Old Feb 28, 2012, 08:57 PM
Playing with AutoCAD!
PiperCub49's Avatar
United States, ME
Joined Oct 2008
Designing for scratch-built FPV wing...
Hey guys,
I will be ordering my first FPV system here soon, and I need a platform to fly it on. Based on all of the aircraft that I've seen, I've come here looking for a solid, stable, lightly loaded design to that will serve my FPV needs well.
I have noticed that the Ritewing Zephyr II is a popular platform. Because of it's flight characteristics, I have been thinking that I will use it as a base for my build. The biggest limitation that I have in making my own Zephyr is that I don't have a hotwire. That pushes me towards a KF airfoil. Here's some data that I have to work with:
Current design thoughts:
The more I look at airfoils, the more I confuse myself. According to this image:
I would think that I'd want an KFm-3 airfoil.
So, in the end, I guess I'm just asking for your opinion on my plans. I have so little experience with flying wings and large electric setups that I really need the help from those who have "been there, done that." Maybe my wingspan is off. Maybe my power system isn't viable. Maybe there is a better airfoil to use. Anything at all would help me tremendously.
Thank you,
Kody
PiperCub49 is online now Find More Posts by PiperCub49
Old Feb 29, 2012, 09:41 PM
PiperCub49's Avatar
United States, ME
Joined Oct 2008
Bumpity bump. Here's to hoping that someone has an opinion--anything to say at all...
Old Mar 01, 2012, 12:26 AM
Joined Feb 2011
I think im gonna try your plans. Im just gonna use pink homedepot foam.
rcthrasher is offline Find More Posts by rcthrasher
Old Mar 01, 2012, 12:48 AM
United Kingdom, England, Portsmouth
Joined Jan 2009
the kfm4 will give you great stability at slow speeds on flying wings, and also its great at speed, my 48 inch divinity flys like its on rails
cant comment on the kfm3 have never built one, but have read alot saying they are good lifter heavy lift wings.
you can allways build the kfm3 and try it then add an extra step underneith to give you something like the kfm7.
try it and see.
RCT
rcta15 is offline Find More Posts by rcta15
Old Mar 01, 2012, 02:11 PM
10^27
Joined Jul 2011
Just out of curiosity concerning your plans, why is your motor mount so close to the CoG of the wing? Even the ZII doesn't have the motor that deep into the wing. Also, how many degrees of sweep does the nose have?
hellabytes is offline Find More Posts by hellabytes
Old Mar 01, 2012, 02:17 PM
Went to mow a meadow
frank48's Avatar
Joined Feb 2007
Plus one for the KFM4 - I have a KESL wing and its a great stable flyer. Heres another KFM4 wing that flies well. Check out the scratch built foamy forum for a few more
I perused your drawing in sketchup and imho your angles and dimensions seem pretty much spot on comparing them with mine
Regards
Frank
frank48 is offline Find More Posts by frank48
Old Mar 01, 2012, 08:13 PM
PiperCub49's Avatar
United States, ME
Joined Oct 2008
try it and see.
RCT
RCT,
Thank you for the help. I'm thinking that the KFm3 might be a bit less stable than the KFm4 at high speeds because of the lack of a phillips-style LE, but of course this isn't suppose to be a speed plane, so I would be okay if this does prove true.
I really like having the ability to change it to a KFm7. That would get me closer to the KFm4, which has so much positive feedback.
Confession time. All I did to make that model was trace over the image here. I'll have to do some more looking and fix that mistake. Thanks for letting me know I was off on the drawing.
It is a 60* sweep.
EDIT: I have attached my modified plans and would appreciate your thoughts.
Regards
Frank
Frank,
I was looking at the KESL. All of this support for the KF airfoils is really encouraging. I guess I feel that I am wasting lift or creating excessive drag by using a fully symmetrical airfoil on a plane that I won't be rolling or flying inverted with. I hope that the KFm3 will treat me as kindly as the KFm4 does that pilot in those videos!
Old Mar 01, 2012, 10:32 PM
ashdec87's Avatar
Chicago suburbanite
Joined Feb 2004
For your first fpv plane I would suggest a trainer type plane. A wing is a really really bad first fpv plane.
ashdec87 is offline Find More Posts by ashdec87
Latest blog entry: SS FPV Maiden
Old Mar 01, 2012, 11:24 PM
PiperCub49's Avatar
United States, ME
Joined Oct 2008
Interesting. I'm curious as to why. If it's large enough with a light enough wing loading, I don't see why it can be flown similarly to a trainer. The wind might bump it around more than a trainer, but then again, one doesn't have to fly in the wind. I built a 16" Dead Simple Wing. It has a pretty high wing loading, but it is still one of the most docile and predictable plane I've ever built.
Old Mar 02, 2012, 05:54 AM
frank48's Avatar
Joined Feb 2007
In my limited experience of flying a wing when the wind starts to blow its the one I fly. They handle windy conditions much better than a trainer type plane, maybe its because theres no fuselage to catch the wind
Old Mar 02, 2012, 06:58 AM
Austin TEXAS area
Joined Apr 2008
I only have The blucore wing to go by but I have built it in 34" up to 47" spans. The blucore is super simple to build, very easy to fly, with great flying characteristics. I let a fellow old timer fly one of my 34" wings, his comment was it flies better than a zagi, so you might look at this design.
pops57 is offline Find More Posts by pops57
Old Mar 02, 2012, 11:57 AM
ashdec87's Avatar
Chicago suburbanite
Joined Feb 2004
Because trainers will auto correct where a wing will not.
I have both types of planes for fpv and trust me on this one. Wings are great and a lot of fun. But it's really nice to know that a trainer will fly itself for a bit if something goes wrong. Which it absolutely will for the first few flights. It's an entirely different type of flying so you have to relearn some basic skills.
Old Mar 08, 2012, 06:59 AM
..in a Johnny Cash voice.
Vintabilly_NS's Avatar
Canada, NS, Beaver Bank
Joined Aug 2010
This man speaks the truth! I fly FPV. Wing for wind, trainer for.....well... training.
You will lose your airplane..you will be happy when it glides itself to a safe landing on it's own...you will enjoy learning the systems....you will progress!
LOL, seriously. Fly/build what you like. I'm in on the kfm wing build for myself. Besides, you can't really go wrong, you're going to crash regardless so give' er.
PS- FPV at 25mph is still pretty crazy at first.
Vintabilly_NS is offline Find More Posts by Vintabilly_NS
Old Mar 08, 2012, 07:38 AM
PiperCub49's Avatar
United States, ME
Joined Oct 2008
Thank you both. Part of me says, "You've gone this far. Don't back up now. You'll get it to fly." The other half of me knows that too many people come into the hobby with that attitude! I can build both platforms, and I think that's what I'll do. So if you think that it's necessary, I'll start with a trainer, learn on that, and move to the wing at some point. Sound like a smart plan of attack?
Old Mar 09, 2012, 08:49 PM
10^27
Joined Jul 2011
Hey Piper, was just thinking about your fpv dilemma not too long ago and i thought I'd point you in the direction of another thread that might peak your interest (if you're good at scaling upwards)
this post:
http://www.rcgroups.com/forums/showp...5&postcount=16
(you should be able to access the main thread from the link in the upper right of the page)
KFm4 might not be your best bet, but they're very very easy to slap together just for testing purposes. I'm still guessing it's the geometry that you're after. I'm actually poking for help in some other threads to see if my KFm7 approach is sound. More steps on the top = more lift = more gear. So far, my 38" rendition is working out pretty well with 14-16 minute flight times on a single 2200mah 3S, but I have no idea what will happen if i try to strap an additional half pound of fpv gear to it.
Discussion Scratch Built Balsa Wing (Build Log) The_RattleSnake Flying Wings 37 Apr 21, 2012 04:32 PM
Build Log 2nd Scratch built plane ever! nickwasp Foamies (Scratchbuilt) 0 Feb 27, 2012 03:14 AM
Discussion I covered My scratch built wing! The_RattleSnake Painting and Finishing Tips 0 Jan 31, 2012 05:20 AM
Yippee! Scratch built flying wing clipper99 Flying Wings 3 Dec 05, 2011 04:56 PM
