Old Jul 03, 2012, 03:52 AM
oldbilgewater is online now
Find More Posts by oldbilgewater
United States, PA, Quakertown
Joined Jan 2012
Doug: Looking good. It looks like our Stirling "cousins" are at about the same stage. Maybe they will get wet together?
OBW
oldbilgewater is online now Find More Posts by oldbilgewater
Old Jul 03, 2012, 08:41 PM
tinknocker is offline
Find More Posts by tinknocker
tinknocker's Avatar
New Jersey
Thanks. Sure looking forward to getting them wet but it won't be until next summer. I just put down a layer of glass so now starts the endless sanding. I would like to get the hull painted before the cold weather sets in. It seems like a long way away but it will be here before you know it. I'll try to get some pictures up tomorrow.
Doug
tinknocker is offline Find More Posts by tinknocker
Old Jul 04, 2012, 02:42 PM
tinknocker's Avatar
New Jersey
These pictures are almost the same as the last post but taken after many hours of sanding. Next is prime fill sand repeat-repeat-repeat. In my case there will be many repeat steps before it gets top coated. Thanks for looking.
Doug
Old Jul 04, 2012, 06:56 PM
norgale is offline
Find More Posts by norgale
Retired for now
Bonita Springs,Fl.
Joined Sep 2007
OOOOOOO! Dat's niccccceeeeee. Ya gonna glass it Doug? Pete
norgale is offline Find More Posts by norgale
Old Jul 04, 2012, 08:18 PM
tinknocker's Avatar
New Jersey
Yeah Pete the glass is already on with three coats of resin and lots of sand time with 60 grit and 150 grit. Primer is next and plenty of filler and much more time with the a sanding block and more primer. Thanks much Pete.
Doug
Old Oct 08, 2012, 03:12 PM
tinknocker's Avatar
New Jersey
Hi all
It has been a while since I have posted but that doesn't mean I have not been busy. Got the hull painted outside before the weather turned. We woke up this morning to 40 degree temps. The deck planking took close to 40 hours. The toe rails and motors are just put in place to get an idea how see how things will go together. Now that building season is just around the corner it will move a little quicker. I'll post more pictures as I go. Thanks for looking.
Doug
Old Oct 08, 2012, 04:31 PM
Tim B. is offline
Find More Posts by Tim B.
Tim B.'s Avatar
United States, CA, Oakland
Joined Aug 2009
GREAT looking start !!
Tim B. is offline Find More Posts by Tim B.
Old Oct 08, 2012, 04:43 PM
norgale is offline
Retired for now
Bonita Springs,Fl.
Joined Sep 2007
Now that's going to be a beauty. Good work Doug,nice and clean. Pete
Old Oct 09, 2012, 12:25 AM
jeepers1940 is offline
Find More Posts by jeepers1940
Madison, MS
A very nice job, Doug. As usual, I'm enjoying and learning from your fine work. Thanks for sharing with us.
Bill
jeepers1940 is offline Find More Posts by jeepers1940
Old Oct 09, 2012, 04:44 PM
P31 is offline
P31
Find More Posts by P31
P31
United States, WA, Spanaway
Joined Dec 2011
Originally Posted by tinknocker View Post
Hi all
Doug
What kind of wood is that on the sides and window frames.
Very nice build BTW
Gary
P31 is offline Find More Posts by P31
Old Oct 09, 2012, 09:33 PM
tinknocker's Avatar
New Jersey
Thanks guys for the encouragement.
Gary All the wood on this cabin will be bass wood and stained. The other two Chris's before this one were done in mahogany but the grain is straight and splits in a heart beat so it is a pain to work with. Areas between the windows would split very easily. So far no problems with the bass.
Doug
Old Oct 09, 2012, 11:35 PM
P31 is offline
P31
P31
Joined Dec 2011
I was thinking of doing the same thing, using bass wood on my referb build. thanks.
Gary
Old Oct 11, 2012, 01:32 PM
JimS43 is offline
Find More Posts by JimS43
USA, IN, South Bend
Joined Oct 2009
Hi all
Doug
Doug, very nice build. What motors are you using and what size props will you use? Are the plans ones you had on hand from a previous build or did you obtain them from another source?
Jim
JimS43 is offline Find More Posts by JimS43
Old Oct 11, 2012, 01:42 PM
JimS43 is offline
USA, IN, South Bend
Joined Oct 2009
Doug
Doug, will you be using thin mahohany veneer over the bass wood cabin sides?
Old Oct 11, 2012, 09:55 PM
tinknocker's Avatar
New Jersey
Jim The plans came from e-bay several years ago. I haven't seen them around lately. One thought you might want to do is contact Norgale. He had plans for the Chris Craft 63'so he may have plans for the Catalina. The motors are 12 volt Johnsons from All Electronics. I have not given much thought to the props yet but probably 11/4" to 11/2". Al at Ships and Things is my source of information for my hardware so whatever he recommends is what I will use. I used Min Wax Red Chestnut stain on the transom and really liked the way it came out so I what to use it on the basswod. I need to test it first to check the color on the bass. If it doesn't look right then we use a different stain but no veneer will go on the cabin. The bass has a fine grain so I am hoping that it will look like mahogany when it is finished. Hope I have answered your questions.
Doug
My Sterling Catalina has finally arrived...HELP!! tim slocum Scale Boats 133 Jan 13, 2009 11:00 PM
For Sale Sterling CC Catalina safspir Boats (FS/W) 0 Sep 20, 2008 02:23 PM
Discussion Seeking Sterling Catalina fittings clockman Scale Boats 28 Feb 17, 2008 07:33 PM
Discussion Sterling Century Seamaid and Catalina on Ebay Now E-Challenged Scale Boats 23 Apr 25, 2007 07:16 PM
Sterling catalina pics H.Lauer Scale Boats 2 Jun 20, 2005 07:19 PM
