Old Feb 28, 2012, 04:26 PM
payne9999 is online now
Find More Posts by payne9999
Balsa&Tissue
payne9999's Avatar
United States, OR, Beaverton
Joined Jan 2011
Question
Wing Structure Question
I am in the middle of an 80" DC-6B scratch build and the wing structure seems to have a weakness between the inboard nacelles and the center where it joins the fuse. The rest of the wing seems stiff enough especially once covering will go on but I am worried about the center section since at this point before covering it seems to flexible (torsional strength...twisting). All the weight of the nacelles, motors etc outboard of this area seem to be putting quite a load on the inboard sections.
I am thinking of adding some shear webs to the other spars in that section and/or sheeting these areas. Just looking for advice, any thoughts?
Dave
payne9999 is online now Find More Posts by payne9999
Old Feb 29, 2012, 10:47 AM
Herman Munster is offline
Find More Posts by Herman Munster
Herman Munster's Avatar
United States, Mt, Libby
Joined Nov 2007
I think sheeting both the top and bottom in that area would help significantly. I take it you have shear webs on the main spar.
Herman Munster is offline Find More Posts by Herman Munster
Old Feb 29, 2012, 12:04 PM
how much is offline
Find More Posts by how much
how much's Avatar
United Kingdom, England, Wigan
Joined Jul 2011
Dave
just been looking through your build log http://www.rcgroups.com/forums/showthread.php?t=1597461
very nice work!
i noticed you built the wing in two halfs... did you put a ply brace accross the centre vertical join of the main spar? doesnt need a lot... just a 1/32" ply plate accross the join on one side
i would definately sheet the centre section in 1/16" balsa top and bottom too
i will be doing the wing next on my balsa sunderland
David
how much is offline Find More Posts by how much
Old Feb 29, 2012, 12:16 PM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
Carbon fibre!
Keenan smith is offline Find More Posts by Keenan smith
Old Feb 29, 2012, 02:01 PM
M.Putnam is offline
Find More Posts by M.Putnam
Shade Tree Aviation #2
M.Putnam's Avatar
United States, NC, Rutherfordton
Joined Jan 2002
Sheeting & cap strips will help tie the structure together.
Matt
M.Putnam is offline Find More Posts by M.Putnam
Old Feb 29, 2012, 02:24 PM
Joined Dec 2010
carbon fibre!
Old Feb 29, 2012, 05:54 PM
invertmast is offline
Find More Posts by invertmast
United States, FL, North Port
Joined Mar 2004
I'd suggest putting the top or bottom sheeting on first and then re-examining your original concern. The sheeting will add a substantial amount of torsional rigidity.
If after adding one side of the sheeting, you find that it still isn't torsionally stiff enough for you, you can add ribs Diagonally between the wing ribs to help as well.
invertmast is offline Find More Posts by invertmast
Old Feb 29, 2012, 10:31 PM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
Originally Posted by how much View Post
Dave
very nice work!
David
David,
the main spar consists of shear web with a top and bottom spar of a spruce like wood (paulownia wood). The remaining spars are just 3/16" paulownia top and bottom. I was thinking about adding some reinforcement plates on either side of the spar in the center section.
Dave
Old Feb 29, 2012, 10:34 PM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
Thanks all for the advice,
I had not thought much about carbon fiber but I had seriously considered more shear webbing and some limited sheeting. This was designed to be an 80" plane that was to be under 3 to 3.5 lbs. so it is a game between strength and weight. I still feel like I will make the goal and when the wing is bolted on the center section under the fuse will be much stiffer. It is a bit of a guessing game trying to figure out how much to add and how much the fuse and covering will help as well.
Dave
Inflatable Wing Structure jonas_madman Flying Wings 23 Apr 25, 2015 10:33 PM
Best Wing structure for strength and durability. soholingo Composites Fabrication 5 Nov 03, 2004 06:57 PM
Yippee! Jaro Muller latest: state of the art W wing structure: Elita Protocooler The Builders Workshop 10 Feb 24, 2004 11:45 PM
Idea Questions on wing structure astroboy Modeling Science 5 Jul 22, 2003 01:48 AM
"D-tube wing structure" - what does it mean ? oded mazor Electric Sailplanes 2 Mar 05, 2002 09:56 AM
