Old Feb 28, 2012, 11:25 AM
SpeedsterDEN is offline
Find More Posts by SpeedsterDEN
DS will change your life
SpeedsterDEN's Avatar
Danmark, Nordjylland, Sæby
Joined May 2010
Funcup as towplane
You do not have to spend a fortune on a towplane.
A Multiplex funcup do it really well.
With a few improvements, and the right engine setup its a great little towplane.
1. Better motor mount.
2. Stronger towhook, fixed with wire around the mainspar, or else it will be pulled out of the wing
(The original is ok for small foam gliders)
Then your ready.
Incredibly easy to fly, and worth every penny.
My setup is:
Turnigy Aerodrive SK3 - 3542-1185kv
http://www.hobbyking.com/hobbyking/s...dproduct=18120
13x4 prop
100 Amp ESC
4 cell 4000 Mha 40 c battery.
It pull 75 Amp 1200 Watt.
And it pull my 3,1 kg 3,20 meter F3b all GFK glider, - 3 meter Fox, - 3,6 meter Nimbus from the ground.
or 4 foam gliders at a time.
I Think this is max size gliders for the funcup.
For saving the motor, I only use full power at the first few second of the take off.
3,6 meter Nimbus.
Funcup towing a 3,6 meter glider (0 min 30 sec)
The next videos was with a smaller motor
Funcup towing fun. (1 min 54 sec)
Funcup towing disaster. (1 min 46 sec)
http://www.youtube.com/watch?NR=1&v=...ture=endscreen
Scratchbuild Fox first flight. (1 min 10 sec)
FOX fly by
Flyfly Fox fly by. (1 min 33 sec)
Regards
S
SpeedsterDEN is offline Find More Posts by SpeedsterDEN
Old Mar 26, 2012, 01:49 PM
Joined May 2010
More Funcup towing
Motor is now:
http://www.hobbyking.com/hobbyking/s...idproduct=8489
And its doing a great job, and dont even get hot when towing.
Still 13x4 prop and 4 cell 4000 mha battery + 100 Amp ESC
Funcup towing 3 meter gliders (1 min 26 sec)
Regards
S
Old Apr 04, 2012, 05:03 PM
Joined May 2010
FunCup towing 3,3 meter glider (0 min 47 sec)
Old Apr 22, 2012, 10:56 AM
Joined May 2010
Amp draw
Amp drop in flight compared to static test.
Rc. Amp draw, static / flight (1 min 40 sec)
Static 73 Amp og 1075 Watt
Flying 56 Amp og 839 watt
Bonus Trailer video
RC Funcup go pro. (1 min 42 sec)
Cheers
S
Old Apr 25, 2012, 03:26 PM
Joined May 2010
Funcup,double glider towing.
My Funcup towing a 1,1 kg 2,4 meter Speedster, and a 2,3 kg 3,2 meter F3B Trinitus in double towing.
Set up is Motor Turnigy 4250 Brushless Motor 1000kv :
ESC: 110 AMP
http://www.hobbyking.com/hobbyking/s...rushless_ESC_3... prop
Batt 4000 Mha 4 Cell:
http://www.hobbyking.com/hobbyking/s...dproduct=13949
Servos all HXT 900.
http://www.hobbyking.com/hobbyking/s..._12sec_Micro_S...
Funcup, towing 2 large gliders. (1 min 44 sec)
Cheers
S
Old Nov 19, 2012, 08:18 AM
Joined May 2010
Funcup
Funcup towing a 4,85 meter glider. (0 min 54 sec)
Funcup towing 4 meter Simprop Solution. (1 min 27 sec)
Glider towing with Multiplex Funcup. Due to heigh grass and soft ground + the heavy 4 meter glider, the towplane needed a little start help.
Normal procedure is that the helper runs to the side, but when he saw we were filming he got the stupid idea to throw himself to the ground. Fortunately, the glider took off at the last second.
Imagine him at the hospital with a 4 meter glider stuck, where the sun dont shine
RC glider towing, start help. (0 min 24 sec)
Cheers
S
Cool Apprentice 15e as a Towplane? Pilot28 Electric Plane Talk 14 Jul 16, 2015 11:13 PM
Discussion Avimodelli Calypso Mk3 for SALE!? And Tango? And as many as you might want? mixerfix Classic Pattern Flying 0 Feb 23, 2012 10:10 PM
Discussion 1/4 scale cub as towplane? thermal145 Scale Sailplanes 3 Apr 21, 2010 06:35 PM
Giant Stinger w/G-62 as towplane...any pictures?? quietflyer Scale Sailplanes 12 Jan 31, 2005 06:56 PM
Lanier 84" Stinger as Towplane ? quietflyer Scale Sailplanes 0 Dec 03, 2003 01:59 AM
