Old Feb 27, 2012, 03:47 PM
Pulseifier is offline
Find More Posts by Pulseifier
Joined Sep 2011
Help!
Fun Cub Flaps
Guys/Gals.........need some advise with the flaps. I have a DX7 which supposedly you can program for the flaps but you need to reverse the servo on one of the channels. I'm trying to get them on the flap mix switch so I can program it for mid and full flaps but am totally lost. I also have a servo reversing Y harness. I tried that but still only get 1 flap to work. I was told something about a master/slave setting that needs to be deactivated? Again lost. The DX7 manual is not as clear as it could be (at least to me). Any scholars out there? Or at least a point in the right direction? I'm using an AR6200 reciever if that helps any.
Pulseifier is offline Find More Posts by Pulseifier
Old Feb 28, 2012, 12:13 PM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Originally Posted by Pulseifier View Post
I also have a servo reversing Y harness. I tried that but still only get 1 flap to work. ...
If only one servo works when using a Y-harness, then either a servo or the Y-harness is defect.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Discussion super cub lp flaps and ailerons ford f47 Electric Plane Talk 8 Jun 25, 2014 07:25 AM
Discussion Super Cub LP or Fun Cub qakeith Beginner Training Area (Aircraft-Electric) 16 Jul 18, 2012 11:42 AM
Wanted Floats for Multiplex Fun Cub/Easy Cub JoeR Aircraft - Electric - Airplanes (FS/W) 6 Dec 11, 2011 08:59 AM
Discussion Easy Cub / Fun Cub They just want to climb Jim Cantillo Foamies (Kits) 7 Apr 18, 2011 04:56 PM
