Old Feb 27, 2012, 04:56 PM
DreamArcher is offline
Find More Posts by DreamArcher
DreamArcher's Avatar
Joined Apr 2008
Question
Can I mount my retracts at an angle?
Great Planes P-51D 40 kit. To get the wheels up in the required area in front of the main spar I either have to: 1) put a slight bend in the legs. 2) Mount the retracts at an angle. I'm not sure I'll be able to bend the 3/16" wire accurately or at all. So I'm looking at solution #2. Is that OK or do the retracts have to be mounted exactly at 90 deg?
DreamArcher is offline Find More Posts by DreamArcher
Old Feb 27, 2012, 06:29 PM
EJWash1 is online now
Find More Posts by EJWash1
AMA 910957
EJWash1's Avatar
United States, WA, Hoodsport
Joined Mar 2008
Where the landing gear goes and how its angled when retracted is not important. How it is positioned when it is extended is VERY important.
So I’m looking at page #20 of the build manual (online) for the GP P-51D 40. From the pics of the landing gear wire, there seems to be a slight dog-leg (bend) in the wire angling the gear towards the leading edge of the wing. However, I do not see any reference to the bend in the manual. This sorta makes me think that the bend *may* not be there at all. One way to get the proper angle is to make the adjustment at the gear wire coil.
- Remove the gear wire from the retract mechanism.
Now secure the short end of the wire (the end that goes into the retract mechanism) and uncoil the wire to the proper angle.
3/16”wire? Seems too large for this application. Even the 60-size models use 5/32” wire.
EJWash
EJWash1 is online now Find More Posts by EJWash1
Old Feb 27, 2012, 06:50 PM
Joined Apr 2008
Thanks. I hadn't thought of uncoiling a little. I don't have a vice or very solid bench in our house but I'll give it a try anyway.
Yeah, after getting the 40 size Hobbico retracts and seeing what crap they are I kind of went overkill and got Robart 608 HD. These say 45-120 planes and I figured this plane squeaks in at the bottom range.
Old Feb 27, 2012, 07:10 PM
AMA 910957
EJWash1's Avatar
Joined Mar 2008
Since you don't have a vise, you could drill a 3/16" hole in a a length of 2X4 and use that as leverage.
I have some 1/4-scale kits that are in the 20+-pound range and they have 3/16" gear wire. I appreciate going strong, but maybe you should consider lighter gear if you haven't already bought them.
EJWash
Old Mar 05, 2012, 12:15 PM
Joined Apr 2008
I've been test fitting and I think they'll work fine but given your advice and handling these beasts has made me re-think. I'll just save them for a larger build I'm doing next winter. I've ordered the next size smaller Robarts with 1/8" legs. Thanks.
Old Mar 20, 2012, 01:17 PM
Joined Apr 2008
Here's the smaller mechanical Robarts.
Discussion Bought an Airfield F16, Can I put retracts on it? thor4944 Foamy EDFs 5 Feb 12, 2012 10:20 PM
Discussion Bought an Airfield F16, Can I put retracts on it? thor4944 Electric Ducted Fan Jet Talk 3 Feb 12, 2012 08:27 AM
Discussion Is my model at the right angle ? sam-smith Scale Kit/Scratch Built 3 Nov 12, 2011 04:15 PM
Help! Why is my CHAMP flying at an upward angle? Planet Papi Beginner Training Area (Aircraft-Electric) 4 Jun 30, 2011 03:06 PM
Alert Bad CS I can handle, but an obvious attempt at deceit? eeephreakeee Banana Hobby 12 Mar 23, 2011 10:59 PM
