Old Feb 29, 2012, 01:25 AM
R31 Mark is offline
Find More Posts by R31 Mark
amidoinitrite¿ ¿
R31 Mark's Avatar
Joined Feb 2012
Idea
Do you think this would work?
Hey all, I want to make a 20" ish wingspan model of something like a Fokker DVI (I have the Walt Mooney plans for it). Anyway, I was thinking that maybe instead of the usual electric motor route of doing things I could make this a bit different. By way of powering it with a cox 049 or there abouts. But the real idea is this, I thought about what to use as a throttle servo and then all of a sudden I was hit by an idea, basically Flyzone playmate guts. But this is where it gets interesting, cut the motor wires and solder them to a servo, possibly one of similar size to the factory ones. But would it be strong enough to open and close an 049 throttle? and would this even work? I dont have much to spend ($100ish max), can anyone reccomend some cheap electronics that would work instead? So what are peoples opinions?
R31 Mark is offline Find More Posts by R31 Mark
Old Feb 29, 2012, 06:02 AM
PeteSchug is offline
Find More Posts by PeteSchug
PeteSchug's Avatar
Elmhurst, NY (Queens in NYC)
Joined Apr 2004
.049 is VERY BIG for a plane of that size even with a throttle.
Also, there is very little likelihood that the motor wires carry servo information.
MAYBE the input to the ESC has a servo type signal, but that's not guaranteed either.
I'd guess that something around 30 to 36 inches might be more suited to the power of an .049
All of the above is just my opinion.
Pete
PeteSchug is offline Find More Posts by PeteSchug
Old Feb 29, 2012, 08:40 AM
billyjim is offline
Find More Posts by billyjim
billyjim
Cullman, AL
Joined Jun 2007
MARK: I agree with Pete ... an .049 is way too big. More like a Cox TD 010 or maybe an 020.
But my biggest concern is going to a glow fuel engine, rather than electric. I flew all my ultramicro planes back in the '60s and early '70s using an 010 --- but, Man! -- the mess the exhaust made all over the plane ---- they're not called "slimeys" for nothing. Also once the plane's surfaces are coated (with even only a fine mist of fuel oil), and then there's crash damage that must be repaired, it's no fun cleaning all the surfaces with alcohol or other cleaner, to prepare the damage so it can be glued back together.
I admire your ambition to do a 'retro' but it ain't for me -- been there, done that..
Bill
billyjim is offline Find More Posts by billyjim
Old Feb 29, 2012, 02:23 PM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
keep in mind the cox .049 weighs more than the plane does once you figer in fuel.
i say go for it. but you will have a few critical problems here.
1. the oil in the fuel makes a slime on the plane that tends to eat paint.
2. you will need a pwm to ppm converter. homefly or bsdmicrorc has one, or you could go DIY.
3. a 049 is made for a plane in the 10 oz area, or about 290 grams.
4. a cox .010 is a better idea, but expensive. a cox 0.20 is good, but are a pain to run right. best bet is to buy one new, about 60usd. (still might not be any better.)
5. a cox .020 is mostly a low and hi throttle. assuming you have a exhast choke.
try posting on the cox engine forum.
if you really want to do this, scale the plan up to the 24-36 inch mark. keep in mind a cox .049 puts out a lot of thrust. you better off in the park flyer forum for this, tho.
nemoskull is offline Find More Posts by nemoskull
Old Feb 29, 2012, 07:58 PM
R31 Mark is offline
amidoinitrite¿ ¿
R31 Mark's Avatar
Joined Feb 2012
Hmm wise words indeed. I think I'll go for a 020 if I can spot one on ebay. Mind if I ask what exactly a "pwm to ppm converter" is and what it does?
Old Feb 29, 2012, 10:36 PM
Laramie is offline
Find More Posts by Laramie
San Bernardino California U.S.A.
Joined Dec 2009
They took the words ...
... right outta my mouth!
I'm with you, in so far as the whole engine v.s. motor thing goes (me, I like "internal combustion engines"), but they voiced all my concearns, burnt glow fuel is nasty stuff! A cox 1/4A engine requiers a lot of nitro too. It gets "all bad & ugly" in so far as paint & nitro goes.
Me, I'm switching to electric (although I hate it!), for just about all the reasons they brought up, I strongly recomend that you "make it easier on yourself" & consider E-Power too.
Well, there's my 2 cents worth,
Laramie.
Laramie is offline Find More Posts by Laramie
Old Mar 01, 2012, 09:10 AM
CorvetteC5 is offline
Find More Posts by CorvetteC5
CorvetteC5's Avatar
Kokomo, Indiana
Joined Jun 2008
I agree with the mess created by the fuel. I don't miss thoughs days
However, my first concern with this idea is the vibration from the engine over taxing the micro RX/servos circuitry and causing it to fail. Before I went all electric the servos would be isolated from the plane with rubber grommets, and the receiver was wrapped in soft foam. Not sure how effective these methods will be for the 1-piece brick proposed
FWIW
CorvetteC5 is offline Find More Posts by CorvetteC5
Discussion What to do if you think a customer is lying? Neil Stainton Vendor Talk 6 Feb 29, 2012 04:03 PM
Discussion what do you guys think of this clone dynam 3D Flying 0 Feb 29, 2012 12:04 AM
Discussion What do you think about this? Conversion to Lipo on Sumo 1/24 AmazingRCstore Micro Cars 0 Feb 25, 2012 03:18 PM
Discussion I think this combo will work with this plane, do you? FlyingLakland Power Systems 8 Dec 01, 2008 11:08 PM
Discussion do u think this would work leliommarino Scratchbuilt Indoor and Micro Models 0 Jul 08, 2008 03:14 PM
