in the UK in Nov..usually not good, so hopefully soon... Matt. |
I have 2 ifly esc's that aren't doing me any good if anyone want them pm me pay for the shipping and they are yours
Joined Oct 2012
![]() Weather is keeping me grounded too atm although still need to get a replacement propellor nut as the ones I did get were from an older iFly type so weren't the correct size. Probably going to just have to find and use a steel replacement untill I can get some official ones. Getting better on the sim though ![]() Regards, S. |
![]() S: Sorry to hear of your bad luck regarding the prop nuts, was it unmanned who supplied the nuts? Maybe send them back and ask them to send the later model ones when they come in? Good to hear your sim flying is improving ![]() I might get another outdoor test flight in today: Doesn't look too bad atm. I didn't use the Scholl gel inserts, my brother has his own shoe repair business, I got the foam from him (the grey stuff) for free as they are offcuts. The yellow foam my camera sits on is glued using rubber cement-UHU POR. Any foam safe contact cement will do. Remember to cut the holes in the foam big enough to clear your bolts, as you should avoid the bolts coming into contact with the foam, as it will reduce vibration even further. Don't forget to check the balance of your props and adjust as necessary. Here's some pics of my camera mount, and an explanation of how I did it. I hope that helps! Matt
| Thread Tools | |
| Wanted PARIS - MultiWiiCopter aerial photography board | mcguyver9111 | Aircraft - Electric - Multirotor (FS/W) | 3 | Feb 25, 2012 10:42 PM |
| Wanted PARIS - MultiWiiCopter aerial photography board - v4.0 LLC semi-naked or populated | mcguyver9111 | Aircraft - Electric - Miscellaneous (FS/W) | 1 | Feb 23, 2012 02:18 PM |
| Discussion S-606 Aerial photography combo/TMF Pro FC | batusaix | Multirotor Talk | 7 | Feb 03, 2012 03:39 AM |
| Discussion Vimeos Group Aerial photography & video also on facebook | aeropics | Aerial Photography | 0 | Sep 12, 2011 02:25 PM |
| Discussion Use of RC Aircraft for Aerial Videos and Photography | BJADA | Aerial Photography | 1 | Sep 06, 2011 04:35 PM |
