Espritmodel.com Heli Air
Old Feb 28, 2012, 10:36 PM
Melbourne, Australia
Joined Apr 2008
Skyartec 705 Buddy / Trainer setup
I have two Tx705 transmitters and would like to couple them together in a Master / Student configuration.
I have two issues:
1. What sort of cable do I need to couple the controllers together? Does anyone have a pinout diagram?
2. Using the SKY705_V2 software I have configured the two transmitters as per instructions, as Master and Student with the s/n as required. Not having a cable, I turned on the Master controller by itself and found that it no longer communicates with the Rx. Is this because it is not coupled to the Student Controller?
Any advice on how to use the Trainer mode would be appreciated.
ZippoZ is offline Find More Posts by ZippoZ
Old Mar 01, 2012, 02:10 AM
Pontiac/Auburn Hills, Michigan USA
Joined Dec 2008
I have two issues:
these are most excellent questions. I hope we can get some more information from the factory. i have not seen the trainer cable available on our distributor price lists, but will check with the factory
Update: according to the factory agent, the two transmitters link using the radio signal and do not require a cable to connect the Master to the Student; sorry I missed this one totally, as i though they would require a cable;
I will try to get the next one right!
Regards
Max
www.parkrcmodels.com
Parkflying is offline Find More Posts by Parkflying
Site Sponsor
Old Mar 13, 2012, 03:32 PM
Joined Feb 2006
Regards
Max
It is no cable for it. It use 2.4g system.
When you set up the studend and master, we just pull the master left switch.It will take the student 2.4g singal and control the rc product.
skyartec is offline Find More Posts by skyartec
Old Mar 17, 2012, 06:05 AM
Joined Apr 2008
Thanks for your help. I have it working now.
What threw me off was that I thought the "Master" Transmitter would be communicating with its Rx that it is bound to. But instead it is the "Student" Transmitter and its Rx that are controlling the plane.
Old Mar 23, 2012, 06:28 PM
Australia, QLD, Booyal
Joined Aug 2011
How do you set up the student master setup? It would be useful to use to teach some of the kids who go to the school next door. I fly on the oval and always attract a crowd when I fly after school
scrubmonkey is offline Find More Posts by scrubmonkey
Old Mar 23, 2012, 09:01 PM
Joined Dec 2008
Using the Skyartec Software you configure the Trainer Master and Student in each transmitter with the options on the Information Tab of the Software. Only the Sky705 or Sky706 have this option. Once both are setup the connection between them is wireless, no cable necessary
Regards
Max
www.skyartec-usa.com
Site Sponsor
Old Mar 24, 2012, 04:43 AM
Joined Aug 2011
Is there any way to wipe the transmitter and then re program it or something? The cable was broken that connected it to the computer and it kept on shorting across or some thing like that bu the cable is fixed and tested but it says that the tx is corrupt or along those lines. It still works fine with the plane though.
Old Mar 24, 2012, 06:26 AM
Joined Dec 2008
Do you have the Sky 705 or the Sky 706 Transmitter?
Regards
Max
Site Sponsor
Old Mar 24, 2012, 04:53 PM
Joined Aug 2011
I have the sky 705. It was the original tx that came with the Cessna which had flaps
Old Mar 24, 2012, 08:56 PM
Joined Dec 2008
Ouch. The Sky 706 has the option to upgrade or reinstall the firmware on the information tab page.
You said you fixed the cable; so you tested the fixed cable on another Sky705 or Sky 706 to confirm it is working?
Sounds like you will need to get a new transmitter or have the board in your's replaced. If the firmware won't take any configuration changes then it sounds like the framework programming is messed up on the PROM Chip on the board.
I just don't have any other solutions for you. Because of the distance between us and you, the shipping fee alone would be over $35 just for a new Tx.. Maybe contact a dealer in your part of the world and see about a replacement
Regards
Max
Site Sponsor
Old Mar 24, 2012, 11:38 PM
Joined Aug 2011
I asked the Australian distributor and he said he didn't have any. I need to up grade to a decent tx any way since only some brands are allowed to be used at maaa fields (equivalent of the AMA I think)
Old Mar 29, 2012, 05:23 PM
Joined Apr 2008
Scrubmonkey, I suggest you re-check your USB cable and confirm on another TX that it is working. I had a problem with my cable that caused quite a bit of frustration.
There is a pinout diagram in this thread:
I bought a new connector from Jaycar for about a $1 to connect to the transmitter. Since fixing that I have had flawless communication from pc to TX.
Old Mar 29, 2012, 05:28 PM
Joined Apr 2008
Hmm...
Lets try again with that link...
http://www.rcgroups.com/forums/showthread.php?t=1382487
Old Mar 29, 2012, 07:01 PM
Joined Aug 2011
I looked at the diagram and did the same thing buying a connector from jaycar. Tested it and it was fine. There is a message that pops up on the computer saying that it is corrupted
Question Skyartec 705 - Dual Servo Ailerons? ZippoZ Skyartec 10 Mar 28, 2012 11:07 AM
Sold Futaba 4YF Trainer Box (Buddy Box) randyoo1214 Aircraft - General - Radio Equipment (FS/W) 2 Mar 08, 2012 07:44 PM
Help! Skyartec sky-705 receiver West Oz Mark Power Systems 0 Feb 27, 2012 11:20 PM
Discussion SKYARTEC SKY-705 channell mapping to Real Flight Gen 4.5 andione1983 Radios 0 Nov 02, 2011 04:32 AM
Alert Need a Buddy Box/Trainer Setup?? (PRICE REDUCED!) txflyboys2 Beginner Training Area (Fuel) 2 Apr 17, 2008 05:18 PM
