Old Feb 28, 2012, 06:25 AM
Warbird@home is offline
Find More Posts by Warbird@home
Warbird@home's Avatar
The Netherlands, NB, Hapert
Joined Apr 2002
63" Hawker Typhoon
Hi folks , I would like some advice regarding swinging a 24" 4 x bladed prop on this aeroplane. Is anyone else swinging a prop like this ona scale warbird? I think maybe a gear box with an inrunner may be the way to go?, but I have no experience of propellors of this size, so any help would be greatly appreciated. The aeroplane will weigh 7lbs approx (3.175 Kgs)
Thank you
Ray
Warbird@home is offline Find More Posts by Warbird@home
Old Feb 28, 2012, 09:58 AM
Doug Bartley is offline
Find More Posts by Doug Bartley
Doug Bartley's Avatar
Canada, ON, Owen Sound
Joined Oct 2008
Must be a typing error here I suspect. Theres no way a 24" anything will mount on a plane with a 63" wingspan. A four blade prop would weigh at least 2 lbs by itself at 24". Maybe a 83" wingspan??? 93"???
24" 4 blades are avialable from Vario Prop (22.6 actually), Zinger will custom make 24" 4 bladers, and Simprop has very $$ dadjustable scale props. FWIW Doug B
Doug Bartley is offline Find More Posts by Doug Bartley
Old Feb 28, 2012, 11:20 AM
Joined Apr 2002
I calculated it as follows/...Typhoon prop is 14ft, time 12 to get to inches, then divide by 7?
did I have a brain fart here somewhere?
Could be :-)
Ray
Old Feb 28, 2012, 10:20 PM
luke352 is offline
Find More Posts by luke352
Australia, QLD, Ipswich
Joined Sep 2008
The data I just found puts the Typhoon at a 41ft 7" wingspan, which puts your 63" model @ 1 to 7.9 scale which puts your prop at about 21". Even a 21" prop is going to be a bit on the big side you could safely go down to 18" and it would more than likely still look perfectly scale.
luke352 is offline Find More Posts by luke352
Old Feb 29, 2012, 12:59 AM
hul is offline
hul
Find More Posts by hul
hul
hul's Avatar
Switzerland
Joined Mar 2003
say you want to run 700W (100W/lb) and 60mph pitch speed. This would roughly be a 21x30x4 prop spinning at 2100rpm. Don't think such a prop can be bought.
Using a 4:1 gearbox, you'd need a Kv of about 750rpm/V on 4s. Outrunner territory.
Hans
hul is offline Find More Posts by hul
Old Feb 29, 2012, 05:57 PM
KIWINB is offline
Find More Posts by KIWINB
Auckland New Zealand
Joined Sep 2010
Typhoon wing span is 41 ft 7in, x12 = 499 inches, divide by your scale span of 63 inches, and scale =7.92:1.
Prop diameter is 14 feet, x 12 = 168 inches, divide by 7.92 = 21.2 inches.
Most of the Typhoons had 3 blade props.
Only the very last of the production run had 4 blade props, as did all the Tempests. All still 14 ft diameter.
This will make your prop selection easier.
KIWINB is offline Find More Posts by KIWINB
Old Mar 01, 2012, 02:38 AM
Joined Apr 2002
a BIG THANK YOU
To all you guys....I hadn't thought this through properly and yur comments have made things much clearer..
Thanks folks
Ray
Discussion Hawker Tempest or Typhoon... yorkiepap Electric Warbirds 76 Aug 06, 2012 11:13 AM
Sold Ems hawker typhoon lpu only blmhighlander Aircraft - Electric - Airplanes (FS/W) 4 Oct 17, 2011 12:03 PM
Discussion 63'' FREE Hawker Typhoon plan in RCME this month. Matt Halton Electric Warbirds 16 Oct 11, 2008 11:14 PM
Build Log Depron Hawker Typhoon 63 inch Wingspan fuelsguy Electric Warbirds 20 Apr 16, 2008 01:00 PM
Discussion Depron Hawker Typhoon 63 inch Wingspan fuelsguy Foamies (Scratchbuilt) 2 Jul 22, 2007 12:27 PM
