Old Oct 16, 2003, 09:48 PM
bradm is offline
Find More Posts by bradm
Blue Foam & a Happy Home
bradm's Avatar
www.DadsFunPage.com
Joined Jun 2003
50% Zagnutz build - Here's hoping!
I've got a Zagi and a Pocket Combat Wing (PCW) and now it's time for my first scratch build. I'm armed with info from http://home1.gte.net/texhills/index.html and inspired by the vidoes from http://www.fdisk.com/rcaddict/ (see MZN50+1) I'm off.
First shot - just after folding
bradm is offline Find More Posts by bradm
Old Oct 16, 2003, 09:49 PM
bradm is offline
bradm's Avatar
www.DadsFunPage.com
Joined Jun 2003
Next, setting up the layout. I had planned to use the 1020 Kokum in the photo, but ended up using a 950 Li-Ion to move the weight toward the nose.
Old Oct 16, 2003, 09:52 PM
bradm is offline
bradm's Avatar
www.DadsFunPage.com
Joined Jun 2003
From here I stripped the skin from the insides of the wing trailing edge and glued with Super 77. The Elmer's in the photos was used as a weight rather than glue.
I was dissappointed in the large gap, but decided it provided good access to the equipment and should be much stronger after taping and covering.
Old Oct 16, 2003, 09:53 PM
bradm is offline
bradm's Avatar
www.DadsFunPage.com
Joined Jun 2003
After the glue had dried over night I filled part of the gap with a foam piece cut to fit. I used 5 min epoxy and then ran clear packing tape across to hold it tight. A few more strips of tape across at angles really stiffen this baby up!
Old Oct 16, 2003, 09:55 PM
bradm is offline
bradm's Avatar
www.DadsFunPage.com
Joined Jun 2003
Since this is my first scratch build, it may as well be my first covering experience. I used Monokote from my LHS. Ironing it on is really kind of fun. It was different than taping my PCW, but about the same amount of work. It's definately cleaner.
Old Oct 16, 2003, 09:57 PM
bradm is offline
bradm's Avatar
www.DadsFunPage.com
Joined Jun 2003
I used taped over FFF for the elevons as well. This is probably a bad idea, but I did it anyway. I covered the top in black so I'll have a real nice Halloween flyer!
Do you think it's over propped?
Old Oct 16, 2003, 09:59 PM
bradm is offline
bradm's Avatar
www.DadsFunPage.com
Joined Jun 2003
Here's the final product next to my PCW for size comparison. Don't worry the PCW is still holding up. I took it apart for retaping and I've robbed the parts from it for now. I'll get back to it, though as I really like it.
Thanks to CenTexFlyer for providing the info and to FDisk for providing the inspiration.
So, do you want to know if it will fly?
Me too!
Old Oct 17, 2003, 08:42 AM
Rip-N-Burn is offline
Find More Posts by Rip-N-Burn
Rip-N-Burn's Avatar
Chandler Williams, Arizona, United States
Joined Nov 2002
Nice build thread. what's the weight?
Looking forward to a flight report..
Kenny..
Rip-N-Burn is offline Find More Posts by Rip-N-Burn
Old Oct 17, 2003, 08:50 AM
No rudder is offline
Find More Posts by No rudder
France
Joined Oct 2003
I'm planing to do something quite close, but slightly ( perhaps the H is not at the right place ) different, i'm very interressed in your flight tests result.
By experience be very carefull with the CoG on such a small flying wing.
No rudder is offline Find More Posts by No rudder
Old Oct 17, 2003, 09:51 AM
pcaffeldt is offline
Find More Posts by pcaffeldt
Arizona Rim Country
Joined Nov 2001
A true e-zoner !
Definately a worthy project ! Well Done. Somewhere I've got directions on how to overcome that gap on top. I'll see if I can dig them up.
pcaffeldt is offline Find More Posts by pcaffeldt
Old Oct 17, 2003, 11:03 AM
CenTexFlyer is offline
Find More Posts by CenTexFlyer
Near Austin
Joined Dec 2001
Great job, Brad!
I would imagine that guy will be a handful! As NoRudder said, check and then DOUBLE check that CofG. I would go for a tad nose heavy on the test glides with some up reflex to make sure. I bet you have yourself a real zippy MZN50 there!
And how much did you have in material costs???
CTF
P.S. I forgot to ask, I'm re-doing the website. What do you think?
CenTexFlyer is offline Find More Posts by CenTexFlyer
Old Oct 17, 2003, 12:14 PM
bradm is offline
bradm's Avatar
www.DadsFunPage.com
Joined Jun 2003
I have no clue on the AUW. It's the same equipment as I had on the PCW (including the Li-Ion for a while) so should be within a good range.
The C of G is about **EDIT 4.5 inches ** back from the nose as recomended by fdisk's site. I'm definately interested in getting that gap out of there on the next one I build, but it is really stiff with that little bridge and the tape.
It'll be a handfull to be sure. I wouldn't have tried it without progressing from the Zagi to the PCW. Just jumping right in on a little one like this could lead to frustration! I'm figuring this will be the bird I use to learn how to build. I'll fly it and thrash it 'till it's done. If I really like it I'll build another or, if not, happily go back to the PCW. I'm also interested in another variation called the Jackknife.
CTF - The new web page is looking great! It's interesting to see the twin version. If you have pics of your other variations we'd all be interested in seeing those as well. I've printed off your tips page. I wish I'd known before about not spreading hot glue with my finger
The weekend is shaping up to be a good one so hopefully I'll have a flight report soon.
EDIT: Almost forgot - I'm guessing about 35 cents for the foam, control link and home made horns (craft stick). I'm sure the covering was more, but I like the way it looks.
Old Oct 17, 2003, 03:08 PM
Near Austin
Joined Dec 2001
Re: That ugly little gap
Hey Fdisk,
I thought we came up with the geometry to cut section so that the gap was closed up!?!?! Am I dreaming, or was this something on my long and lovely "to do" list? The little man running around in my head pulling files found something that said essentially to just trace the intended airfoil on onto the center section cut on both sides....?? Does this sound right?
CTF
Old Oct 17, 2003, 06:32 PM
bradm is offline
bradm's Avatar
www.DadsFunPage.com
Joined Jun 2003
Well, it's a pretty poor time to test out a new and small airplane. The winds are right around 15. I'm sure it's best to wait for another time.
So, I did it anyway
It started with a test "glide" across the back yard. I gave it a burst of throttle just to make sure it was steady. Very nice level straight ahead flight. My back yard is sheltered from the wind by trees and bushes. This was a pleasant surprise because I had just eyeballed the elevon settings.
Next flight was up the hill from my house in the baseball outfield. I used the exact same settings as I had for my PCW. Well, it flies. It doesn't fly well yet, but it does fly.
In spite of having the heavier Li-Ion up front it is a bit tail heavy I believe. Going into the wind it looks a bit like it's riding a wheelie - nose up slightly to keep it level. When the wind gets under it, up it goes. I can raise the nose higher and almost park it there facing into the wind. It was really difficult trying to gain altitude.
Turning down wind it speeds up in a hurry, but holds altitude. The really rough part is turning back into the wind. It slows way down when it's side is turned toward the wind and I have to be very careful in the turn not to tip it. It also gives back all the altitide it had gained going up wind.
Does this sound tail heavy or should I just consider myself lucky flying on such a breezy day?
I brought it back home nearly as pretty as when I left. (The airplane I mean. I'm not pretty)
Next I'm going to try moving the CG forward a bit at a time by taping a couple of quarters to the nose. There's also a little more room to slide the battery forward. Hopefully tomorrow will be a better day for this.
I'll let you know how it goes.
Old Oct 17, 2003, 07:47 PM
Near Austin
Joined Dec 2001
WOOF! Wind and a small plane are really hard to decipher. You really need a still, quiet day to just to experiment with both the reflex required and getting the CG right. I have been amazed at how a full sized ZagNutz will react to a breezy day as versus a still day - the difference can be quite dramatic. I would say that at this point you *MAY* be a tad tail heavy but explore that little extra space you say you have to move the batt forward. Then try it on a still day. I know I don't need to remind you since you've flown a wing before, but I'm going to anyway.... you need to let the wing "fly" and get up on "step" before you really start to see its' FLYING characteristics rather than its' power on nose, high "guiding" characteristics. If you managed to fly a circuit or two in this configuration, then I'd say you have yourself a diamond in the rough, and it only needs to be tweaked a bit to be a full on, rip 'em up flyer!
CTF
Hello all.... I am new, Here's my GA F-14 build.. -=PLanE CrazY=- Electric Ducted Fan Jet Talk 90 Apr 29, 2006 07:58 PM
Here is my Mini Telemaste build photo's Bigwheels Electric Plane Talk 7 Sep 08, 2005 02:59 AM
My first SS build past, here's my report card... LexTalionis Parkflyers 8 Jun 05, 2004 09:34 PM
Ok guys, here's my lastest scratch job steve neill Electric Ducted Fan Jet Talk 15 Jul 29, 2001 03:12 PM
