Old Feb 27, 2012, 11:36 PM
scarab is offline
Find More Posts by scarab
scarab's Avatar
Australia, SA, Goolwa North
Joined Dec 2004
Xplorer E motor choices
I'm looking for suitable motor choices for Xplorer 3.5 to be used in ALES comps.
I expect the flying weight to be 2.4kg (84.67 ozs)
Currently on my list are:
Hyperion 3025-8 - Looks like it might be OK but it could be really tight fit.
MVVS 46 5.6/690
MVVS 46 5.6/960 - these may fit, but are a bit heavy.
A Nue motor would be my first choice but is beyond my budget.
Other suggestions appreciated, preferably for motors available in US or Australia.
scarab is offline Find More Posts by scarab
Old Feb 28, 2012, 05:41 AM
cianokol is offline
Find More Posts by cianokol
Joined Mar 2007
HET2W+5,2:1Kontronik, 3SLipo, (Pike Perfect 3,8), 2,2kg, clinbing ca 10m/s
cianokol is offline Find More Posts by cianokol
Old Feb 28, 2012, 06:19 AM
flyboy320 is offline
Find More Posts by flyboy320
flyboy320's Avatar
Canada, ON, Burlington
Joined Sep 2004
Check out Neil's recommendations for a Supra on his web site;
http://www.hyperflight.co.uk/product...ra-e-f5j-glass
I'm in the middle of building a E Super Supra (147" span) when finished will be around 2.1Kg and I'm planning on using a Mega 16/25/2 with a Kontronik 5.21gb, same as RoK-K used on his Supra found on his build thread.
flyboy320 is offline Find More Posts by flyboy320
Old Feb 28, 2012, 08:15 AM
Jebera is offline
Find More Posts by Jebera
Jebera's Avatar
United States, NH, Nashua
Joined Oct 2006
MVVS 46 5.6/690
Hi,
Hyperion is fine, I have a 3032 6 turn, 3s and a Graupner 15x10, climbs at 13m/s.
Cheers!
André
Jebera is offline Find More Posts by Jebera
Old Feb 28, 2012, 08:32 AM
FASTBEN is offline
Find More Posts by FASTBEN
Cumulus Altimus
FASTBEN's Avatar
United States, TX, Keller
Joined Feb 2002
Originally Posted by Jebera View Post
Hi,
Cheers!
André
2nd the Hyperion
FASTBEN is offline Find More Posts by FASTBEN
Old Feb 28, 2012, 08:47 AM
Jebera is offline
Jebera's Avatar
Joined Oct 2006
Yes,
Cheap and good enough.
André
Old Feb 28, 2012, 09:54 AM
scarab is offline
scarab's Avatar
Joined Dec 2004
Thanks for your replies.
Without having a motor at hand, my major concern using the Hyperion was having enough clearance for the motor cables to clear the rotating case.
From your comments, that appears to not be an issue.
Your help is much appreciated.
Don
Old Feb 28, 2012, 09:57 AM
scarab is offline
scarab's Avatar
Joined Dec 2004
Did either of you choose to use the motor backplate bearing support offered by Hyperion?
Don
Discussion New product Xplorer E Sotir Electric Sailplanes 20 Aug 22, 2015 02:53 AM
Discussion DW BAF 55" YAK 54 Motor Choices HELP bmoranx 3D Foamies 1 Oct 26, 2011 09:37 PM
Help! Electric Motor choices for .15 gas sport plane maxitron Foamies (Scratchbuilt) 1 Oct 19, 2011 11:46 PM
Wanted E-Xplorer fuse jaizon Aircraft - Sailplanes (FS/W) 0 Sep 15, 2011 06:54 PM
Help! Pegasus 3 electrical and motor choices chrissell Scale Boats 9 Aug 03, 2011 05:29 AM
